werid z starting printing much higher than anticipated...
2.6k
    otaku521
    M122
    Used output buffers: 3 of 32 (13 max)
    RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
    Board ID: xxxxxxxxxxxxxxxxxxxx
    Static ram used: 16152
    Dynamic ram used: 100648
    Recycled dynamic ram: 1984
    Stack ram used: 1224 current, 6504 maximum
    Never used ram: 5784
    Last reset 05:23:42 ago, cause: power up
    Last software reset at 2018-04-13 14:39, reason: User, spinning module GCodes, available RAM 7760 bytes (slot 3)
    Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
    Error status: 0
    Free file entries: 9
    SD card longest block write time: 170.2ms
    MCU temperature: min 32.8, current 48.2, max 49.7
    Supply voltage: min 24.1, current 24.2, max 25.3, under voltage events: 0, over voltage events: 0
    Driver 0: ok, SG min/max 0/75
    Driver 1: ok, SG min/max 0/16
    Driver 2: ok, SG min/max 0/1023
    Driver 3: ok, SG min/max not available
    Driver 4: ok, SG min/max 0/365
    Date/time: 2018-04-14 03:14:00
    Slowest main loop (seconds): 1.256110; fastest: 0.000046
    MaxReps: 4, StepErrors: 0, LaErrors: 0, FreeDm: 129, MinFreeDm 120, MaxWait: 3092251824ms, Underruns: 0, 2
    Scheduled moves: 233458, completed moves: 233428
    Bed compensation in use: mesh
    Bed probe heights: -0.850 -1.028 -1.423 -0.223 -0.308
    Heater 0 is on, I-accum = 0.3
    Heater 1 is on, I-accum = 0.3
    Segments left: 1
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is doing "G1 X207.709 Y205.763 E29.1859" in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
    HTTP sessions: 2 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.21
      WiFi MAC address xxxxxxxxxxxxx
      WiFi Vcc 3.33, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 13992
      WiFi IP address 192.168.10.22
      WiFi signal strength -56dBm, reconnections 0, sleep mode modem
      Socket states: 2 0 0 0 0 0 0 0
      === Expansion ===
      otaku521
      Here is a photo of my HEVO
        T3P3Tony administrators
        To confirm. When you command the printer to go to
        G1 Z0
        Its at a perfect Z0 (by paper feeler gauge)
        But when you start a print you have to use -1.35mm of baby stepping to get it to the right height?
        Can you post the first bit of a gcode file that you have tried to print that shows this issue please.
        undefined 2 Replies Last reply 14 Apr 2018, 14:49 Reply Quote 0
          Does your slicer start GCode include a G28 homing command, and if so it that altering the Z=0 position?
          undefined 1 Reply Last reply 14 Apr 2018, 14:47 Reply Quote 0
            otaku521 @dc42
            @dc42 Yes it does a home before print... is this the problem?? if so I take it out!
              otaku521 @T3P3Tony
              @t3p3tony
              Here is the gfile for the above print... (first couple of lines) (using S3D as Slicer)
              G90
              M82
              M106 S0
              M140 S85
              M190 S85
              M104 S235 T0
              M109 S235 T0
              M582 T3 ; FILAMENT RUNOUT SENSOR TURN ON
              G28 ; home all axes <<<<< @dc42 is this the problem???
              M106 P1 S0 ; Turn off Parts Fans
              G92 E0
              G1 E-0.6000 F6000
              G1 Z0.250 F1200
              ; process Process1
              ; layer 1, Z = 0.250
              T0
              ; tool H0.250 W0.600
              ; skirt
              G1 X51.471 Y88.911 F3000
              G1 E0.0000 F1800
              G92 E0
              G1 X52.456 Y88.293 E0.0711 F600
              G1 X52.557 Y88.237 E0.0781
              G1 X53.155 Y87.948 E0.1188
                otaku521 @T3P3Tony
                @t3p3tony
                Yes when I go G1 Z0 it is a good paper feeler grip (like typical feel when I do paper feeler)
                then start print i have to use -1.35mm baby step... this IMHO doesn't make sense...
                if it was +/-0.2-0.3 maybe... but -1.35mm made me think there is something really wrong ... but I have no idea what
                undefined 1 Reply Last reply 14 Apr 2018, 16:23 Reply Quote 0
                  T3P3Tony administrators @otaku521
                  @otaku521 if you do a G28 and then G1 Z0, how far above the bed is the nozzle? Is it paper feeler close or~1.35mm above. If it is the latter then you need to adjust oyur config so that it is.
                  I think is sensible to have a home command in your start gcode.
                    otaku521
                    @t3p3tony
                    It is after g28 before print it is paper feeler close
                    But when start print and re home again it is higher than anticipated
                    Thus I have to do baby step that large (which results me to perminate to add it in my config file for now on
                    The bottom of the mini ir sensor there is enough gap that I can see the hex of the nozzle to the tip
                    Maybe g28 is running too fast on z to get an inaccurate reading?
                    Note that i am using a 2mm black PEI sheet like I mentioned above
                    undefined 1 Reply Last reply 15 Apr 2018, 10:13 Reply Quote 0
                      otaku521
                      I have uploaded the video for your reference...
                      https://youtu.be/p8XtWKYzo_I
                        @otaku521 g28 should produce the same results no matter if it is run from the command line or from a gcode file. Can you test it multiple times from the command line to assure repeatability.
                          otaku521
                          I know... this is why it is weird....
                          so far I am wondering if my config and other scripts are fine ?
                          undefined 1 Reply Last reply 15 Apr 2018, 13:01 Reply Quote 0
                            BPisLife @otaku521
                            @otaku521 Sorry if you already mentioned this, but I was having an strange issue like this to and it turns out my slicer (simplify3D) was setting the Z to be .18 for the first layer. If my z=0 was tuned to approx. .1mm off the bed, then it would be .28mm off the bed and the print wouldn't adhere.
                            Just a thought, check out your gcode for the first layer and see what it sets Z to, then manually move the Z to the point it says after printing and you may see the gap. If so, then you need to either A adjust your slicer or your leveling. This is of course only assuming you are seeing what I am describing here.
                            undefined 1 Reply Last reply 15 Apr 2018, 13:31 Reply Quote 0
                              otaku521 @BPisLife
                              @bpislife you are 0.1-0.2xx off.. while I am 1.xx off... this made me think otherwise....
                              the only thing is I think is the 2mm PEI sheet on the bed not being correctly read by mini IR probe... so I am thinking of switching back to BL Touch and see
                                If the PEI sheet was not being recognised l would expect that to happen either way. I just had a thought though. Are you probing the bed in your prints but not when doing a normal test of G28?
                                undefined 1 Reply Last reply 16 Apr 2018, 12:04 Reply Quote 0
                                  SputnikOC3d
                                  I have the same issues and have been plagued by it since day one. I cannot resolve ... I initially chalked it up to inconsistency of the BL Touch, but the more I deal with the issue it seems to be some arbitrary value created by the firmware.
                                  I have to babystep in EVERY print - using a 5-6 perimeter skirt - and hope I can step it in in time before the actual part starts. Circles are particularly ominous to get right ... in time.
                                  If I dont get adhesion - then I get Elephants Foot [ alot ] as I err on the side of sticking this mother down.
                                  all this to say ... youre not alone.
                                  undefined 1 Reply Last reply 16 Apr 2018, 12:09 Reply Quote 0
                                    otaku521 @T3P3Tony
                                    @t3p3tony
                                    No... I only probe when everytime I start the machine doing my Macro above which calibrate my leadscrews (from 2... now 3 (just installed a Duex5) and then I do some prints from there on... but I don't start script all my prints to go calibration at the beginning since I got the Mini IR Probe (Switching out the BL touch)... (which was "PITA"...)
                                      otaku521 @SputnikOC3d
                                      @sputnikoc3d
                                      Thanks! I think it is problem with PEI with IR...
                                      I used to have BL Touch on AnyCubic's Ultrabase... it was inconsistent... then I switch Mini IR with Ultrabase and it was a joy!.... then now with a bigger bed (420x320)... I have to cut my own PEI sheet (2mm) and now it literally drives me nuts!! (but PEI when printed on fine... it is very nice to use!)
                                      I am thinking of installing BL touch back... but I might be plagued by inconsistencies again.... OH THE JOY of 3D printing! XD
                                        AlexLin
                                        @otaku521 said in werid z starting printing much higher than anticipated...:
                                        was it? No problems due to the hole-pattern? What color do you have under the Ultrabase?
                                        undefined 1 Reply Last reply 16 Apr 2018, 13:09 Reply Quote 0
                                          otaku521 @AlexLin
                                          @alexlin I never removed the sticker on the bottom... I just put it on top of my old MK3 200x200x3mm Alum bed and clip in with 4 binder clips... never had a problem... I am in process of tearing my old i3 clone and making another corexy
                                          13 out of 23
