problem with connection to duet3d
That all looks OK to me, although the firmware you are running is 2 versions out of date. Please try upgrading both firmwares and DWC to 1.21.
I updated to 1.21, I can enter now, thanks a lot.
what is DWC? -
DWC is Duet Web Control.
what can be the problem?
https://ibb.co/njRg38I updated the firmware to 1.21, DWC not updated.
The problem is failure to read the SD card:
Please confirm that you have the SD card inserted directly into the slot, pressed in until it clicks.
Are you able to read the same SD card on a PC?
when I run the duet, the sd card must be inside? there must to some files?
I tried to run the duet with the SD card(pressed until clicks) and without it.
it still rejected.
actually, when I connected the SD card to PC I had an error that was fixed by the computer, it seems that it works ok.
maybe to try a different SD card? -
Yes, please try a different SD card if you can. You can find the files needed on it at https://github.com/T3P3/Duet/tree/master/Duet2/SD Card Contents.
Another test you can do is to send M39 from YAT. it should report something like this:
SD card in slot 0: capacity 1.98Gb, free space 1.81Gb, speed 20.00MBytes/sec, cluster size 64kb
If it doesn't, send M21 and you should get a response like this:
SD card mounted in slot 0, capacity 1.98Gb
and then you can run M39 again to check the speed.
I can enter now, I got this error when I start.
https://ibb.co/eqV31Tthanks.
@kuper said in problem with connection to duet3d:
That looks excellent. The "heater over-powered" message is common, although it may go away or change after you have tuned your hot end heater.
I am sorry that the SD card that was included with your Duet appears to be faulty.
maybe someone can help with that. now after I changed the sd card files to Rostockmax v3.2 files and try to do first probe or firmware update I didn't get any response. (the firmware updated to 1.21)
update:
https://ibb.co/cuEV0ofirst probe:
thanks for the help.
Adi. -
It looks like you are running macro files provided by SeeMeCNC to do firmware update and bed probing, so please asks them for support for those macros.
