    Dual Z-axis endstops
    89
    20.1k
    • SpeedyDadundefined
      SpeedyDad
      I think it was the steps
        Bear in mind that in firmware 1.19beta10, an alternative to using dual Z endstops now is to use auto bed levelling to adjust your 2 leadscrews independently to get the bed level after homing.
        • kazolarundefined
          kazolar
          I am considering using my 2 lead screws independently also, since I can add driver 12 to the LCD connector.
          Your example shows assigning U axis to an unconnected driver, which in my case there will be none. So how would I configure dual lead screw (don't have auto bed leveling setup yet – I will add that in after I get the basics configured)
          This is what I have now:
          M584 X0 Y1 U2 V3 W4 A5 E6:7:8:9 Z10
          so if I were to add 11 it would change to
          M584 X0 Y1 U2 V3 W4 A5 E6:7:8:9 Z10:11 then presumably I would define B somehow? would be also 11?
          I can remap other axis to -- as in U etc kinda like this:
          M584 X0 Y1 V2 W3 A4 B5 E6:7:8:9 Z10:11 -- then I have U freed up as a limit switch on the primary duet as apposed to the expansion board, though I haven't notice any performance difference with 19.11 support for end stops on the expansion board.
          Being that I have a large bed and there is the ability to add the 12th driver -- I can drop in another TB6600 and run my 2 lead screws independently.
            The recommended approach now is to use a Z probe and to drive the multiple Z leadscrews independently during bed levelling only. However, you could use the old approach of dual endstop switches instead if you want, but in your case use the B axis for the second Z leadscrew instead of U. Then you can use the M584 P parameter to hide the B axis.
            • kazolarundefined
              kazolar
              @dc42:
              I have different bed leveling options I will be trying once I have a bed πŸ™‚ I need to prep the PEI sheet with the automotive paint before I adhere it to the boro glass, that is on my queue for next week. I ordered the second TB6600 and will be setting it up for now to use the old method with 2 limit switches as you said, so I'm assuming
              The correct option for me is
              M584 X0 Y1 U2 V3 W4 A5 E6:7:8:9 Z10:11 B11 P7
              M574 X1 Y1 Z1 U2 V2 W1 A2 B1 S1
              then my homez.g would be
              G91
              M584 Z10 B11
              G1 S1 Zxxx Bxxx
              G92 Zxxx
              M584 Z10:11
              G90
              So I can't really "hide" or prevent inadvertent moves of the B axis – since at the end of the Z homing it still assigned to 11 (which I suppose isn't critical as no standard gcode contains G1 B commands)
              • Amiliousundefined
                Amilious
                Question on this. Can I use my bl touch instead of endstops? I have the endstops but would rather not use if i do not have to. Can we use the Z probe for both Z and U. For example, home the bed, with bl touch this would leave space between nozzle and the bed. Then move the head to the other side of the build platform and use only the U motor to move until probe is triggered again.
                  @kazolar:
                  G91
                  M584 Z10 B11
                  G1 S1 Zxxx Bxxx
                  G92 Zxxx
                  M584 Z10:11
                  G90
                  You can hide the B axis at the end of homing by adding P8 to the first M584 command and P7 to the second. The B axis will appear during Z homing but will be hidden afterwards.
                    @Amilious:
                    Use the bltouch to home Z at bed centre as normal, then use the multiple leadscrew bed levelling facility described at https://duet3d.com/wiki/Bed_levelling_using_multiple_independent_Z_motors.
                    • j3dkundefined
                      j3dk
                      I have have an FT-5 and want to split my Z axis when homing, my Home Z.g looks like this:
                      ; homez.g
                      ; called to home the Z axis
                      ; generated by Jens Kej on Sun Mar 11 2018 15.00
                      G91 ; relative mode
                      G1 Z4 F200 ; raise head 4mm to ensure it is above the switch trigger height
                      G90 ; back to absolute mode
                      G1 X-305 Y-305 F1800 S1; move XY home
                      G1 X150 Y150 F2000 ; put the head to be centered when you home Z
                      G91 ; relative mode
                      M584 Z2 U3 ; split Z axis in two
                      G1 Z-400 U-400 S1 F100 ; home the Z- and U axis
                      G92 Z0.1 ; tell the software that it 0,1 mm above bed
                      M584 Z2:3 ; make One Z axis again
                      the bed is moving fine up and down from web interface but only the Z axis is trying move when I push home Z, why?
                      Jk
                        Please post your config.g file.
                        • j3dkundefined
                          j3dk
                          @j3dk:
                          ; homez.g
                          G91 ; relative mode
                          G91 ; relative mode
                          here comes my config.g:
                          ; Configuration file for Duet WiFi (firmware version 1.17)
                          ; generated by Jens Kej on Thu Sep 21 2017 17:16:32 GMT+0200 (Rom, sommertid)
                          M111 S0 ; Debugging off
                          G21 ; Work in millimetres
                          G90 ; Send absolute coordinates…
                          M555 P2 ; Set firmware compatibility to look like Marlin
                          M208 X300 Y300 Z350 S0 ; Set axis maxima
                          ;M574 Z1 S1 ; Define Hall sensor active high on Z-axis
                          M574 X1 Y1 Z1 U1 S0 ; Define active low and unused microswitches
                          :M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                          ;G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                          ;M557 X15:285 Y15:285 S20 ; Define mesh grid
                          M569 P0 S0 ; Drive 0 goes backwards
                          M569 P3 S0 ; Drive 3 goes backwards
                          M569 P5 S1 ; Drive 5 goes forwards
                          M569 P6 S1 ; Drive 6 goes forwards
                          M584 X0 Y1 Z2:3 U3 E4:5:6 P3; Apply custom drive mapping
                          M350 X16 Y16 Z16 U16 E16:16:16 I1 ; Configure microstepping with interpolation
                          M92 X80 Y80 Z400 U400 E100πŸ’―100 ; Set steps per mm
                          M566 X900 Y900 Z12 U12 E120:120:120 ; Set maximum instantaneous speed changes (mm/min)
                          M203 X6000 Y6000 Z1000 U1000 E1200:1200:1200 ; Set maximum speeds (mm/min)
                          M201 X500 Y500 Z250 U250 E250:250:250 ; Set accelerations (mm/s^2)
                          M906 X800 Y800 Z800 U800 E800:800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M143 S260 ; Set maximum heater temperature to 260C
                          M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                          ;M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                          M305 P1 x151 ; Thermocouple
                          M307 H1 A626.6 C265.6 D13.9 ; hotend pid settings
                          M563 P0 D0 H1 ; Define tool 0
                          M563 P1 D1 H1 ; Define tool 1
                          G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
                          G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                          M563 P2 D2 H1 ; Define tool 2
                          G10 P2 X0 Y0 Z0 ; Set tool 2 axis offsets
                          G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
                          M550 PFT-5 DD ; Set machine name
                          M552 S1 ; Enable network
                          M587 Sfarce95taske53lufffe P"be81b0f702d6d23152c28d870e" ; Configure access point. You can delete this line once connected
                          M586 P0 S1 ; Enable HTTP
                          M586 P1 S0 ; Disable FTP
                          M586 P2 S0 ; Disable Telnet
                          M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M501 ;Load overide config.g
                          Jk
                            Your two M208 commands need to be moved to be after the M584 command, and you need to add U axis values to them.
                            • j3dkundefined
                              j3dk
                              @dc42:
                              I made something very wrong, messed it all up and had to put new configuration files on the SD-Card. Then I started all over again from scratch. Now my config.g and homez.g looks like this, much better structured, without unused comands etc. but the problem still remains the same:
                              ; config.g Dual Z-axis
                              ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
                              ; generated by RepRapFirmware Configuration Tool on Mon Mar 19 2018 17:18:48 GMT+0100 (Rom, normaltid)
                              ; Edited by J. Kej on Mon Mar 19 2018 20:58:48 GMT+0100 (Rom, normaltid)
                              M550 PJK'S FT-5 DD ; Set machine name
                              M587 S"farce95taske53lufe" P"be81b0f702d6d23152c28d870e" ; Configure access point.
                              M586 P1 S1 ; Enable FTP
                              M586 P2 S1 ; Enable Telnet
                              M584 X0 Y1 Z2:3 U3 E4:5:6 P3 ; Configure drive remapping to dual Z-axis
                              M350 X16 Y16 Z16 U16 E16:16:16 I0 ; Configure microstepping without interpolation
                              M203 X6000 Y6000 Z1800 U1800 E1200:1200:1200 ; Set maximum speeds (mm/min)
                              M208 X0 Y0 Z0 U1 S1 ; Set axis minima
                              M208 X300 Y300 Z350 U350 S0 ; Set axis maxima
                              M574 X1 Y1 Z1 U1 S0 ; Set active low endstops
                              M558 P0 H3 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
                              M305 P1 X151 ; Configure thermocouple for heater 1
                              M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                              G10 P0 X0 Y0 Z0.1 ; Set tool 0 axis offsets
                              G10 P1 X0 Y0 Z0.1 ; Set tool 1 axis offsets
                              G10 P2 X0 Y0 Z0.1 ; Set tool 2 axis offsets
                              M563 P3 D0:1:2 H1 ; Define tool 3
                              G10 P3 X0 Y0 Z0.1 ; Set tool 3 axis offsets
                              G10 P3 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
                              M568 P3 S1 ; Enable mixing for tool 3
                              M567 P3 E0.33:0.33:0.34 ; Set mixing ratios for tool 3
                              ; Custom settings
                              ; homez.g
                              ; generated by RepRapFirmware Configured for Dual Z-axis by J. Kej on Mon Mar 19 2018 20:18:47 GMT+0100 (Rom, normaltid)
                              M584 Z2 U3 P3
                              G1 S1 Z-355 U-355
                              G92 Z0.1
                              M584 Z2:3 P3
                              Jk
                                Have you tested the U endstop switch? Perhaps it is showing as already triggered. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches.
                                • j3dkundefined
                                  j3dk
                                  @j3dk:
                                  @dc42:
                                  ; Custom settings
                                  ; homez.g
                                  M584 Z2 U3 P3
                                  G1 S1 Z-355 U-355
                                  G92 Z0.1
                                  M584 Z2:3 P3
                                  Endstop Z and U are working properly, led's on board lights up when i hit them with my finger. That's not the issue…...
                                  Jk
                                    Can you see the U endstop working in the Duet Web Control Machine Properties page? The LED is not always a reliable indication.
                                    • j3dkundefined
                                      j3dk
                                      @dc42:
                                      Found out that U endstop is not working and it seems like it is a problem related to my Duet WiFi board as I have tested/measured all wires, connectors and endstops, yhey are all ok.
                                      Then I have tried to move the plug from my working Z stop to the U connector on the board but when I turn it on again and go to Machine Properties page nothing works.
                                      Now I also have tried to move the stepper and endstop for my U axis to E4 on my duex5 and remap U in my confiig.g and homez.g but I still had the same problem.
                                      Have tested all my endstops and they work properly on the XYZ axis. On all other they seem to work the oposite way in the machine properties page. Reported as hit and change from Yes to No when I hit them manually, Whats wrong then?
                                      Jk
                                        1. If you are running firmware 1.21RC5 then it's normal for endstops that are set to active low to read the wrong way round. That's fixed in the 1.21 release.
                                        2. Are you using microswitches, or some other type of endstop?
                                        3. Please run M574 without parameters, and check that the U endstop is reported as being configured the same way as XYZ.
                                        • j3dkundefined
                                          j3dk
                                          1. Now I have updated my Firmware to ver. 1.21 and now all my declared endstops works, but still no readings of minimum and maximum for drive 3 aka U axis.
                                          2. I use standard Makerbot Mechanical endstops ver. 1.2
                                          3. M574 returns: Endstop configuration: X: low end active low switch, Y: low end active low switch, Z: low end active low switch, U: low end active low switch,
                                          Now when I try to move Z up and down I get a red popup like this:
                                          M120
                                          G91
                                          G1 Z-1 F6000
                                          M121
                                          Error: G0/G1: insufficient axes homed
                                          Error: Pop(): stack underflow!
                                          homez still don't work
                                          What's next?
                                          Jk
                                            Read the release notes for firmware 1.21.
