    Does M906 set RMS or peak current?
    8.3k
      Setting standstill current with M917 doesn't yet work on the Duet 2. But you might want to temporarily increase the idle current to 100% in M906 so that the motor current doesn't get reduced after 230 seconds of inactivity, making the standstill noise easier to hear.
      Setting M906 I parameter to zero will reduce the current to 100mA.
      • wilrikerundefined
        wilriker @dc42
        @dc42 said in Does M906 set RMS or peak current?:
        I have my timeout even reduced to 15s. Which reminds me of another question that came to my mind: is idle current reduction also applied while printing (from SD card)? I ask because that might mean that with this rather short timeout I have set it would reduce the Z motors to idle current for any layer above 10mm height (mesh level taper) that takes longer then my timeout.
        OK, I will add this to GCode description so it will be known when reading documentation about M906
        Manuel
        My Tool Collection
          dc42 administrators @wilriker
          @wilriker, the idle timeout only takes effect when all enabled motors are idle for 30 seconds, or whatever you have the timeout period set to. So the only time it should happen during an SD card print is while heating up.
          • wilrikerundefined
            wilriker
            @dc42 I just wrote a little tool in Go to create me the integer required for M569 Cnnnn based on a more human-friendly input. 😉 I used the macros in TMC2660.cpp as a basis but decided to allow only exactly the values as specified in Trinamic's documentation, e.g. 16, 24, 36 and 54 for TBL which should make it a little less brain-twisting when working with their guide. 🙂
            I have to check an issue with motor stall detection on low Y positions first that my today's print spit out a lot but after that I can start looking into CHOPCONF register.
            EDIT: can this value be set live or do I need to set them in config.g and restart?
            Manuel
            My Tool Collection
              You can set the value live.
              • wilrikerundefined
                wilriker
                @dc42 OK, my results so far: we are already at the more or less best values.
                Test Setup
                Motor: 42SHDC3025-24B
                • Axis: X
                • Step Angle: 1.8°
                • Rated current: 900mA
                • Resistance: 4.4Ohm
                • Inductance: unknown - estimated to 8-10mH
                • Rated torque: 40Ncm
                Motor current set to 400mA with idle current reduction disabled (by setting it to I100)
                Standstill noise is clearly audible and a high pitched sound.
                Results invalid, see post(s) below.
                Results
                Moves
                HSTRT/HEND
                I could get a little bit quieter moves on some circumstances and listening angles/distances when setting HSTRT=5 and HEND=0 (for clarification these are the values that will be put into the macros of the C++ code). But the difference is very faint.
                Standstill
                TOFF
                Regarding standstill noise, I could not find any combination that was quieter. TOFF starting from 8 or 9 up to 15 gets worse with every step but below that they are all about the same, so reducing this from 4 to 2 does not make any audible difference.
                rndtf
                I also tried enabling rndtf but that makes it very minimally worse or equal at best but definitely not better.
                TBL
                Also tried all values of tbl but the current value of 2 already gives best results regarding noise level.
                Any idea what else to test?
                Manuel
                My Tool Collection
                • wilrikerundefined
                  wilriker
                  @dc42 I only now realized that my X motor nearly does not give off any standstill noise. It were my Z motors I was hearing all the time because I did not disable them while testing. I will need to retest and come back with new results.
                  Manuel
                  My Tool Collection
                  • wilrikerundefined
                    wilriker
                    So, this was a rather quick one because currently I have some mechanical squeaking on my Z axis, so I cannot really test movement noises.
                    TOFF
                    For standstill noise setting TOFF=3 makes a noticable difference towards being more silent and a less annoying frequency. All other values are either equal to a value of 4 or are definitely worse.
                    TBL
                    TBL=2 is already the best value.
                    rndtf
                    Enabling rndtf this time makes it noticeably worse.
                    Conclusion
                    Reducing TOFF to a value of 3 will definitely go into my configuration for Z axis. 😉
                    Manuel
                    My Tool Collection
                    • wilrikerundefined
                      wilriker
                      I now also tested all other axes.
                      Best values for TOFF per axis:
                      • X: 6 (makes it inaudible in standstill)
                      • Y: 3 (large improvement)
                      • Z: 3 (large improvement)
                      • E0: 4 (current default) even though 9 also gives a quite good result
                      So it might be interesting to provide a dedicated parameter for TOFF to either M569 or M906 (or maybe M917?) so everyone could work out the perfect values for themselves without having to fiddle around with bitmasks.
                      I will have to retest values fo HSTRT/HEND for all axes again tomorrow.
                      Manuel
                      My Tool Collection
                      • wilrikerundefined
                        wilriker
                        I just precalculated all (valid) combinations of HSTRT+HEND for all axes and uploaded 400 macros to the Duet via a remote connection - the UI was clearly never meant to do that. 😂
                        Manuel
                        My Tool Collection
                        • wilrikerundefined
                          wilriker
                          Another step done:
                          HSTRT, HEND and Standstill Noise
                          I played around with HSTRT and HEND. Main regard here as well was standstill noise.
                          Generally I can confirm my findings above that MSTRT=5, MEND=0 gives best or at least equal noise level except for extruder. For the extruder MSTRT=4, MEND=4 was the best value I could find.
                          General rules found while testing:
                          • MSTRT >= MEND gives least noise
                          • MEND >=8 is usually very noisy and annoying
                          HSTRT, HEND and Movement Noise
                          I only tested X and Z so far regarding movement noise and vibration and also my initial findings for Z stand that MSTRT=5, MEND=0 is equal to very slightly less noisy compared to current default of 3 and 3.
                          For X though I could not find a value that gives less noise on very slow movements than 3 and 3.
                          Basically these settings mainly influence noise level of very slow movements. I usually test them with G1 ... F1 - which is rather unusual for printing except maybe really with Z when Mesh Bed Compensation is active.
                          Manuel
                          My Tool Collection
                            Thanks for your excellent work! I've added a TOFF parameter for M569 to the work list for firmware 2.01.
                            wilrikerundefined 1 Reply Last reply Reply Quote 1
                            • wilrikerundefined
                              wilriker @dc42
                              @dc42 You're welcome! Was fun to experiment with that a little bit.
                              Having a separate parameter will definitely make the config.g file (or more precisely the M569 commands) a lot more understandable without a comment. 🙂
                              Manuel
                              My Tool Collection
                              • wilrikerundefined
                                wilriker
                                For Reference
                                @dc42 said in Motor Whine/Loud Movement:
                                Could you provide chopper configuration values for various TOFF values, so that users who only need to change TOFF can try them?
                                Of course:
                                • TOFF=0 -> M569 C65968 (this means motors are off!)
                                • TOFF=1 -> M569 C65969
                                • TOFF=2 -> M569 C65970
                                • TOFF=3 -> M569 C65971
                                • TOFF=4 -> M569 C65972
                                • TOFF=5 -> M569 C65973
                                • TOFF=6 -> M569 C65974
                                • TOFF=7 -> M569 C65975
                                • TOFF=8 -> M569 C65976
                                • TOFF=9 -> M569 C65977
                                • TOFF=10 -> M569 C65978
                                • TOFF=11 -> M569 C65979
                                • TOFF=12 -> M569 C65980
                                • TOFF=13 -> M569 C65981
                                • TOFF=14 -> M569 C65982
                                • TOFF=15 -> M569 C65983
                                You'll have to add at least the Pnnn parameter to specify the motor.
                                I have written a small tool to create the values for the Cnnn parameter that takes into account all possible sub-values:
                                The source code as well as three precompiled binaries for Windows/Linux/Mac AMD64 have been uploaded to https://github.com/wilriker/chopconf-generator (binaries can be found at https://github.com/wilriker/chopconf-generator/releases).
                                There is also some very short usage description.
                                There is now a page at the wiki Reducing Stand-Still Noise.
                                Manuel
                                My Tool Collection
                                garisundefined 1 Reply Last reply Reply Quote 1
                                • garisundefined
                                  garis @wilriker
                                  @wilriker Thanks for this - another great advantage of having a Duet. I wrote a macro for each motor with 10 seconds at each setting and voila! 2 quiet motors. But I have 4 on a core XY
                                  I am using motors recycled from a scrapped old CTC printer. They are way out of David's recommended specs - they are 6 ohms and 9 mH. They now work quietly on X and Y with no apparent problems so even poor spec motors can work, I think. But the extruder motor went berserk (speed and direction both erratic) driving a Zesty Nimble so I quickly purchased a good 20mm pancake.
                                  My issue is with the Z motor that as an integrated lead screw which I am hesitating on replacing. Because the 250mm leadscrew has different resonant frequencies none of the TOFF settings silenced it. Perhaps it is not possible? A fallback is to add some damping material around the Z screw near the T nut but that might be inelegant. Any suggestions?
                                  • wilrikerundefined
                                    wilriker @garis
                                    @garis My motors are also not optimal with 4.4 Ohm and 10mH and with my extruder motor I was not able to find a better setting than the default. That said there is no guarantee that you can find a setting that will be silent.
                                    I do have silicone dampers on my Z steppers (which I will replace with these standard Nema 17 dampers if I not keep forgetting to order them) and also change my nut to one made from POM/Delrin which also reduced the noise or at least shifted it to a nicer frequency. You could try that.
                                    Manuel
                                    My Tool Collection
                                    • Martin1454undefined
                                      Martin1454
                                      So, I have been playing around a bit with it - But when I change TOFF from 72 to 69, the sound is a little bit better, but my stall detection/ sensorless homing stops working - @dc42 do you know why this happening?
                                      dc42undefined wilrikerundefined 2 Replies Last reply Reply Quote 0
                                        dc42 administrators @Martin1454
                                        @martin1454 said in Does M906 set RMS or peak current?:
                                        I don't. Trinamic has not made the full details of load sensing public, all we know is that it measures motor back emf. I think the back emf can only be measured during the off-time; so maybe it needs a minimum off-time to work.
                                        Have you checked whether you can get stall detection working again by changing the M915 setting?
                                        • wilrikerundefined
                                          wilriker @Martin1454
                                          @martin1454 I can only say so much that stallGuard is very sensitive to any kind of changes. This means if you change TOFF you probably have to retune stallGuard. It might continue to work without adaption but there is no guarantee it will.
                                          Manuel
                                          My Tool Collection
                                            Please note, the TMC2660 datasheet says that the lowest TOFF setting available must not be used with the lowest TBL setting.
                                            I have just implemented a TOFF parameter in M569. I expect to release beta firmware later today or tomorrow.
