Retraction issues
for reference here are my settings on my P3Steel (i3 clone) with titan extruder:
M201 X2000 Y2000 Z100 E1000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z800:800 E1800 ; Maximum speeds (mm/min) M566 X1200 Y1200 Z800:800 E300 ; Set allowable instantaneous speed change mm/min M207 S1.2 R0 F3000 ; firmware retraction
Cura is doing my retraction, I’ll use firmware if needed it’s just not something I’ve had to mess with until now.
You’re not my real dad! Lol. Thanks, I’ll start messing with some settings when I get off work.
Thanks also to everyone who’s commented!
No, it's not needed to do firmware retraction. Cura has good retraction control. Just wondering what settings you're trying to use. The low jerk value could be preventing you from hitting it.
If you're coming from Marlin you may be used to seeing the jerk values in mm/s rather than the mm/min in RRF.
I’m coming from Marlin, so this is all different haha. I’ll definitely up my jerk settings and see what happens.
Also I have this issue where I can set a perfect offset from the bed for the first layer, but after a couple layers the nozzle starts touching the print. I’m thinking it’s my z steps but I had set those to what I had in Marlin firmware, So I’m not sure lol.
@stealthy_tt What are you using for a Z probe? What does your homez.g file look like?
Have no access to the home file at the moment, but I’m using dc42s mini ir probe
Heres my homez file
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool on Sat Apr 14 2018 16:11:45 GMT-0700 (Pacific Daylight Time)
;G91 ; relative positioning
;G1 Z5 F6000 S2 ; lift Z relative to current position
;G1 S1 Z-405 F1800 ; move Z down until the switch triggers
;G92 Z2.5 ; set Z position to trigger height; Uncomment the following lines to lift Z after probing
G1 Z20 F100 S2 ; lift Z relative to current position
G90 ; absolute positioning /
g1 x180 y180 s2 f2000
g30I know i probably messed something up here, was a crap shoot for me to get the probe to work haha.
RepRapFirmware will do whatever the gcode generated by the slicer commands. It isn't normal to retract and travel at the same time, although some slicers have a "wipe while retracting" option.
The way im describing it is probably wrong. I know its not retracting correctly though. On my stock anet board the nozzle would never stop to retract, and if it did it wasnt long enough for me to think hey something is wrong. On the Duet the hotend stops dead in its tracks long enough for me to notice something is wrong with my settings or something. Ill have to get a video of it as I know im not describing it correctly lol.
Perhaps you have the maximum extruder speed or acceleration set much too low in the M203 or M201 command?
Probably, im going to try some changes when i get off work. Are we able to upload videos directly or do we have to upload somewhere like youtube?Using my phone thats why I ask.
Thanks dc42
Upload to YouTube and post the link here.
Thanks will do when I get off work.
Any ideas as to why when I get my nozzle offset corect after a first couple layers print the nozzle starts to scrape over the top of the print?
I calibrated the extruder steps and when I extrude 100mm of filament 100mm is indeed what is taken up. So I dont think it can be that. I was thinking maybe the z axis steps, but thats the same as I had in Marlin. Is there like an offset per layer or something?
May have figured out my issue with the nozzle dragging on the print after the first layer or so. Searching around i found that a M8 rod 1.25 pitch at x16 should have a value of 2560 steps/mm i have mine set to 400 steps/mm ill have to try when i get home
@stealthy_tt Are you maybe skipping steps on the Z axis?
@phaedrux
Not skipping that i am sure of, see my reply above you, i think i figured it out but wont know till later -
Okay, So just messed with my Z steps/mm 400 is infact correct with my printer afaik. I homed z and took a measurement and then moved z up 10mm and it was exactly 10mm. so thats not my dragging issue.
Heres the video of what it is doing. The hums you hear are it retracting and re extruding
Did increasing jerk and acceleration help at all?
What do the retraction settings look like in Cura?
