    Noctua 5v 40mm fan only running at max power
    2.0k
      You said you're running two of them, are they connected in series, or in parallel?
      bartolomeusundefined 1 Reply Last reply Reply Quote 0
      • bartolomeusundefined
        bartolomeus @Phaedrux
        @phaedrux None of both. One is layer fan, other is hotend fan.
          You can try varying the PWM frequency or adding a blip time of full speed. some fans won't start at low speeds without a true PWM signal.
          Those fans are very quiet. Is there an issue with running them at 100% power? For the layer fan when printing PLA that probably wouldn't be an issue since it's not the most powerful fan to begin with.
          For a good controllable 5v blower Sunon has some good options.
            @phaedrux I agree it probably won't be a big problem for the layer fan. It really doesn't move that much air. I needed my printer to make less noise as its in the living room and this seemed like a good option. However I really doubt it moves enough air..... I'll have a look at the sunons.
              I use the 12v version of that fan for my hotend fan and it seems to perform alright.
                @phaedrux you mean you have the sunon or the noctua for the hotend?
                  Phaedrux Moderator @bartolomeus
                  @bartolomeus Sorry, I meant to say, I use the 12v version of the Noctua 40mm you are using on my Titan Aero and it seems to work fine. I use a 12v Sunon blower fan for the part cooling, but it's not exactly quiet above 50%. However it does have a very wide usable PWM range, which makes it flexible. Sunon also makes 5v versions of blowers which are quite good.
                    @phaedrux thanks for the tips. I am not worried about the hotend fan. I'll see how it performs as layer fan. If it doesn't do well, I'll look for something else.
                      Try varying the PWM frequency as @Phaedrux suggested. In particular, try reducing it.
                      bartolomeusundefined 2 Replies Last reply Reply Quote 0
                        bartolomeus @dc42
                        @dc42 Thanks. It's on tomorrow's to-do list, including the blip time.
                        • mrehorstdmdundefined
                          mrehorstdmd
                          Since the subject is quiet fans here, I recently bought a hot-end via Ali-express and it came with a 24V cooling fan. That fan is about as quiet as the Noctua fan on the Prusa i3 at the makerspace. I know the Noctua fans aren't available as 24V units, so if you're looking for a dead quiet 24V fan you can get them here
                          I haven't had the unit in my printer for long, so I can't say anything about reliability.
                          Unlike most of the inexpensive stuff from China, these things have actual data sheets with real specs.
                            bartolomeus @dc42
                            @dc42 said in Noctua 5v 40mm fan only running at max power:
                            Ok, so did that:
                            at 25,100, 1.000hz and there was no difference
                            tried 25.000 as that is suggested for PWM fans (which this one is not), and now it starts at about 35% power.
                            Should I leave it at this, or look further?
                              Try lower, e.g. 100. High frequencies such as 25000 should only be used with 4-wire fans.
                                bartolomeus
                                I did try lower. 25, 100, 1000, with no effect
