    DuetWifi & PanelDue 10-Pin Ribbon Cable Hookup Clarification
    2.6k
    • SnowCrashundefined
      SnowCrash @elmoret
      Thanks elmoret!
      @elmoret said in DuetWifi & PanelDue 10-Pin Ribbon Cable Hookup Clarification:
      You can use both the 4 pin and the 10 pin cables, just the former, or just the latter. No really reason to use both, though.
      Got it.
      Unsure where you pulled the Conn_SD pinout from, but it looks incorrect.
      Well, I pulled it from the official pinout diagram of the DuetWifi published here ... 🙂
      I guess Duet3D might want to correct this.
      Try here:
      https://github.com/T3P3/Duet/blob/master/Duet2/Duet2v1.03/Duet2_Schematic_v1.03.pdf
      Thanks for the pointer! I actually have both the pinout and circuit diagrams on my desktop - it was just easier to simply look it up in the former than go searching for the relevant section in the latter.
      That should hopefully rectify your concerns, the others are just pin nomenclatures.
      The circuit diagram does make much more sense!
      I appreciate the help!
      All the best,
      SnowCrash
        T3P3Tony administrators
        Got it, I need to update that part of the circuit diagram to v1.01+
          T3P3Tony administrators @T3P3Tony
          @t3p3tony and now its fixed:
          https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
          SnowCrashundefined 1 Reply Last reply Reply Quote 1
            SnowCrash
            Excellent job, T3P3Tony, thanks!
            On a sidenote, since the new forum was launched, I haven't been receiving email notifications about new posts in threads I'm watching like this one. Might be worth checking if this feature is working properly.
            All the best,
            SnowCrash
            JohnOCFIIundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
            • JohnOCFIIundefined
              JohnOCFII @SnowCrash
              @snowcrash DId you set up the new notifications in the new software? That is something that did not transition from the old forum software, and has to be set up separately. I find the new notifications (with the new forum software) much more reliable than with the old.
              SnowCrashundefined 1 Reply Last reply Reply Quote 2
                T3P3Tony administrators @SnowCrash
                @snowcrash check your profile settings.
                  SnowCrash @JohnOCFII
                  @johnocfii said in DuetWifi & PanelDue 10-Pin Ribbon Cable Hookup Clarification:
                  @t3p3tony said in DuetWifi & PanelDue 10-Pin Ribbon Cable Hookup Clarification:
                  Thanks JohnOCFII & T3P3Tony!
                  You were both right - the settings needed updating 🙂
                    SnowCrash @T3P3Tony
                    I'm not sure this is the correct place to post this comment, but it's related to previous posts so here goes.
                    Having done a lot of work in the past couple of weeks with this excellent pinout diagram, it occurred to me to suggest a tweak that I know would be very helpful to me and hopefully to others as well.
                    The connectors on the board are of course keyed, however, the diagram doesn't reflect the keying direction. This means that when making a new cable for one of the connectors, I first refer to the diagram for the order of wires and then need to look at the actual board to check in which direction the connector is keyed.
                    On the other hand, had the diagram also included the keying direction of each connector, it would make things much simpler as there wouldn't be a need to check the actual board when making new cables.
                    Phaedruxundefined 1 Reply Last reply Reply Quote 2
                      Phaedrux Moderator @SnowCrash
                      @snowcrash I had to open my enclosure today for the very same reason! So having the connector keys indicated on the diagram would be nice.
                        Thanks for the recommendation. On my to-do list!
