    Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?
    141
    28.9k
    • mindbender9undefined
      mindbender9 @Danal
      Hi @danal,
      I’ll set the top screws to halfway like you recommended.
      ; homedelta.g
      ; called to home all towers on a delta printer
      ; generated by RepRapFirmware Configuration Tool on Sun May 13 2018 19:16:40
      G91                        ; relative positioning
      G1 S1 X282 Y282 Z282 F1800 ; move all towers to the high end stopping at the endstops (first pass)
      G1 X-5 Y-5 Z-5 F1800 S2    ; go down a few mm
      G1 S1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
      G1 Z-5 F6000               ; move down a few mm so that the nozzle can be centred
      G90                        ; absolute positioning
      ;G1 X0 Y0 F6000            ; move X+Y to the centre
      Thanks
        If the carriages don't always move all the way up to the top when you home the printer, then the problem is probably this line in homedelta.g:
        The figure "282" is the maximum distance in mm that the carriages will be moved up during homing. You may need to increase it.
          mindbender9
          I’ve changed the homedelta.g to:
          ; homedelta.g
          G1 S1 X290 Y290 Z290 F1800 ; move all towers to the high end stopping at the endstops (first pass)
          Entering G28 now allows the screws (tightened halfway) to reach the endpoints.
          What would be the next step to do?
          (And thank you for your continued help)
          • Danalundefined
            Danal
            Absolutely what David said. My NON-plus Z-height is 289 in the initial firmware (and its not powered up so I can't see the exact calibration number).
            So, change G1 S1 X282 Y282 Z282 F1800 to something like G1 S1 X300 Y300 Z300 F1800
            Then see if your G28 causes the screws to touch the switches. If it DOES, try another G32. If it does NOT, don't do anything else with the printer until we get that working...
            • Danalundefined
              Danal
              Ah, our posts crossed.
              Now it is OK to do a G32. If I recall, you are set up for manual probing, and are using paper, correct? If so, you can ignore those "deploy probe" errors.
              And/or take the M98 lines out of bed.g.
              • Danalundefined
                Danal
                This post is deleted!
                mindbender9undefined 1 Reply Last reply Reply Quote 0
                  mindbender9 @Danal
                  @danal
                  Thanks for your help. I’ll do a G32 now.
                  Update: The repeated calibration attempts have gouged a deep enough line that the Anycubic printer heat bed sticker has been torn through. I would say that this printer isn't calibrated properly.
                  Do all delta printers go through this?
                  • Danalundefined
                    Danal @mindbender9
                    @mindbender9 said in Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?:
                    @danal
                    No... However, it can be a real struggle to get started with ANY printer from completely scratch.
                    For example, there are assumptions built into the documentation. One example, the entire sequence documented here:
                    https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
                    assumes that the printer is homing (hitting the limit switches) correctly. Without that, NOTHING is 'safe'; bed strikes will occur. Are the words: "The printer MUST physically touch the home switches" written clearly anywhere? Not really...
                    The other big thing, that from your pictures and descriptions I think you may not have been doing: When commissioning a new printer, have your finger on the power switch, and hit it off INSTANTLY if you see something you don't like. Seriously, a power down can save your bed.
                    And... don't get discouraged. You are learning a HUGE amount about ALL printers, and there will be many AHA moments.
                    Last thought: In the grand scheme of things, an Anycubic replacement plastic bed sticker is fairly cheap. I've been through three on my AKL, even though I've never converted the controller board... so, no worries!
                      mindbender9
                      @danal - Thank you for explaining these things that a newcomer is unaware of - and I mean that. I really appreciate the time and patience you (and everyone) are putting in with me.
                      —Here’s what happened last night:
                      Test prints of a 1mm circle start off with the nozzle laying down filament for half the circle “skirt?” and scraping the bed for the other half, with filament being pushed and scattered all over the print area.
                      At roughly 5-10% of the way, the nozzle grinds into half of the circle itself and then lays down filament from 2-3mm above the bed for the other half for a ragged, stringy result. This implies that the bed is lopsided.
                      I’ve rescrewed the “clamps” that hold the bed in place, but it’s still lopsided.
                      • Dumb question #1: How do I flatten the bed? Do I put shims in under the low side? Is the software supposed to compensate for the bed during calibrations? Not sure how to proceed with this.
                      • Dumb question #2: What is the ideal height for a nozzle to be above the bed during printing? What should I aim for during a calibration? 1mm? 2mm? This is one of those “I should know but I don’t” questions.
                      • Dumb question #3: What is the config-override.g file used for? Several people and sources suggest that I should delete the contents of this file if I’m having issues, but I haven’t done so unless things go really bad. Am I doing something wrong?
                      • Dumb question #4: Do I have to perform a manual calibration before every print? By this, I mean the Auto Delta Calibration or (I think) G32. If I do a back to back print (all of which fail), the failing prints get worse in scale each time.
                      • Dumb question #5: Is it wrong to do multiple manual G32’s? The amount of Z height I have to enter for each test point keeps increasing with every attempt.
                        For example, let’s say I have to adjust the first attempt by -5.5 on one particular endpoint. The next attempt on that same endpoint might be -26. Is this normal? What is happening here for the values to keep increasing or the nozzle to keep setting itself higher and higher?
                      Thanks again for the help and encouragement. I really appreciate all of this.
                      • Danalundefined
                        Danal @mindbender9
                        • Question #1: How do I flatten the bed? Do I put shims in under the low side? Is the software supposed to compensate for the bed during calibrations? Not sure how to proceed with this.
                        Eventually, the combination of G32 and G29 will fix this. Just to confirm: Homing is now working, correct?
                        • Question #2: What is the ideal height for a nozzle to be above the bed during printing? What should I aim for during a calibration? 1mm? 2mm? This is one of those “I should know but I don’t” questions.
                        The first layer works best with the nozzle roughly the thickness of a business card above the bed. For PLA. (Some filaments like to be 'squished' on and some like to be 'dropped' on. PLA likes business cards)
                        • Question #3: What is the config-override.g file used for? Several people and sources suggest that I should delete the contents of this file if I’m having issues, but I haven’t done so unless things go really bad. Am I doing something wrong?
                        Several commands, like G32, only update things "in memory" and a power cycle will reset to whatever is in config.g
                        The M500 command really just writes (creates or updates) config_override.g). M501 reads it.
                        The "delete it" advice comes from all of us humans who look in config.g and FORGET that config_override.g exists !!
                        Not if the results are saved via an M500, and loaded via an M501 near the end of config.g. In theory, you should only need to do a G32 and/or G29 if something changes. Like you've removed the bed and replaced it, or changed nozzles, or similar.
                        Personally, I only run G32 M500 G29 when I've done maintenance, and/or when the first layer "just doesn't work" for some reason or another.
                        By the way, just like dogs can smell fear, 3D printers can smell both frustration and complacency. A printer that was working fine will just "be cranky" one day. Maybe it didn't get enough sleep, who knows...
                        • Question #5: Is it wrong to do multiple manual G32’s? The amount of Z height I have to enter for each test point keeps increasing with every attempt.
                        You shouldn't have to enter anything, if you do an M500 to save. The Z Height (H on the M665 in config_override.g) may change a little up or down with each calibration. A few tenths. It should NOT increase after each one. Again checking a basic: Does G28 now cause all three screws to hit all three switches?
                        No problem. We'll slay this dragon together. Obviously, I enjoy it!
                        • Danalundefined
                          Danal
                          Oh, and to clarify:
                          Inconsistently enough:
                          G32 (auto calibrate) requires an M500 to save and a M501 to load. The M501 is most often placed near the end of config.g.
                          G29 (mesh bed level) saves itself... but requires a G29 S1 to load. The G29 S1 is most often put in the start g-code script of the slicer (because several different things can turn it off, best be sure its on just before a print starts).
                          • Danalundefined
                            Danal
                            One more thought: You asked if you should wedge or shim the bed, and I kind of ignored the q. Here's the full answer:
                            A basic assumption check: Be sure the frame of the printer is "Square". Yeah, I know, it is a triangle!!! Seriously, do the best you can to be sure the towers are 90 degrees to the base and the top, the base is flat, etc, etc.
                            This does include doing the best you can to get the bed 90 degrees to all three towers. If the base extrusions are flat, and the towers are dead upright, this should happen naturally... but it is ALL worth checking.
                            Even when G32 and G29 are fully working, they will work best in a square and true set of mechanics.
                            When I did the final assembly and alignment of my BFD (Big Fast Delta), I used a granite slab to do the final alignment of the bottom frame and the top frame. I didn't trust any tables or the floor. (Yeah, I just happened to have access to a granite "flat", machine shop quality, to use for the final assembly).
                              mindbender9
                              Hi @Danal ,
                              • I'm able to home successfully now that I've raised the values higher.
                              • So if the bed is lopsided, then something is not aligned right on my delta? Or the three pillars are not set well? How would I be able to check this, because everything seems rigid?
                              • I still cannot print a base layer - only half is possible and the nozzle drags along the bed which prevents filament from being laid down.
                              Danalundefined dc42undefined 2 Replies Last reply Reply Quote 0
                              • Barracuda72undefined
                                Barracuda72
                                Seems that you have still some mechanical Problems with your frame.
                                As others stated before..make sure that all angles are near perfection. Put the Printer on flattest surface and check if the printbed is at same angle as the frame. On thingiverse there are some bed holder that works good. _( Prob..how to print without a working printer? )
                                Manual calibration could be PITA. Tried it on my Anycubic Kossel too before i upgraded to a duet. If Money is not that big prob, get the smart effector ( working with it is like heaven) or if you want a cheap solution, get a foil switch. Its cheap and works quite well to do a autocalibration and make a highmap. Before i used that switch i tried BLTouch and the original Anycubic switch ( both expensive crap..Delta and a z-probe with a XYZ Offset dont work good)
                                The autocalibration and bedmesh can only compensate mechanical errors to some degree..its not a simsalabim magic wand 😉
                                • Danalundefined
                                  Danal @mindbender9
                                  Loosen the bolts/nuts on the "corners" (really triangles) and move the frame to be more square as you tighten them.
                                  Literally use a "Carpenter's Square" or a "Try Square". This may be where American English and British English confuse things a little, so here are some pictures:
                                  0_1527575176226_2cb59a93-7c46-4326-9c61-11b9dbf29fd4-image.png 0_1527575211725_82df1121-ccb3-4541-be86-572fff967c39-image.png
                                    dc42 administrators @mindbender9
                                    Are you sure the bed is lopsided? If you have an engineer's or carpenters's square, use it to check whether the bed is at right angles to the towers.
                                    That may simply mean that your endstop corrections are not set correctly. Calibration (G32) will fix that.
                                      mindbender9 @dc42
                                      @dc42 said in Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?:
                                      Am I supposed to add shims under the bed? There doesn't appear to be a way to raise/lower the bed mechanically with the Anycubic Kossel Plus. It's just lopsided on one of the three sides.
                                      I performed a manual calibration (G32) and the nozzle did a HARD nose bury into the bed when a test print was attempted. It tore up the blue painters tape that I had on the bed and the test 1mm circle print was a mess. Half of it was missing (the side where the tape was pulled up) and the other half was stringy and a mess.
                                      This is not working.
                                        mindbender9 @Danal
                                        @danal
                                        I don't have a way of acquiring those right angle guides at the moment.
                                        I loosened and readjusted the three pillars as best as I could. The nozzle still buries itself into the bed hard and tears up the surface on half of the print, then releases filament 1-2mm above the bed on the other half.
                                        And this happens after I do a manual calibration (G32).
                                        Could this miserable delta hardware be so screwed up that this kind of results will repeat over and over?
                                        • Danalundefined
                                          Danal
                                          If you can't get a carpenter's square, use anything that you are confident is 90 degrees, and is about the right size.
                                          A heavy card, a plastic cover, your mobile, something.
                                          With the towers reasonably square, and the bed sitting in consistent clips or supports of some sort, there is almost no way for it to be off that much over a span the size of the circles in your photo. Something else is wrong.
                                          By the way, when it digs in like that, TURN IT OFF. Don't let it continue to tear tape, or the plastic bed, or whatever.
                                          Now, back to basics:
                                          Are all six rods the same length? To within 1/10 of a MM? I've seen Anycubics with rods that vary by as much as 1mm across the six. This will cause all kinds of problems.
                                          Is everything at all six attach points to the effector the same? Like this:
                                          Is everything at all three carriages the same? Etc, etc.
                                          Can we please re-verify what is in your latest "config_override.g", after you've done your latest series of G32 and M500? Please post the whole thing.
                                          • Danalundefined
                                            Danal
                                            Oh, and can you please post a video shot in such a way we can see the carriages, the home switches, and the bed, while the printer does a full G32 sequence?
                                            Post to youtube or vimeo or something, and link here.
