Extra axies not interpolatedduring G2 and G3 moves
1.7k
    Kulitorum
    In the following gcode, U is not interpolated during G2 and G3 moves. Any chance for a quick fix?
    T0 ; Select head 0
    M302 P1 ; Allow cold extrusion
    G90 ;absolute position
    M82 ;absolute extrusion
    G21 ;metric values
    G1 F6000 ; set speed
    ; tool H20.000000 W50.000000 - set visualization width and height for Simplify3D
    ; layer 0, Z = 20.000000
    G92 E0
    G92 E0
    G1 X1000.000000 Y2000.000000 Z21.000000 U0.000000;2
    G2 X1707.106781 Y1707.106781 I0.000000 J-1000.000000 U45.000000 E39.269910
    G2 X1995.859195 Y1090.909091 I-707.106781 J-707.106781 U84.784091 E73.988080
    G3 X2028.025129 Y1026.145105 I99.585920 J9.090909 U264.784091 E77.687482
    G3 X2095.445115 Y1000.000000 I67.419986 J73.854895 U222.392046 E81.386884
    G1 X2900.000000 Y1000.000000 U0.000000 E121.614624 ;4
    G2 X2970.710678 Y970.710678 I0.000000 J-100.000000 U45.000000 E125.541614
    G2 X3000.000000 Y900.000000 I-70.710678 J-70.710678 U90.000000 E129.468604
    G1 X3000.000000 Y500.000000 U90.000000 E149.468604 ;4
    G2 X2853.553391 Y146.446609 I-500.000000 J-0.000000 U135.000000 E169.103552
    G2 X2500.000000 Y0.000000 I-353.553391 J353.553391 U180.000000 E188.738501
    G1 X500.000000 Y-0.000000 U180.000000 E288.738501 ;4
    G2 X146.446609 Y146.446609 I-0.000000 J500.000000 U225.000000 E308.373462
    G2 X0.000000 Y500.000000 I353.553391 J353.553391 U270.000000 E328.008423
    G1 X-0.000000 Y1900.000000 U270.000000 E398.008423 ;4
    G2 X29.289322 Y1970.710678 I100.000000 J0.000000 U-45.000000 E401.935425
    G2 X100.000000 Y2000.000000 I70.710678 J-70.710678 U0.000000 E405.862427
    G1 X1000.000000 Y2000.000000 U0.000000 E450.862402 ;4
    G92 E0
    G1 X1000.000000 Y2000.000000 Z41.000000 U0.000000;2
      Kulitorum
      I just realized that E is also not being processed during G2 and G3 moves.
      Kulitorum
        Thanks for your report. I have located the problem and I will include a fix in the next RC.
          Kulitorum
          I am still waiting for a new firmware 🙂
          I just updated to RC4a to check if the fixes were implemented, and noticed that there are a few other problems:
          G2 and G3 moves are moving too slow. The command
          G1 x0 y0
          g2 x1000 y000 i500 j000 f16000
          Takes 43 seconds to execute, and should take 31.4 second.
          At the same time, the axies are very noisy. I think the axies are accelerating and decelerating all the time, leading to slow move speed and noisy steppers. If I increase acceleration to 50000 (from 400) the time matches the 31.4 sec and the axies are not noisy.
          Any idea when you are releasing the next RC?
          Kulitorum
          undefined 1 Reply Last reply 22 May 2018, 13:57 Reply Quote 0
            dc42 administrators @Kulitorum
            @kulitorum said in Extra axies not interpolatedduring G2 and G3 moves:
            G1 x0 y0
            Kulitorum
            Can you confirm that G2 and G3 moves are extruding correctly in RC4a?
            If it's printing circles too slowly then you probably need to increase the XY jerk setting.
              Kulitorum
              Extrusion works, but U interpolation does not work.
              Changing XY jerk makes no difference, but changing acceleration does.
              Kulitorum
              undefined 1 Reply Last reply 22 May 2018, 14:24 Reply Quote 0
                Kulitorum
                Can you give me a small example of the sort of G2 or G3 move with U movement that you are making? I was planning to do a release later this afternoon but I'll try to fix this issue first when I am sure I understand what it is.
                  Kulitorum
                  I assume you are doing some kind of piecewise linear move, and if you use the start AND end position of each piece, you will get double coords (end is the same as start) and this leads to constant acceleration and deacceleration. Maybe you just need to use the end points and this will fix it?
                  Kulitorum
                    Kulitorum
                    G1 x0 y0
                    g2 x000 y1000 i00 j500 u9000 e9 f6000
                    undefined 1 Reply Last reply 22 May 2018, 15:00 Reply Quote 0
                      Kulitorum
                      After a demo of x and y axis, I execute the G2 command I pasted here:
                      https://youtu.be/g3Q2_Sx2frY
                        G1 x0 y0
                        What was the U coordinate before you executed that command?
                        EDIT: ignore that, I found the problem.
                          Kulitorum
                          Any progress?
                          Kulitorum
                            whosrdaddy
                            I believe @dc42 fixed this problem in 2.0RC5...
                              Kulitorum
                              Just tested RC5, the missing axis problem has been fixed.
                              Thanks
                              Michael
                                Thanks for confirmation.
                                5 out of 15
