My duetwifi seems to have died :(
3.0k
    gzcwnk
    m115
    SENDING:M115
    FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-12-23
    M587 S"24G" P"mypassword" never returns. Nothing on wifi router.
    Trying to set up the wifi and no workie
      There are pretty specific steps for upgrading to 1.20 from an older firmware. It's a bit of a change from previous updates. Did you follow those steps?
        gzcwnk
        Ok when I send the above it switches my password to uppercase by the look of it. M552 S1 says wrong password
          https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_Installing_and_Updating_Firmware
          https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Upgrading_to_DuetWiFiFirmware_1_Num_19
            gzcwnk
            as far as I know.
              gzcwnk
              Ok so this is a 3rd set of instructions!
                gzcwnk
                OK so its all upper case so I need to find something else to send commands with
                  gzcwnk
                  M98 P/macros/SetNetwork
                  Warning: Macro file /macros/SetNetwork not found.<lf>ok<lf>Warning: Macro file /macros/SetNetwork not found.<lf>ok <lf>hmmm something wrong here…</lf></lf></lf></lf>
                    gzcwnk
                    M552 S1
                    ok<lf>WiFi module started <lf>M587
                    Remembered networks:<lf>24G IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>24G_IOT IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle <lf>?
                    It can see 24G so wifi hardware must be OK?
                    I know the password is correct.</lf></lf></lf></lf></lf></lf></lf></lf>
                      gzcwnk
                      M587 S"G24" P"xxxxxxx"
                      M587: Failed to add SSID to remembered list<lf>ok <lf>?</lf></lf>
                        gzcwnk
                        OK I am failing to get an IP address.
                          gzcwnk
                          (COM7) Remembered networks:<lf>24G IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>24G_IOT IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>G24 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle</lf></lf></lf></lf></lf></lf>
                            gzcwnk
                            OK I tried a new network,
                            (COM7) M587 S"G24_IoT" P"stevenjones"
                            (COM7) ok <lf>(COM7) M552 S1
                            (COM7) ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle <lf>I cant see it being a wrong password!</lf></lf></lf></lf>
                              1. How are you sending the M587 command? If you are using Pronterface or a similar USB host program, it is probably converting the characters in the password to uppercase.
                              2. Check that your router encryption is set to WPA2-PSK.
                                gzcwnk
                                (COM7) M122
                                (COM7) === Diagnostics ===<lf>Used output buffers: 1 of 32 (1 max)<lf>=== Platform ===<lf>RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0<lf>Board ID: 08DAM-999TL-MQ4S4-6JTDG-3S86M-T5GRZ<lf>Static ram used: 15448<lf>Dynamic ram used: 98720<lf>Recycled dynamic ram: 520<lf>Stack ram used: 3576 current, 4896 maximum<lf>Never used ram: 11488<lf>Last reset 00:23:17 ago, cause: power up<lf>Last software reset details not available<lf>Error status: 0<lf>Free file entries: 10<lf>SD card 0 detected, interface speed: 20.0MBytes/sec<lf>SD card longest block write time: 0.0ms<lf>MCU temperature: min 29.4, current 37.7, max 38.0<lf>Supply voltage: min 0.1, current 1.1, max 1.2, under voltage events: 0, over voltage events: 0<lf>Driver 0: ok, SG min/max not available<lf>Driver 1: ok, SG min/max not available<lf>Driver 2: ok, SG min/max not available<lf>Driver 3: ok, SG min/max not available<lf>Driver 4: ok, SG min/max not available<lf>Date/time: 1970-01-01 00:00:00<lf>Cache data hit count 1617411415<lf>Slowest main loop (seconds): 0.099954; fastest: 0.000035<lf>==<warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.=""></warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf>
                                  gzcwnk
                                  Ok lets flash back to 1.19.2.
                                  (COM8) M997 S0
                                  (COM8) RepRapFirmware for Duet WiFi Version 1.19.2 dated 2017-09-01<lf><lf>Executing config.g…Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 651C.<lf><lf>Done!<lf>RepRapFirmware for Duet WiFi is up and running.<lf>WiFi module started<lf>WiFi reported error: Wrong password while tryi
                                  and,
                                  (COM8) Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload successful<lf>ok<lf>Trying to connect at 460800 baud: success<lf>Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload successful<lf>ok<lf>Trying to connect at 460800 baud: success<lf>Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload s <warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.="">(COM8) M115
                                  (COM8) Trying to connect at 460800 baud: success<lf>Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload successful<lf>ok<lf>FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19.2 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-09-01<lf>ok <lf>(COM8) M115
                                  (COM8) FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19.2 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-09-01<lf>ok</lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf>
                                    gzcwnk
                                    (COM8) M122
                                    (COM8) === Diagnostics ===<lf>Used output buffers: 1 of 32 (2 max)<lf>=== Platform ===<lf>RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0<lf>Board ID: 08DAM-999TL-MQ4S4-6JTDG-3S86M-T5GRZ<lf>Static ram used: 21176<lf>Dynamic ram used: 95768<lf>Recycled dynamic ram: 1840<lf>Stack ram used: 4048 current, 5116 maximum<lf>Never used ram: 7172<lf>Last reset 00:04:20 ago, cause: software<lf>Last software reset reason: not available<lf>Error status: 1<lf>Free file entries: 10<lf>SD card 0 detected, interface speed: 20.0MBytes/sec<lf>SD card longest block write time: 0.0ms<lf>MCU temperature: min 35.4, current 37.2, max 38.1<lf>Supply voltage: min 1.0, current 1.1, max 1.2, under voltage events: 0, over voltage events: 0<lf>Driver 0: ok<lf>Driver 1: ok<lf>Driver 2: ok<lf>Driver 3: ok<lf>Driver 4: ok<lf>Date/time: 1970-01-01 00:00:00<lf>Slowest main loop (seconds): 1.965744; fastest: 0.000031<lf>=== Move ===<lf>MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0<lf>Scheduled moves: 0, completed moves: 0<lf>Bed compensation in use:<warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.=""></warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf>
                                      gzcwnk
                                      (COM7) M552 S1
                                      (COM7) ok <lf>(COM7) M587
                                      (COM7) Remembered networks:<lf>24G<lf>24G_IOT<lf>G24<lf>G24_IoT<lf>ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle</lf></lf></lf></lf></lf></lf></lf></lf>
                                        gzcwnk
                                        OK finally worked, well I have an IP…
                                          gzcwnk
                                          Ok I am on 1.19.2 I am calling it quits, web ui works. My next one might just be a duetethernet.
                                          18 out of 31
