    Sensorless Homing oddness
    3.2k
    • mhackneyundefined
      mhackney
      I read through the wiki and read the posts here on setting up Sensorless Homing on a CoreXY running RRF 1.21 release. I thought I had working it but I am seeing odd sporadic behavior. This machine was running fine with endstop switches but I wanted to try this feature out.
      Basically, after a Duet reboot, if I Home All, the carriage moves the wrong way in X (away from X=0 which is at the left on this printer.) However, if I Home X individually, it homes correctly. Then Home Y individually, it homes Y correctly and then if I Home All, that works correctly! Note that if I only Home X but not Y and then Home All, it homes towards +Y and stalls undetected.
      If after a successful Home X, Home Y, Home All I attempt to Home All again later, it sometimes works, sometimes goes towards X+.
      Here is my config.g:
      M574 X1 Y1 S3 ; set endstop to use motor stall
      Here is homex.g
      ; Sensorless Homing for X axis
      ; BL Touch prep
      M280 P3 S160 I1			; alarm release and push-pin up
      M402				; retract probe in case its down
      M400                    	; make sure everything has stopped before we make changes
      M913 X50             		; reduce motor current to 50% to prevent belts slipping
      M915 X S3 R0 F0			; X sensitivity to 3, do nothing when stall, unfiltered
      G91                   	 	; use relative positioning
      G1 S1 X-270 F4000    		; move to home position
      G1 X25 F2000          		; back off to edge of bed
      G90            			; back to absolute positioning
      M913 X100        		; motor currents back to normal
      and here is homeall.g
      ; homeall with BL Touch probe
      M400				; make sure everything has stopped moving
      M913 X50 Y50
      ; BL Touch prep
      G4 S1
      G4 S0.5
      ; home XY for Z homing
      G91            			; relative mode
      G1 Z5 F200 S2			; lower bed 5mm
      G1 S1 X-270 F4000		; home X
      G1 S1 Y-270 F4000		; home Y
      ; Z homing
      G1 X135 Y135 F4000		; move to bed center
      ; slow down for probing Z
      M566 Z10			; max instantaneous speed change (mm/min) (jerk)
      M203 Z400			; max speed (mm/min)
      M201 Z100			; max acceleration (mm/s^2)
      ; probe
      M558 A1 F400			; set single probe at faster feed rate
      G30				; probe
      M558 A10 F100			; set single probe at slower feed rate (more accurate)
      G30				; probe to get a more accurate postion
      ; set normal speeds
      M566 Z60			; max instantaneous speed change (mm/min) (jerk)
      M203 Z900			; max speed (mm/min)
      M201 Z20			; max acceleration (mm/s^2)
      G90				; back to absolute mode
      M400
      M913 X100 Y100
      Note that I am using a BL Touch for probing and have deployprobe.g defined as:
      M280 P3 S10 I1
      and retractprobe.g:
      M280 P3 S90 I1
      My 3D Printing blog: http://www.sublimelayers.com
      Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
        You haven't posted your homing files so this is just a guess. If the motors are initially reporting stalled status because they were at standstill then the first G1 S1 move will be terminated immediately. So you may need to insert a short move away from the endstops first. For a CoreXY I think something like G1 S2 X1 Y-1 may work, if both axes home to the low end.
        • mhackneyundefined
          mhackney
          David, the code above is my homex,g and homeall.g
          Both axis do home to the low end - left front corner.
          Is there a way to show code in this new forum? I didn't find that feature so my home files are just in line in the post.
          • mhackneyundefined
            mhackney
            I noticed that there is a 2-3 second delay before it starts a Home All. I don't recall that happening with endstop switches.
              I'm sorry, this new forum is a pig to use on a tablet, I can usually see on!y half a line of what I am typing (often I can't see it at all) and none of the message I am replying to. Anyway, moving the head a short distance away from the endstops may fix the problem.
              mhackneyundefined T3P3Tonyundefined 3 Replies Last reply Reply Quote 0
              • mhackneyundefined
                mhackney @dc42
                @dc42 thanks David, I'll give that a shot.
                • norbs12undefined
                  norbs12
                  I've gotten sensorless homing down pretty well.
                  First off, I've found that just calling your home(x,y,z,).g with a M98 P<filename> from your homeall.g is the best what to go about things. Yes it will take a bit longer but at least you're not editing multiple files.
                  Example:
                  G1 Z15 F6000 S2
                  M98 Phomex.g
                  M98 Phomey.g
                  M98 Phomez.g
                  G1 X5 Y5 Z5 F6000
                  Next for each axis I do a double home. First I'll home an axis then move away from home then home again but slower. This seems to be a bit more reliable because if you're too close to begin with, you can get grinding as well as can be mid acceleration so you can get different results. I also adjust motor current to a constant that doesn't depend on any setting from my config.g. This lets me change motor settings and not break sensorless homing.
                  Here is an example of how I home X:
                  ; homex.g
                  ; called to home the X axis
                  ;Here I set motor settings before homing, it makes sure they are consistent even if I change settings for my motors for regular printing, it wont break my homing (the settings are corrected at the end of homing)
                  M203 X8000				; Set maximum speeds (mm/min)
                  M906 X900				; Set motor currents (mA) and motor idle factor in percent
                  M201 X200				; Set accelerations (mm/s^2)
                  M913 X30		; drop motor currents to 30%
                  G1 S1 X-305  F8000	; move X all the way left and stop at end
                  G1 X40  F2700	; move X all the way left and stop at end
                  G92 X50
                  G1 S1 X-60  F2700	; move X all the way left and stop at end
                  M400			; make sure everything has stopped before we reset the motor currents
                  M913 X100		; motor currents back to 100%
                  G1 X10			; move to parking point
                  M98 Pmotorspeeds.g      ;I moved all motor settings from config.g into motorspeeds.g file so that I can set the back to normal after any changes during homing.
                    T3P3Tony administrators @mhackney
                    @mhackney said in Sensorless Homing oddness:
                    Formatting is done in "Markdown" ( see the compose ?) Link http://commonmark.org/help
                    Code blocks:
                    Inline code with backticks
                    # code block
                    print '3 backticks or'
                    print 'indent 4 spaces'
                    mhackneyundefined 1 Reply Last reply Reply Quote 0
                    • mhackneyundefined
                      mhackney @dc42
                      @dc42, adding the move away from endstops did not work. The behavior appears to be identical.
                      • mhackneyundefined
                        mhackney
                        @norbs12 and @dc42 - this is driving me sane!
                        norbs12, I refactored my homeall.g to call the individual macros per your suggestion. I then ran it 5 times in a row successfully. Went to get a cup of coffee and re-ran when I got back (5 minutes). This time, the printer homed incorrectly to X+ again (just like the original symptom).
                        When it starts to home, if it moves in the correct direction, homing will complete correctly but for some reason, it wants to home in the wrong direction and that, of course, fails.
                        • mhackneyundefined
                          mhackney
                          I do see an error in the console:
                          Error: Attempt to seek on a non-open file.
                          Here is my firmware install:
                          Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
                          Firmware Electronics:	Duet WiFi 1.02 or later
                          Firmware Version:	1.21 (2018-03-21)
                          WiFi Server Version:	1.21
                          Web Interface Version:	1.21-RC4
                          • mhackneyundefined
                            mhackney
                            I noticed something else, when I run Home X by itself, most of the time it works correctly. But in 6-10 runs, it will also move in the wrong direction and stop the "back off to edge of bed" (see in code) distance. So, the behavior is, none of movement code above that line is run but the G1 X25 F2000 is executed and the carriage moves 25mm in the +X direction on occasion.
                            ; BL Touch prep
                            • mhackneyundefined
                              mhackney
                              Here's a CoreXY question! In my homex.g script above, I reduce the current for the X stepper. However, CoreXY movements in X use both the X and Y steppers. The M913 command sets motor current % for the MOTOR not the axis, correct? So all of us with CoreXYs need to reduce current on both X and Y motors when we use senseless homing. I'll try this now. Don't think it will affect my issue but I think this is the correct configuration for CoreXY right?
                              And this would apply to M915 motor stall detection too wouldn't it.
                              • mhackneyundefined
                                mhackney
                                Ok, I think I have a handle on things. It required understanding the M913 and M915 behavior - they apply to drives no axes (I had to use the M915 P0:1, the X Y did not provide consistent behavior) AND an issue with my printer. First, code:
                                Simple homeall execute individual homing scripts
                                ; homeall by executing individual axes homing macros
                                M98 Phomex.g
                                M98 Phomey.g
                                M98 Phomez.g
                                homex.g
                                ; home X with BL Touch
                                ; BL Touch prep
                                M913 X30 Y30             	; reduce motor current to 50% to prevent belts slipping unfiltered
                                M915 P0:1 S3 R0 F0
                                M400
                                M913 X100 Y100        		; motor currents back to normal
                                homey.g is the similar to above
                                homez.g uses BL Touch probe
                                ; BL Touch prep
                                G4 S1
                                G4 S0.5
                                ; lower bed for travel
                                G91				; relative moves
                                ; move probe into position
                                G90
                                M400
                                ; probe
                                G30				; probe
                                M400
                                ; set normal speeds
                                Now for my problem - the X linear rail carriage bearings are horrible and bind slightly. Not noticeable (except the grating noise) at normal current but turning the current down to 30% creates sporadic issues with slight binding.
                                I have new bearings to pack these carriages and in fact was planning to do that after I got senseless homing working. I'll claim victory (pending any recommendations from @dc42 on the code above) and take the rails off to R&R.
                                  That's correct, M913 and M915 on a CoreXY machine relate to drives not axes.
                                  If an axis sometimes moves the wrong way when homing, then it could be that you have reduced the motor currents too much to overcome friction, and one motor + friction in one axis is driving the other motor backwards.
                                  • mhackneyundefined
                                    mhackney
                                    Makes sense. I know my Z linear rail carriages are gritty - they occasionally make a grinding noise that "just ain't right".
                                    klcjr89undefined 1 Reply Last reply Reply Quote 0
                                    • klcjr89undefined
                                      klcjr89 @mhackney
                                      @mhackney How did the LM76 speed demon linear rails work out? Any cons? I want to do a build based around them.
                                      • mhackneyundefined
                                        mhackney
                                        I like them a lot. I do still need to complete the big CoreXY they are on but I got them moving plus I had them operational on a delta 2 years ago.
                                        • klcjr89undefined
                                          klcjr89 @mhackney
                                          @mhackney The speed demon guides do seem like a better choice than the Hiwin style, less points of failure and no grit ingestion.
                                          • mhackneyundefined
                                            mhackney @klcjr89
                                            @klcjr89 the only downside is they do not have a model as compact as a 12mm hiwin
