    Seems to be doing something : ))
    3.0k
      dc42 administrators @3mm
      @3mm said in Seems to be doing something : )):
      Hovering over the grid does nothing.
      3mm
      In that image it isn't displaying a height map at all. Did that auto calibration fail?
      3mmundefined 1 Reply Last reply Reply Quote 0
      • 3mmundefined
        3mm @dc42
        @dc42 said in Seems to be doing something : )):
        3mm
        No, that's what I've been saying. I've not seen anything on that grid in all of the runs that I've done. Its seems like its working ok?? and I'm not seeing any error messages anywhere. Both 'AutoCalibration' and 'Mesh Grid Compensation' macros run the entire process. It creates a height-map .csv file, but nothing is displayed? And hovering over it does nothing, and before I mentioned this matter...well...I tried zooming in, and out, rotating, panning. The grid is empty.
        Here's the content of the most recent HeightMap.csv file that I generated today.
        HeightMap.csv:
        RepRapFirmware height map file v2, mean error -0.001, deviation 0.044
        xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
        -100.00,100.10,-100.00,100.10,111.80,20.00,20.00,11,11
        0, 0, 0, -0.057, -0.049, 0.052, 0.040, 0.104, 0, 0, 0
        0, 0, 0.017, -0.001, -0.008, 0.027, 0.007, 0.023, 0.027, 0, 0
        0, 0.053, -0.019, -0.011, 0.020, 0.063, 0.026, 0.067, 0.075, 0.098, 0
        0.085, 0.064, 0.037, 0.018, 0.013, 0.017, 0.019, 0.003, -0.096, -0.100, 0.012
        0.051, 0.040, 0.012, -0.002, 0.002, -0.001, -0.010, 0.001, -0.013, 0.003, -0.006
        0.066, 0.040, 0.017, -0.010, -0.034, -0.050, -0.049, -0.061, -0.058, -0.071, -0.073
        0.014, 0.003, 0.003, -0.001, -0.034, 0.015, -0.048, -0.060, -0.043, -0.050, -0.068
        -0.013, 0.010, 0.008, 0.041, 0.014, -0.063, -0.074, -0.071, -0.060, 0.025, -0.046
        0, 0.041, 0.048, 0.050, -0.026, -0.047, 0.031, 0.032, 0.039, 0.051, 0
        0, 0, -0.036, 0.020, -0.055, -0.060, 0.004, 0.004, -0.009, 0, 0
        0, 0, 0, -0.032, 0.023, -0.037, -0.044, -0.023, 0, 0, 0
        On an unrelated subject...I find it peculiar that the web 'G-Console' displays different messages than does the PanelDUE, in fact, there is an obvious disparity between the two readouts, eg, the web 'G-Console' and the PanelDUE 'Console'. It would be convenient to watch the PanelDUE 'Console' display for messages while the web-interface remains in Machine-Control or another mode.
        Thanks...3mm
        There are 10 types of people: Those who understand binary and those who don't.
          What browser are you using? Also, please confirm what firmware and DWC versions you are using.
          • 3mmundefined
            3mm
            Hi...
            Web-Browser: Mozilla - FireFox 'Quantum' v57.0 (64-bit)
            PanelDUE: v1.20(15b1)
            DUET-E HW v1.02
            Smart-Effector v?
            RepRap FW for Duet 2 WiFi/Ethernet
            HW Electronics: Duet Ethernet 1.02 or later
            FW Ver: 1.21 (2018-03-21)
            Web Interface Ver: 1.15a
            thanks...3mm
            ps...screen grab of 'Machine-Control' page:
              You are running a very old version of DWC. Please upgrade it to 1.21.
              3mmundefined 2 Replies Last reply Reply Quote 0
              • 3mmundefined
                3mm @dc42
                I'm confused, I thought I had the latest Firmware...which of these two firmwares are you refering?
                The web-interface, presume is an internal module of the DUET-E firmware v1.21, do I need to manually update that firmware? eg, 1.15a?
                thanks...3mm
                • 3mmundefined
                  3mm @dc42
                  Also, which specific (DUET-E v1.02 HW, SAM4E8E) firmware do you recommend? I'd appreciate the URL location, so as not to make any mistakes.
                  thanks...3mm
                  • Dougal1957undefined
                    Dougal1957
                    This is the link to the file you need to Download then drag the .zip file (do not unzip it) to the Upload button on the settings page of the web interface
                    DWC V 1.21
                    • 3mmundefined
                      3mm @Dougal1957
                      @dougal1957 & @dc42
                      Thanks guys, that fixed the graph anomally!!
                      What about the latest FW releases? I notice some releases at URL:
                      https://github.com/dc42/RepRapFirmware/tags
                      depict a 'verified' tag, while other's don't? What's the difference, are the un-'verified' beta or not-necessarially-stable test releases?
                      Thanks in advance
                      3mm
                        That is correct.
                        • JoergS5undefined
                          JoergS5 @dc42
                          This post is deleted!
