    My duetwifi seems to have died :(
    3.0k
    • gzcwnkundefined
      gzcwnk
      Ok found that….installed it to /sys.
      SENDING:M997 S1
      Trying to connect at 230400 baud:
      success
      Erasing 4096 bytes...
      Erasing 233472 bytes...
      Uploading file...
      5% complete
      10% complete
      15% complete
      20% complete
      25% complete
      30% complete
      35% complete
      40% complete
      45% complete
      50% complete
      55% complete
      60% complete
      65% complete
      70% complete
      75% complete
      80% complete
      85% complete
      90% complete
      95% complete
      Upload successful
        Before trying to update the firmware on maybe not working hardware try disabling and reenabling the wifi module.
        M552 S0
        M552 S1
        What does m552 return in pronterface?
          Well at least it was successful? 😕
          • gzcwnkundefined
            gzcwnk
            m115
            SENDING:M115
            FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-12-23
            M587 S"24G" P"mypassword" never returns. Nothing on wifi router.
            Trying to set up the wifi and no workie
              There are pretty specific steps for upgrading to 1.20 from an older firmware. It's a bit of a change from previous updates. Did you follow those steps?
              • gzcwnkundefined
                gzcwnk
                Ok when I send the above it switches my password to uppercase by the look of it. M552 S1 says wrong password
                  https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_Installing_and_Updating_Firmware
                  https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Upgrading_to_DuetWiFiFirmware_1_Num_19
                  • gzcwnkundefined
                    gzcwnk
                    as far as I know.
                    • gzcwnkundefined
                      gzcwnk
                      Ok so this is a 3rd set of instructions!
                      • gzcwnkundefined
                        gzcwnk
                        OK so its all upper case so I need to find something else to send commands with
                        • gzcwnkundefined
                          gzcwnk
                          M98 P/macros/SetNetwork
                          Warning: Macro file /macros/SetNetwork not found.<lf>ok<lf>Warning: Macro file /macros/SetNetwork not found.<lf>ok <lf>hmmm something wrong here…</lf></lf></lf></lf>
                          • gzcwnkundefined
                            gzcwnk
                            M552 S1
                            ok<lf>WiFi module started <lf>M587
                            Remembered networks:<lf>24G IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>24G_IOT IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle <lf>?
                            It can see 24G so wifi hardware must be OK?
                            I know the password is correct.</lf></lf></lf></lf></lf></lf></lf></lf>
                            • gzcwnkundefined
                              gzcwnk
                              M587 S"G24" P"xxxxxxx"
                              M587: Failed to add SSID to remembered list<lf>ok <lf>?</lf></lf>
                              • gzcwnkundefined
                                gzcwnk
                                OK I am failing to get an IP address.
                                • gzcwnkundefined
                                  gzcwnk
                                  (COM7) Remembered networks:<lf>24G IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>24G_IOT IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>G24 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle</lf></lf></lf></lf></lf></lf>
                                  • gzcwnkundefined
                                    gzcwnk
                                    OK I tried a new network,
                                    (COM7) M587 S"G24_IoT" P"stevenjones"
                                    (COM7) ok <lf>(COM7) M552 S1
                                    (COM7) ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle <lf>I cant see it being a wrong password!</lf></lf></lf></lf>
                                      1. How are you sending the M587 command? If you are using Pronterface or a similar USB host program, it is probably converting the characters in the password to uppercase.
                                      2. Check that your router encryption is set to WPA2-PSK.
                                      • gzcwnkundefined
                                        gzcwnk
                                        (COM7) M122
                                        (COM7) === Diagnostics ===<lf>Used output buffers: 1 of 32 (1 max)<lf>=== Platform ===<lf>RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0<lf>Board ID: 08DAM-999TL-MQ4S4-6JTDG-3S86M-T5GRZ<lf>Static ram used: 15448<lf>Dynamic ram used: 98720<lf>Recycled dynamic ram: 520<lf>Stack ram used: 3576 current, 4896 maximum<lf>Never used ram: 11488<lf>Last reset 00:23:17 ago, cause: power up<lf>Last software reset details not available<lf>Error status: 0<lf>Free file entries: 10<lf>SD card 0 detected, interface speed: 20.0MBytes/sec<lf>SD card longest block write time: 0.0ms<lf>MCU temperature: min 29.4, current 37.7, max 38.0<lf>Supply voltage: min 0.1, current 1.1, max 1.2, under voltage events: 0, over voltage events: 0<lf>Driver 0: ok, SG min/max not available<lf>Driver 1: ok, SG min/max not available<lf>Driver 2: ok, SG min/max not available<lf>Driver 3: ok, SG min/max not available<lf>Driver 4: ok, SG min/max not available<lf>Date/time: 1970-01-01 00:00:00<lf>Cache data hit count 1617411415<lf>Slowest main loop (seconds): 0.099954; fastest: 0.000035<lf>==<warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.=""></warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf>
                                        • gzcwnkundefined
                                          gzcwnk
                                          Ok lets flash back to 1.19.2.
                                          (COM8) M997 S0
                                          (COM8) RepRapFirmware for Duet WiFi Version 1.19.2 dated 2017-09-01<lf><lf>Executing config.g…Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 651C.<lf><lf>Done!<lf>RepRapFirmware for Duet WiFi is up and running.<lf>WiFi module started<lf>WiFi reported error: Wrong password while tryi
                                          and,
                                          (COM8) Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload successful<lf>ok<lf>Trying to connect at 460800 baud: success<lf>Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload successful<lf>ok<lf>Trying to connect at 460800 baud: success<lf>Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload s <warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.="">(COM8) M115
                                          (COM8) Trying to connect at 460800 baud: success<lf>Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload successful<lf>ok<lf>FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19.2 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-09-01<lf>ok <lf>(COM8) M115
                                          (COM8) FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19.2 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-09-01<lf>ok</lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf>
                                          • gzcwnkundefined
                                            gzcwnk
                                            (COM8) M122
                                            (COM8) === Diagnostics ===<lf>Used output buffers: 1 of 32 (2 max)<lf>=== Platform ===<lf>RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0<lf>Board ID: 08DAM-999TL-MQ4S4-6JTDG-3S86M-T5GRZ<lf>Static ram used: 21176<lf>Dynamic ram used: 95768<lf>Recycled dynamic ram: 1840<lf>Stack ram used: 4048 current, 5116 maximum<lf>Never used ram: 7172<lf>Last reset 00:04:20 ago, cause: software<lf>Last software reset reason: not available<lf>Error status: 1<lf>Free file entries: 10<lf>SD card 0 detected, interface speed: 20.0MBytes/sec<lf>SD card longest block write time: 0.0ms<lf>MCU temperature: min 35.4, current 37.2, max 38.1<lf>Supply voltage: min 1.0, current 1.1, max 1.2, under voltage events: 0, over voltage events: 0<lf>Driver 0: ok<lf>Driver 1: ok<lf>Driver 2: ok<lf>Driver 3: ok<lf>Driver 4: ok<lf>Date/time: 1970-01-01 00:00:00<lf>Slowest main loop (seconds): 1.965744; fastest: 0.000031<lf>=== Move ===<lf>MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0<lf>Scheduled moves: 0, completed moves: 0<lf>Bed compensation in use:<warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.=""></warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf>
