Communication Error (Unexpected token)
Which firmware version, and which DWC version are you running?
Firmware Version: 1.21RC5 (2018-03-16 build 1)
WiFi Server Version: 1.21RC5(16b1)
Web Interface Version: 1.21-RC4
As you are using RC firmware, I suggest you upgrade to the 1.21 release, or to 2.0beta3.
ok, I just have updated to what i found in https://github.com/dc42/RepRapFirmware/releases/tag/2.0RC1
Firmware Version: 2.0(RTOS)RC1 (2018-05-02b1)
Web Interface Version: 1.21.1-RC1should I also update the WIFI Server ? if yes where is the last version ?
thank you
Yes, latest WiFi server version is 1.21.
@dc42 said in Communication Error (Unexpected token):
To add to David's answer: Wifi Server 1.21 download link
thank you !
I am getting the same error. Two prints bombed so far.
Firmware Version: 1.21 (2018-03-21)
Web Interface Version: 1.21 -
@stavrosgmtl said in Communication Error (Unexpected token):
Web Interface Version: 1.21WiFi disconnection errors don't in themselves affect printing, the print will just carry on.
@paboman said in Communication Error (Unexpected token):
thank you !
Did upgrading the firmware resolve your issue?
Yes -
I downgraded to 1.20, i probably confused the error, will retest 1.21 later after my printing is done.
