    problem with connection to duet3d
    3.1k
    • kuperundefined
      kuper
      sorry, but I didn't understand.
      what command to right exactly? and which port I need to use for the command?
      thanks,
      Adi.
      • Dr_Ju_Juundefined
        Dr_Ju_Ju
        the command is:
        telnet - ipaddress of target - port to try and connect to
        telnet 192.168.0.170 80
        telnet to ip address on standard web server port
        Julian,
        Old goat, learning new things….
          Please show us exactly what the Chrome address bar and main window show when you put the IP address into it, after doing a successful ping test like that one.
          • kuperundefined
            kuper
            Microsoft edge:
            https://ibb.co/kxDKJ8
            chrome (nothing)
            https://ibb.co/eQqoBT
            I don't know which port number to use in telnet command.
            this is the photo
            https://ibb.co/bykGy8
            thanks.
            • 3DPMicroundefined
              3DPMicro
              is your router set up correctly?
              see if this helps. what fixed it for me was the steps outlined in the first post
              https://forum.duet3d.com/topic/4226/dwc-won-t-open-what-am-i-missing-solved
              Duet controlled Lathe, micro mill, 3d printer and 1992 Haas VF2 VMC
              • kuperundefined
                kuper
                I didn't find any IP address to change in a config file (sys folder)
                  Telnet is no longer provided with recent versions of Windows. I test Telnet using Putty, which is available as a free download.
                  I agree with @3DPMicro, it sounds as if your router is failing to forward the request to the Duet, or failing to pass the response back. However, he had a Duet Ethernet, and I think you have a Duet WiFi - is that correct? If so, please change the end-of-line sequence in YAT to "LF only" (press the "Text settings" button in the Settings screen to find this), then after M552 reports that the Duet is connected to the access point, run M122 to get a diagnostic report.
                  • Dougal1957undefined
                    Dougal1957 @dc42
                    @dc42 Actually Telnet is available in Win10Pro 64 bit (Latest Build) but it does need to be turned on in the Windows Features options
                    • kuperundefined
                      kuper
                      diagnostic report:
                      https://ibb.co/iaRZo8
                      https://ibb.co/iX9LT8
                        That all looks OK to me, although the firmware you are running is 2 versions out of date. Please try upgrading both firmwares and DWC to 1.21.
                        • kuperundefined
                          kuper
                          I updated to 1.21, I can enter now, thanks a lot.
                          what is DWC?
                            DWC is Duet Web Control.
                            • kuperundefined
                              kuper
                              what can be the problem?
                              https://ibb.co/njRg38
                              https://ibb.co/jAt9ao
                              I updated the firmware to 1.21, DWC not updated.
                                The problem is failure to read the SD card:
                                1. Please confirm that you have the SD card inserted directly into the slot, pressed in until it clicks.
                                2. Are you able to read the same SD card on a PC?
                                • kuperundefined
                                  kuper
                                  when I run the duet, the sd card must be inside? there must to some files?
                                  I tried to run the duet with the SD card(pressed until clicks) and without it.
                                  it still rejected.
                                  actually, when I connected the SD card to PC I had an error that was fixed by the computer, it seems that it works ok.
                                  maybe to try a different SD card?
                                    Yes, please try a different SD card if you can. You can find the files needed on it at https://github.com/T3P3/Duet/tree/master/Duet2/SD Card Contents.
                                    Another test you can do is to send M39 from YAT. it should report something like this:
                                    SD card in slot 0: capacity 1.98Gb, free space 1.81Gb, speed 20.00MBytes/sec, cluster size 64kb
                                    If it doesn't, send M21 and you should get a response like this:
                                    SD card mounted in slot 0, capacity 1.98Gb
                                    and then you can run M39 again to check the speed.
                                    • kuperundefined
                                      kuper
                                      I can enter now, I got this error when I start.
                                      https://ibb.co/eqV31T
                                      thanks.
                                        dc42 administrators @kuper
                                        @kuper said in problem with connection to duet3d:
                                        thanks.
                                        That looks excellent. The "heater over-powered" message is common, although it may go away or change after you have tuned your hot end heater.
                                        I am sorry that the SD card that was included with your Duet appears to be faulty.
                                        • kuperundefined
                                          kuper
                                          maybe someone can help with that. now after I changed the sd card files to Rostockmax v3.2 files and try to do first probe or firmware update I didn't get any response. (the firmware updated to 1.21)
                                          update:
                                          https://ibb.co/cuEV0o
                                          https://ibb.co/kdWSfo
                                          first probe:
                                          https://ibb.co/f9TvY8
                                          thanks for the help.
                                          Adi.
                                            It looks like you are running macro files provided by SeeMeCNC to do firmware update and bed probing, so please asks them for support for those macros.
