    Precision Piezo z probe advice for custom hotend
    Third-party add-ons
    2.9k
    • fmaundefined
      fma
      Well, underbed solution is not that simple, and require more piezo discs.
      About piezo discs, I read there are different types, some can be tight and still deliver the same signal only depend on the pressure variation. Where can I buy such discs in Europe?
      Thanks,
      Frédéric
      • whosrdaddyundefined
        whosrdaddy
        I buy murata 20cm disks from mouser.
        • Moriquendiundefined
          Moriquendi
          There are different types of piezo disk but our system is designed to work with the type of disk that is used in piezo buzzers. These piezo disks (usually the Murata 7BB series) will produce a usable signal if they are bent or through a change in pressure. We sell everything you'll need, including piezo disks, on our website https://www.precisionpiezo.co.uk/shop
          Idris
          • fmaundefined
            fma
            Ok, I'll give a try with this discs.
            BTW, which PCB should I buy? The 'Piezo20 PCB v1.1', or the 'Universal Piezo Z-Probe PCB v2.x'?
            Frédéric
            • DjDemonDundefined
              DjDemonD
              Universal kit system is more versatile especially for anything custom like this. The Piezo20 pcb has evolved into something that only really suits the Piezo20 module design or very close derivatives.
              • fmaundefined
                fma
                Ok!
                About pressure on the disc, should I design the top mount so it as a large surface on the piezo disc (white part), or is something like only 3 pressure points better?
                Frédéric
                • DjDemonDundefined
                  DjDemonD
                  For best sensitivity support the disc on one side on its periphery and push into the centre from the other side. Evenly spread compression work but is slightly less sensitive.
                  • fmaundefined
                    fma
                    The problem is I need to keep the disc compressed so the hotend does not move…
                    Frédéric
                    • DjDemonDundefined
                      DjDemonD
                      You can preload them quite a lot, the signal is produced on change so even a heavily preloaded disc generates a rising voltage on further bending/compression. Our circuit is a differentiator in part so it looks for change in voltage. Even small rises generate triggers.
                      • fmaundefined
                        fma
                        Good! Thanks.
                        Frédéric
