    Exponential variable for pressure advance?
    Firmware wishlist
    5.1k
    • nytundefined
      nyt
      thoughts?
        Have you established that reducing pressure advance improves the quality of the higher speed corner in that print? If so, how much did you need to reduce it?
        • nytundefined
          nyt
          Yes, but I don't recall how much. I'll recreate it tomorrow, print running at the moment.
          • nytundefined
            nyt
            This time with a 0.4mm nozzle since it was loaded up… volcano with ruby nozzle 0.2mm layer height
            Maybe add a factor and exponential variable to tune the equation as necessary? Thoughts?
            gcode: https://pastebin.com/x4nu19ah
            inner perimeter speed: 75mm/s
            outer perimeter speed: 30mm/s
            0.15 pressure advance on both:
            0.08 on inner, 0.15 on outer:
              deckingman
              @nyt
              Good work.
              I've done quite a bit of testing with pressure advance but only at high speeds so what you've discovered is useful. Link to my blog here. https://somei3deas.wordpress.com/2018/01/15/an-attempt-to-investigate-pressure-in-the-extrusion-system-with-a-diamond-hot-end/
              From that testing, it appeared that pressure increases as print speed is increased but only up to a point, and thereafter seems to remain fairly constant. i.e. pressure increases up to a certain speed and further increasing the speed does not further increase the pressure. That is of course a somewhat subjective statement based on empirical observation - we'd need to fit a transducer of some sort to be able confirm that. However, it does seem likely.
              So my suggestion would be that if we introduce an exponential variable to increase pressure advance with speed, then we also need to add a maximum speed limit beyond which the pressure advance remains constant. Or conversely, set the maximum pressure advance but introduce a tapering effect so that pressure advance is applied in the range zero to maximum over a print speed range of zero to some threshold value. (not sure if I explained that well).
              • nytundefined
                nyt
                @deckingman:
                @nyt
                Good work.
                Interesting. I wasn't sure it was remaining constant beyond a certain speed, just that less was required as speed increased It would be awesome to be able to graph this with a pressure sensor, but that's more effort then I can see spending on this. In this case, I'd use the variable to limit pressure advance as speed increases, with a value less than 1.
                In the end, I just want to see it working reliably…. Using a factor of 10 and an exponent of 0.3 would get pretty close, for example using the speeds above...
                The PA value would be multiplied by this...
                10 * ( 75 ** 0.3 / 75 ) => 0.48691944197021614
                10 * ( 30 ** 0.3 / 30 ) => 0.9247303715573938
                  deckingman
                  I wasn't aware of the behaviour at low speeds, as I hadn't tested so well done for that.
                  My tests went up to 300mm/sec (which is possible by using a 3 or 5 melt chambers and extruders and a Diamond hot end) so that's probably why you won't have been aware of the behaviour at high speeds. I agree about the pressure sensor (mentioned that very fact in my blog).
                  What is also important is that different nozzles and hot ends have different characteristics. As a general rule, the pressure builds up more with a smaller nozzle than a larger one. The values you used above might work for your particular setup but other configurations might need different values, So any modifiers to the algorithm such as the exponential term or boundary limits ought to be configurable by the user rather than hard coded, fixed values.
                  We're on the same page though. Over to DC to see what he can come up with…..
                  • nytundefined
                    nyt
                    @dc42:
                    Any thoughts on the above posts?
                    Cheers
                    • 3D_lowundefined
                      3D_low
                      I was configuring my pressure advance and ran into the same conclusion. Of course I understand that pressure advance is not perfect but I’d be curious to see the mechanics behind it.
                      It is indeed a matter of speed + total length that will determine how much the pressure builds up
                      • vpundefined
                        vp
                        just my opinion:
                        1. At 0.4 mm nozzle width, 30 and 75 mm/s at 0.2 mm layer height is "no speed" for a volcano, 0.6 at 20 and 60 mm/s also not, the pressure build up difference should not be that impressive (only if you print e.g. PETG at 200 °C….) - at which temperature and with which filament did you try ?
                        In which direction did the print head move on the 20/60 mm/s picture ?
                        2. For me it looks like "skipping steps/increased filament slippage" because of too high E jerk when accelerating. What happens if you lower the E jerk (besides that it might slow down your print speed) ? What kind of extruder do you use ?
                        There is a firmware suggestion, to be able to have different jerk settings for acceleration and deceleration, but it was not implemented. The problem is, that pressure advance can use the max + E jerk possible to push filament in the nozzle, but the viscose damping effect adds an additional force to speed changes. If your extruder cannot handle this, you get more filament slippage and extrude less - it even can be that you would be able to extrude more material without pressure advance (==lower pressure advance values), because pressure advance uses high E jerks and by that amplifies the problem/slippage. Once your filament slippage is too high, the material is lost - underextrusion happens.
                        In case the firmware would support different setting for +- jerk (and acceleration), this problem could be overcome. Retraction can be done much much faster than extruding - without any additional slippage.
                        What also happens is, that the viscosity adds a phase shift (time lag) between the extruder moves and the real filament moves at the nozzle tip. All though pressure advance is not desgined for, by the way it works, a part fo this phase shift is compensated. But not all, the phase shift compensation would have to be adjusted with speed. So at the time being pressure advance cannot work perfectly.
                        Adjusting the pressure advance settings with speed is in my opinion the wrong way, it doesn´t solve the root problem. The root problem is very likely filament slippage caused by too high jerk/acceleration when accelerating.
                        3. Try to increase the temperature and test again to see if the pressure build up is really that important. At higher temperature the viscosity will go down and by that the viscose speed related damping effect will be smaller. In other works, E jerk has a better chance to work.... or tighten your extruder gear if possible, but over tighten it and deforming the filament too much will show the opposite effect.
                        5. The inner (fast) lines are not as wide as the outer (slow) ones. Before you start to use pressure advance, you should correct the extrusion multiplier according to extrusion rate using M952. M952 will increase the extrusion rate even more when "jerking" with pressure advance and by that probably not help your problem, but at least the fast and slow straight parts are OK. But maybe it helps, because M952 compensates the extrusion rate correlated slippage as far as it is not too high.
                        6. A Ruby nozzle might not be a good reference. Afaik it has no real chamfer at the inner side of he tip and by that gives unnecessary pressure build up and maybe other fancy behavior. But for sure it you want to use it, you want to optimize it. But what you found out is maybe not that much relevant for other nozzles - but this could be clarified easily by testing other nozzles.
                        I am used to print at high speeds/accelerations/jerks and and pressure advance has no value for me, because if you use high accelerations (> 1g) there are anyhow no bleeding edges and i would have to lower the E-jerk to get pressure advance working - and by that i would not print fast anymore - so i don´t use it. But i did try to improve retracts with pressure advance (but it doesn´t help).
                          deckingman
                          @vp:
                          I am used to print at high speeds/accelerations/jerks and and pressure advance has no value for me, because if you use high accelerations (> 1g) ..................
                          Congratulations. Most of us mere mortals can't print with satisfactory quality with accelerations and jerk settings in excess of 9807mm/s^2 so for us, pressure build up is a real problem.
                          • nytundefined
                            nyt
                            @vp:
                            just my opinion:
                            Volcano hot ends require more pressure advance as there's a longer melt zone.
                            @vp:
                            counter clockwise
                            @vp:
                            no steps are being skipped. These are 1.7a motors with titan extruders. No signs of skipped steps anywhere, even at much higher speeds and flow rates.
                            @vp:
                            This is just not correct. The same trouble is visible with minimal jerk and acceleration.
                            @vp:
                            3. Try to increase the temperature and test again to see if the pressure build up is really that important. At higher temperature the viscosity will go down and by that the viscose speed related damping effect will be smaller. In other works, E jerk has a better chance to work…. or tighten your extruder gear if possible, but over tighten it and deforming the filament too much will show the opposite effect.
                            That was PLA printed at 245C. That's pushing it already. The thermistor has been validated accurate as well by external probes, and the tests provided are on two entirely different hot ends/extruders.
                            @vp:
                            Extrusion is consistent between inner and outer layers.
                            @vp:
                            you're just guessing here, and again, that's not accurate. At least not for the Olsson model.
                            @vp:
                            That's great, but this printer, and many others, cannot run high acceleration. Even with high acceleration, you'll still have issues with oozing during moves and lack of filament at line starts when pressure advance is required.
                            This post wasn't really constructive. The point is, pressure does not build linearly, and having other variables to control it based on speed would be nice.
                              This would be an interesting topic for research. If a university would like to have a student do an MSc project or similar on it then I expect we could provide a Duet. But at the current stage in our software development cycle (preparing version 1.21 for release), I can't work on it at present.
                              • nytundefined
                                nyt
                                guess ill setup a build environment and start messing with it. if i get any positive results ill submit a pull request.
                                the new linear advance in marlin is interesting, as its based on length of filament compressed.
                                  @nyt:
                                  Marlin linear advance is the same algorithm that RepRapFirmware uses; but Marlin implemented it 2 yards later, and the Marlin implementation makes some approximations because it doesn't do precise acceleration.
                                  • nytundefined
                                    nyt
                                    @dc42:
                                    @nyt:
                                    Did you see the new v1.5 code? They just changed it up
                                    https://github.com/Sebastianv650/Marlin/commits/LIN_ADV_v1.5_final_1.1.x
                                    • vpundefined
                                      vp
                                      it is just my opinion, but i think you missed the point. "missing steps" doesn´t mean only that your stepper misses some steps, it also can mean that the filament slips too much at the extruder gear. When your extruder is pushing hard, the additional E-Jerk introduced by pressure advance can easily overcome the maximum force the extruder gear can handle.
                                      No, only at very low extrusion rates and the difference is not that big to e.g. a e3d v6. If somebody uses a volcano, then normally not to operate in the low extrusion rate area. If a volcano would provide more back pressure at higher extrusion rates, nobody would use it…..
                                      See above. The filament is slipping. I use bondtech extruders with 2.2 A, but that doesn´t mean that the filament is not slipping….
                                      In the last appr. half year i have tested > 100 (that is no joke) combinations of nozzles, extruders, and filaments. If you print PLA with 245 °C with a 0.4 at 75/30 mm/s and you see that big difference using a volcano nozzle, your nozzle is really given an extraordinary big amount of back pressure.
                                      The faster lines are smaller than the slow ones - as far as i can judge. This would be normal when the speed difference would be higher and could be compensated by M592.
                                      That is correct, i don´t really know it, but you will find discussions on youtube and on the web about this issue. The data you have provided shows clearly, that you have a lot of back pressure even at low extrusion rates.
                                      I just wanted to point out, that i did experiment a lot with pressure advance. But because of the E-jerk slipping problem, it is not usable for me.
                                      I cannot reproduce what you have shown and i did play a lot with pressure advance, that´s all. I don´t have any problem at all if an additional tuning parameter is introduced, nobody is forced to use it, but these posts might be useful for others, to maybe find the root cause.
                                        deckingman
                                        @nyt\dc42
                                        I haven't tested the latest firmware but one of the biggest issues for me is the behaviour of pressure advance during segmented arcs. Before I went on my 5 week trip "down under" there was an issue with the print head slowing or stopping with high pressure advance when printing circles. IIRC it had something to do with the slicer generating unequal segments which then triggered the Duet pressure advance algorithm. The version of firmware at that time was more sensitive to those unequal segments than previous versions. I need to update the firmware to see if David has managed to "de-sensitise" it.
                                        With multiple extruders, the situation is much worse. I've been trying to get it to work ever since David first introduced it but always have issues doing arcs. It's a real shame because for high speed printing with multiple extruders, it really works well but only with linear moves - segmented arcs have always been a problem for me.
                                        I'm leaning towards the impression that maybe pressure advance has to be implemented in the slicer rather than firmware. The slicer would "know" where an arc is, whereas firmware only "sees" short moves and doesn't look ahead to determine if a series of small moves constitute an arc. David will no doubt correct me if that conjecture has any basis.
                                        I've read that there is a version of Slic3r (Prusa Edition) which implements some form of pressure advance. When I get time, I plan to give that a go.
                                        • burtoogleundefined
                                          burtoogle
                                          I can't contribute to the main topic of this thread as I do not use pressure advance, however…
                                          I am using M592 and can verify that (for a v6 with 0.4mm nozzle, PLA), it makes a real difference. Before, I was seeing between 5 and 10% underextrusion at higher print speeds. So if you are not using M592 and have calibrated your extruder at a low extrusion rate, it's almost guaranteed that it will be underextruding at higher extrusion rates.
                                          Edit: I forgot to mention that I am using a Titan extruder.
                                            PS - it would be really helpful if someone could generate some GCode files for calibrating pressure advance. The test pattern could be linear line segments with speed changes in them, or 90 degree angles. Several layers should be printed to avoid first layer adhesion issues.
                                            If the test pattern is printed as a grid, then the pressure advance can be varied along one axis and the speed along the other. That should provide a good visual indication of how pressure advance should be changed with speed, giving me a basis on which to implement nonlinear pressure advance.
                                            As most users of Cartesian and CoreXY printers choose the origin to be at one corner of the bed instead of the middle, test patterns should be provided for both delta printers and Cartesian/CoreXY, or a single test pattern provided that assumes the origin is at the centre but that has an adjustable tool offset at the start.
