    No communication after erase button pressed
    Firmware installation
    firmware connectivity erase
    3.8k
    • Spodeopieterundefined
      Spodeopieter @dc42
      Yes , I have tried a few different cables.
      Should I have the sd card inserted or not ?
        dc42 administrators @Spodeopieter
        @spodeopieter said in No communication after erase button pressed:
        It doesn't matter, unless the SD card is faulty and drawing a large current from the 3.3V rail.
        Spodeopieterundefined 2 Replies Last reply Reply Quote 0
          Spodeopieter @denke
          @denke
          Dmesg
          [846482.444916] usb 3-6: new full-speed USB device number 33 using xhci_hcd
          [846482.556934] usb 3-6: device descriptor read/64, error -71
          [846482.772945] usb 3-6: device descriptor read/64, error -71
          [846482.988898] usb 3-6: new full-speed USB device number 34 using xhci_hcd
          [846483.100971] usb 3-6: device descriptor read/64, error -71
          [846483.316940] usb 3-6: device descriptor read/64, error -71
          [846483.532862] usb 3-6: new full-speed USB device number 35 using xhci_hcd
          [846483.533051] usb 3-6: Device not responding to setup address.
          [846483.736958] usb 3-6: Device not responding to setup address.
          [846483.940851] usb 3-6: device not accepting address 35, error -71
          [846484.052817] usb 3-6: new full-speed USB device number 36 using xhci_hcd
          [846484.053010] usb 3-6: Device not responding to setup address.
          [846484.257021] usb 3-6: Device not responding to setup address.
          [846484.460791] usb 3-6: device not accepting address 36, error -71
          [846484.460831] usb usb3-port6: unable to enumerate USB device
          [846508.071353] usb 3-6: new full-speed USB device number 37 using xhci_hcd
          [846508.183413] usb 3-6: device descriptor read/64, error -71
          [846508.399383] usb 3-6: device descriptor read/64, error -71
          [846508.615249] usb 3-6: new full-speed USB device number 38 using xhci_hcd
          [846508.727321] usb 3-6: device descriptor read/64, error -71
          [846508.943313] usb 3-6: device descriptor read/64, error -71
          [846509.159258] usb 3-6: new full-speed USB device number 39 using xhci_hcd
          [846509.159404] usb 3-6: Device not responding to setup address.
          [846509.363394] usb 3-6: Device not responding to setup address.
          [846509.567269] usb 3-6: device not accepting address 39, error -71
          [846509.679246] usb 3-6: new full-speed USB device number 40 using xhci_hcd
          [846509.679451] usb 3-6: Device not responding to setup address.
          [846509.883424] usb 3-6: Device not responding to setup address.
          [846510.087244] usb 3-6: device not accepting address 40, error -71
          [846510.087315] usb usb3-port6: unable to enumerate USB device
          lsusb
          Bus 002 Device 002: ID 8087:8000 Intel Corp.
          Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
          Bus 001 Device 002: ID 8087:8008 Intel Corp.
          Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
          Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
          Bus 003 Device 005: ID 04ca:7022 Lite-On Technology Corp.
          Bus 003 Device 004: ID 138a:003f Validity Sensors, Inc. VFS495 Fingerprint Reader
          Bus 003 Device 003: ID 046d:c534 Logitech, Inc. Unifying Receiver
          Bus 003 Device 012: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
          Bus 003 Device 006: ID 0e8d:763e MediaTek Inc. MT7630e Bluetooth Adapter
          Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
          denkeundefined 1 Reply Last reply Reply Quote 0
            Spodeopieter @dc42
            Noted. I have been trying without the SD card anyway, so what is the next step ?
            • denkeundefined
              denke @Spodeopieter
              Did some digging, and red that this message usually means that the device has exceeded the current limit of the port it means some general communication error, but either way it is worth a try
              I, provided I have a notebook, would try to remove the sdcard, give the panel external 12/24v power, unplug the notebook from the charger and any other device connected to the mains voltage, and try the connection that way.
              And / or an usb cable with multiple computer side connectors used by some mobile hdds.
              I really do not know if it would help, but it is worth a try
              Spodeopieterundefined 1 Reply Last reply Reply Quote 0
                Spodeopieter @denke
                @denke
                Ok , so I just tried this , still no luck. I also tried running through usb isolator.
                  Spodeopieter @dc42
                  So what are the next steps ?
                    Which country are you in?
                      Spodeopieter @dc42
                      I am in South Africa , Pretoria
                        Unless you have someone local to you who may be able to diagnose the board, your best option may be to arrange with forum user W3DRK to send the board to him (he is in the US) and take a look at it. he is experienced at diagnosing and repairing Duets.
                          Spodeopieter
                          Can you assist me with a jtag reflash ?
                            Spodeopieter @Spodeopieter
                            Reliable shipping to USA and back would cost me quite a bit of money. Buying a new one would be a better bet for me.
                            I would really like to give the JTAG reflash a go.
                            What programmer do you use for flashing over JTAG ? and can you provide me with a wiring diagram ? Also , what binary should I flash ?
                              We have never flashed a board using JTAG, we flash using USB.
                              The symptoms you report are odd and it sounds to me more like a wiring or driver issue, except that you have tried multiple PCs. Have you measured the voltage on the +3.3V rail? Is any of the chips or the WiFi module on the Duet getting hot?
                                Spodeopieter @dc42
                                @dc42 said in No communication after erase button pressed:
                                3.3 v rail seems good , the SAM chip is getting a little hot , around 40 degrees , the esp is ice cold.
                                Just another thing I noticed , if I press the erase or reset button , nothing happens , no flashing of any LED's
                                  The SAM shouldn't get hot if it's just waiting to be flashed. Perhaps it is faulty.
                                  Once the chip is erased and waiting to be bootloaded, I wouldn't expect the Erase or Reset buttons to flash any LEDs.
                                  It's possible in theory to program the processor via the PanelDue port (and for the same reason, having a PanelDue connected might interfere with programming over USB, although in practice it doesn't seem to). You would need Bossa or SAM-BA and a serial-to-UART converter with 3.3V signal levels.
