    RepRapFirmware 2.0 with RTOS in development
    Firmware installation
    18
    58
    9.4k
      I've just released another 2.0 alpha. The two bugs in the previous release (crash if you tune a heater, and DWC disconnecting after a while if a PanelDue is also connected) are believed fixed. Nevertheless, I caution against using this release for doing long-running prints. The DWC disconnects were caused by printf in the GNU C library not being re-entrant if you use floating point formats. There may be other issues in the library with lack of reentrancy that I haven't mitigated yet.
      • cgcaferundefined
        cgcafer
        Hi David,
        This is the first run for me with RTOS, here you can find M122 result
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)alpha1 running on Duet WiFi 1.02 or later
        Board ID: 08DAM-9K9K2-NGNSN-6J9D6-3S46J-TPSMJ
        Used output buffers: 2 of 40 (31 max)
        Static ram: 28484
        Dynamic ram: 97188 of which 0 recycled
        Exception stack ram used: 384
        Never used ram: 5016
        Task NETWORK ready, free stack 316
        Task HEAT blocked, free stack 572
        Task MAIN running, free stack 3808
          Thanks, those figures look good, but let me know if you get any unexplained behaviour.
          • AS-3D Druckundefined
            AS-3D Druck
            Quick Question on this point.
            What exactly will change if you're done with Version 2.0?
            Is it just more compact or can it operate faster?
            Is it a performance jump like from Windows Vista to Windows 7? 😄
            Sry but i don't get it. 🙂
            Best regards
            AS-3D Druck / Andre
              The use of RTOS will make it much easier for us to implement some types of new feature. I hope it will also allow us to improve file upload speed a little.
              • Captain_squndefined
                Captain_sq
                @AS-3D:
                In short: More efficient use of the microcontrollers and development resources.
                Which means that you can do more things with the resources you have at your disposal without sacrificing performance. In plain english that means that you can add more features, speed up certain parts and shorten development times.
                For the developer a lot of things becomes easier as the abstraction level is significantly raised. Code becomes more robust as you don't have to twiddle around with low-level error prone code that often incurs limitations that makes the entire code base hard to maintain. Hunting for bugs becomes somewhat easier too.
                Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
                Embedded systems designer, RC Pilot, maker and Gadget-o-holic
                • mhackneyundefined
                  mhackney
                  Firmware Version: 2.0(RTOS)alpha1 (2018-04-05b2) installed on one of my Ultibots D300VS deltas. 1 print completed. Amazing progress David.
                  My 3D Printing blog: http://www.sublimelayers.com
                  Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
                  • whosrdaddyundefined
                    whosrdaddy
                    Completed 2 5 hour prints on 2.0 alpha without any issues, amazing stuff David!.
                    2 (minor) problems I found so far:
                    • sometimes the ESP8266 would not boot a power up (blue led won't light up) ( a power cycle solves this).
                    • DWC Disconnects at the end of an upload.
                    for reference:
                    WiFi Server Version: 1.21
                    Web Interface Version: 1.21.1-b1
                    Here is the last completed print on 2.0 alpha 🙂
                    • mhackneyundefined
                      mhackney
                      I've uploaded multiple files from DWC with no disconnects. I'll keep my eye open for this and if it happens, report back.
                      • timcurtis67undefined
                        timcurtis67
                        After updating to 2.0(RTOS)alpha1 (2018-04-03b2) I ran a few small test calibration cubes. Everything was working fine. On the third run I walked out of the room for a few minutes and came back to the printer frozen (not moving).
                        I reset the printer and ran an M122.
                        Here are the results
                        12:01:24 PMM122
                        Static ram used: 26196
                        Dynamic ram used: 95340
                        Recycled dynamic ram: 1344
                        Handler stack ram used: 324
                        Never used ram: 7868
                        Task NETWORK: state 0 stack rem 676
                        Task HEAT: state 2 stack rem 172
                        Task MAIN: state 1 stack rem 428
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)alpha1 running on Duet WiFi 1.0 or 1.01 + DueX5
                        Board ID: 08DAM-999TL-MQ4S4-6JKDA-3S06M-95HMY
                        Last reset 00:00:26 ago, cause: software
                        Last software reset at 2018-04-08 12:00, reason: User, spinning module GCodes, available RAM 7860 bytes (slot 1)
                        Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
                        Used output buffers: 8 of 32 (18 max)
                        Error status: 0
                        Free file entries: 10
                        SD card longest block write time: 0.0ms
                        MCU temperature: min 30.4, current 30.7, max 31.1
                        Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0
                        Driver 5: standstill, SG min/max not available
                        Driver 6: standstill, SG min/max not available
                        Driver 7: standstill, SG min/max not available
                        Expansion motor(s) stall indication: no
                        Date/time: 2018-04-08 12:01:23
                        Slowest main loop (seconds): 0.008095; fastest: 0.000070
                        MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                        Bed compensation in use: none
                        Heater 1 is on, I-accum = 0.0
                        Segments left: 0
                        Movement lock held by null
                        http is idle in state(s) 0
                        telnet is idle in state(s) 0
                        file is idle in state(s) 0
                        serial is idle in state(s) 0
                        aux is idle in state(s) 0
                        daemon is idle in state(s) 0
                        queue is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                        HTTP sessions: 1 of 8
                        • WiFi -
                          Network state is running
                          WiFi firmware version 1.21
                          WiFi MAC address 60:01:94:0c:4f:6d
                          WiFi Vcc 3.39, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 17192
                          WiFi IP address 10.0.0.137
                          WiFi signal strength -43dBm, reconnections 0, sleep mode modem
                          Socket states: 2 0 0 0 0 0 0 0
                          === Expansion ===
                          DueX I2C errors 0
                        Not sure what happened? Maybe something in here will help you?
                        Running DuetWifi IDEX (2 X carraiges) With these specs
                        Firmware Electronics: Duet WiFi 1.0 or 1.01 + DueX5
                        Firmware Version: 2.0(RTOS)alpha1 (2018-04-03b2)
                        Web Interface Version: 1.21-RC4
                          timcurtis67
                          I ran a few longer running prints without anymore freeze ups. Some web disconnects but zero issues with printing. The disconnects are new for me but not really an issue.
                          The firmware is working great so far.
                          Will there be a revised web interface to try out uploading files while printing? I tried it but the button is locked out in the current version I am running.
                            dc42 administrators @timcurtis67
                            @timcurtis67 said in RepRapFirmware 2.0 with RTOS in development:
                            I've asked chrishamm to look at doing this.
                              RRF 2.0beta 1 has now been released. Please post further comments and feedback in the thread I have created about that release, https://forum.duet3d.com/topic/4871/reprapfirmware-2-0beta1-available.
