    It's out! Firmware 1.21 released
    Firmware installation
    25
    73
    13.3k
    • alclonkyundefined
      alclonky
      Yes, thats what i am saying
      i can home X and Y first and when i home z it failes
      if i home all it homes X and Y and failes with z
        Odd. In your homez.g you have the S2 parameter on the G1 Z5 command, which is the change you needed to make to homez.g. Please double check that the homez.g file in /sys on the SD card really does have that parameter, and what you posted isn't a copy on the PC that didn't make it to the printer.
        The other possibility is that homing X or Y has failed. After you home X and Y, the X and Y homing buttons in DWC should be blue, and Z will still be orange because it hasn't been homed. Is that what you see?
        Bogey55undefined 1 Reply Last reply Reply Quote 0
        • alclonkyundefined
          alclonky
          yes after homing X and Y the buttons get blue
          i copied the files from the /sys folder on the SD
          ; homeall.g
          ; called to home all axes
          ; Relative positioning
          G91
          ; Lift Z
          G1 Z5 F6000 S2
          ; Course home X and Y
          G1 X-200 Y-210 F1800 S1
          ; Move away from the endstops
          G1 X5 Y5 F6000
          ; Fine home X and Y
          G1 X-200 Y-210 F360 S1
          ; Absolute positioning
          G90
          ; Go to first bed probe point and home Z
          G1 X0 Y0 F6000 S2
          G30
          ; homey.g
          ; called to home the Y axis
          ; Lift Z relative to current position
          G91
          G1 Z5 F6000 S2
          G90
          ; Move quickly to Y axis endstop and stop there (first pass)
          G1 Y-210 F1800 S1
          ; Go back a few mm
          G91
          G1 Y5 F6000
          G90
          ; Move slowly to X axis endstop once more (second pass)
          G1 Y-210 F360 S1
          ; Lower Z again
          G91
          G1 Z-5 F6000 S2
          G90
          ; homex.g
          ; called to home the X axis
          G91
          G1 Z5 F6000 S2
          G90
          ; Move quickly to X axis endstop and stop there (first pass)
          G1 X-200 F1800 S1
          ; Go back a few mm
          G91
          G1 X5 F6000
          G90
          G1 X-200 F360 S1
          ; Lower Z again
          G91
          G1 Z-5 F6000 S2
          G90
          ; homez.g
          ; called to home the Z axis
          ; Lift Z relatively to current position
          G91
          G1 Z5 F6000 S2
          ; Back to absolute positioning
          G90
          ; Go to first bed probe point and home the Z axis
          ;G1 X0 Y0 F6000 S2
          G30
          • jnolan72undefined
            jnolan72
            Something new in error in 1.21 that I did not see in 1.20
            Browser or web problem. Error after uploading a file
            JavaScript Error
            A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
            Version: 1.21
            Message: Uncaught TypeError: Cannot read property 'axesHomed' of undefined
            URL: http://10.0.2.147/js/dwc.js
            Line: 776:70
            Error object: {}
              @jnolan72:
              JavaScript Error
              Version: 1.21
              Line: 776:70
              Error object: {}
              Is it reproducible, or did it happen just once? Can you confirm that you are running version 1.21 of both the main firmware and DWC?
              jnolan72undefined 1 Reply Last reply Reply Quote 0
              • DocTruckerundefined
                DocTrucker
                Subtle change noticed…
                My procedure:
                • Home axis
                • Warm up bed / enclosure
                • Run bed probe
                • Warm up nozzle
                • Check nozzle height with my calibrated feeler gauge (scrap of paper đŸ˜‰ )
                • Use G10 to set tool offset - i.e. if feeler'ed ideal z=0 plane is at Z=-0.15mm I'll send 'G10 P0 Z0.15'
                The G10 used to update the reported z position instantly. Now running the G10 command would virtually shift the axis but the value reported on 1.21 web control only updates after a G1 move of the z-axis - which may be a no-distance move.
                  @DocTrucker:
                  My procedure:
                  • Home axis
                  • Run bed probe
                  • Warm up nozzle
                  On my list to look at.
                  • zerspaner_gerdundefined
                    zerspaner_gerd
                    @dc42:
                    2. In FDM printer mode, that is correct. The reason is that it is quite common for a skirt to exceed the bounds of the bed. In laser and CNC mode the print will be terminated. If you want this changes, please suggest what you would like instead in the Firmware Wishlist section.
                    Of course they are right. If it was just the skirt, brim or raft, it would be a good feature.
                    I can live with that, if I know it
                    I have noticed inconsistent Z-value display in firmware 1.21. Observed at nozzle change and Babystepping, Babystepping did not show any z-change.
                    Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                      That's correct, the displayed height is now in user coordinate space, i.e. what was commanded in the last G0 or G1 command before any baby stepping, axis skew correction, tool offset, workspace coordinate offsets or bed level correction. The machine coordinates are also sent to DWC, so in future DWC may display machine coordinates too.
                      • Thomllamaundefined
                        Thomllama
                        OK, I see after doing the Update CoreXY has issue, which I have now, and I read all around what it can't do anymore, but no CLEAR method to fix the homing setting.. just little snippets that are making no sense to me. what exactly do I have to do now that the firmware is updated do I have to do/change to get it to run again? I'm am far from a Codey guy, but can usually figure stuff out, but this makes no sense to me... the Update info says the G1 won't work anymore and need to add some S2 command, but what S2 command? where? does it need a value? do you remove the G0 or G1's from the homing files? Do I have to go in and edit all four Home files in the firmware? will I have to add S2 every time I use the G1/G0 commands?
                          Thomllama
                          OK, face book people helped out and seems I have it working correctly now.. needed to go through all the homing settings file, add and S2 to the end of ever G1 line, unless there is a S1 already there. did screw up and it wasn't sensing the end stops at 1st, but luckily I have copied and save the text in note pad. Started from scratch and re added the S2's and now it seems to be working.
                          on another note, did a search and basically came up with nothing so.. What is S1 and S2? what do the mean/do?
                          thanks
                          • AlexLinundefined
                            AlexLin
                            Snnn Flag to check if an endstop was hit (S1 to check, S0 to ignore, S2+S3 see note, default is S0) 1
                            1RepRapFirmware can be set to enable or disable the "sensing" of endstops during a move. Using the S1 or S2 parameter on a delta printer causes the XYZ parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1. If S3 is passed instead, RepRapFirmware will measure the axis length.
                              Thomllama
                              Honestly, is there a way to return it to the old method? I'm finding this rather annoying. Have changed over the Home files, and yet 50% of the time I still get an error. hit the home button like 3 times and it'll finally home.. and then another 25% of the time it'll ignore the end switch and just try and keep going and get all clicking while trying to rip apart my printer. Sounds like it's an advantage to Deltas, but for me on the CoreXY it's really not. Still building/tinkering with the printer and often want to be able to move away from home to work on something, especially the bed. If I add a new nozzle say I want to be able to move away from home, change things, get things loose then home and adjust to bed height and such, now I have to slam it into the nozzle before I can do anything. Also if there is a glob of old drip on the nozzle, I have to heat it up,. clean it off, home the thing, then can move away. Or (like just happened to me) it homes, slams into the cold, hard glob and twists and breaks the hotend or mount. đŸ˜•
                              Also, just a thought but wouldn't it have been better if the firmware update had updated the home files? Or make this feature apply when you enter the Delta option in the firmware and leave it alone for the rest?
                                If you mean that you want to allow axis movement before the axis has been homed again, that's easy. Just put M564 H0 in config.g.
                                Thomllamaundefined Coffeeundefined 2 Replies Last reply Reply Quote 0
                                  Thomllama @dc42
                                  @dc42 said in It's out! Firmware 1.21 released:
                                  so that will return homing to back like it was before the update? I don't need the extra S2's all over the place?
                                  • Coffeeundefined
                                    Coffee @dc42
                                    @dc42 I have my Duet WiFi up and running very well, but this tweaking of the coding is somewhat new to me. I would love to be able to go back to moving before/without homing. Can you tell me where in config.g and what syntax if any for me to enter the M564 H0 command? Thanks!
                                    Nice Forum BTW Everyone here seems cool and helpful.
                                      It doesn't matter where in config.g you put the M564 H0, but I suggest near the end.
                                      Thomllamaundefined 1 Reply Last reply Reply Quote 1
                                      • Coffeeundefined
                                        Coffee
                                        Thanks a ton!
                                          Thomllama @dc42
                                          Seems to work great! thanks đŸ™‚
                                          • pao_wikhanundefined
                                            pao_wikhan
                                            what is the reason to why add the S2 on the G0 G1 for corexy?
