    It's out! RepRapFirmware 2.0 and 1.21.1 released
    Firmware installation
    25
    81
    15.7k
    • timcurtis67undefined
      timcurtis67
      I updated to this version from the last RC and have had many issues with DWC not connecting. When I try to connect through the DWC my DuetWifi locks up? The panel due still shows a screen but I can't do anything with the buttons. The hot end fans shut off right away even though the hotends are at printing temperature.
      I updated with these 3 files from the link.
      Duet2CombinedFirmware.bim
      DuetWiFiServer.bin
      DuetWebControl-1.21.1.zip
      If I don't use the DWC I can run my printer with a small issue. Last night I ran a 8 hr print without any problems. This morning I was starting a print thru Paneldue and the printer just sat idle. like I didn't choose the gcode file. So I hit the SD icon to re-select a print file and it showed zero files on the disk. I turned the printer off and back on and everything worked fine. I was able to start my print just like I always do.
      Background info,
      When I did the update everything went well, no problems with any of the updates. Then I went to home the printer and got an error that there was not homeall.g file. I checked the system file list and no files were present? This was while using the DWC. So I restarted my printer and the DWC and the DWC has never connected again? I can run through the paneldue but not the DWC, it just locks up my DuetWiFi board.
      Did I miss something? I have never had an issue with updates before.
      Please advise,
      I use google chrome for the DWC.
        dc42 administrators @timcurtis67
        @timcurtis67 said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
        DuetWiFiServer.bin
        Background info,
        Please advise,
        I'm sorry to hear you are having problems. Which firmware version were you running before?
        I suggest you connect via USB using YAT or pronterface on a PC and send M122 to get a diagnostic report. Also send M39 to check the SD card status (you can also do the M39 from PanelDue). Firmware 1.20 and earlier weren't too fussy if the card detect pin on the SD card socket wasn't working, but 1.21 and 2.0 have tightened this up.
          timcurtis67
          @dc42 I was running 2.0RC6. I will try to use the USB tonight to get the M122 report.
          I wanted to try reinstalling all 3 firmwares to make sure I didn't get one mixed up with an older one. I was pretty careful but anything is possible....
          Can I re install the DuetWifiServer.bin file and the DuetWebControl-1.21.1.zip via USB? I'm not sure how to do it that way?
          Also maybe something is up with my SD card if you "tightened" up the SD card detect pin? I will try removing and re-inserting the SD card before I try anything else.
            The DuetWiFiServer.bin file hasn't changed since version 1.21.
            If you want to reinstall Duet2CombinedFirmware.bin and DuetWiFiServer.bin using USB, you will need to move the SD card to a PC and copy those files into the /sys folder. Then with the SD card back in the Duet, restart the Duet. Send M997 S1 to install the wifi binary, and M997 S0 to install the main binary (it will disconnect while you do this, but you should be able to reconnect about 30 seconds later).
            To upgrade DWC, with the SD card in the PC you can rename the /www folder to /www-old, create a new /www folder, and extract the contents of DuetWebControl-1.21.1.zip into it.
              timcurtis67
              Thank you David. I will try that tonight after I try re-inserting the SD card. I'm hoping that I don't have a bad SD card detect pin (maybe it's been that way all along). The more I think about it the more it seems like that is the issue.
              What would be the "work around" if that turns out to be the case?
              • BMMalundefined
                BMMal @dc42
                @dc42 said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
                Are you sure? I have just compared the documentation with the code and they agree:
                P1 - high when filament present, low when no filament
                P2 - low when filament present, high when no filament
                I was not getting responses from M122 or even M572. I disconnected DWC and could not reconnect.
                After power cycling the machine, these are the diagnostics:
                Sadly the diagnostics don't indicate anything wrong. If it happens again, if possible please connect via USB and YAT/pronterface etc. and see if you can get a M122 report that way without restarting.
                I think someone below figured out my confusion between the m591 response and the wiki info.
                I came in this morning and had the same issue where the machine did not give a response to M122 via DWC. I connected with YAT without resetting the machine. Not sure how to get YAT to better format the response but here it is:
                === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet Ethernet 1.02 or later + DueX5<LF>Board ID: 08DDM-9FAM2-LW4SD-6JTDL-3S86R-KJW3X<LF>Used output buffers: 1 of 20 (16 max)<LF>=== RTOS ===<LF>Static ram: 28380<LF>Dynamic ram: 96552 of which 0 recycled<LF>Exception stack ram used: 468<LF>Never used ram: 5672<LF>Task NETWORK ready, free stack 324<LF>Task HEAT blocked, free stack 1200<LF>Task MAIN running, free stack 3568<LF>=== Platform ===<LF>Last reset 14:29:18 ago, cause: power up<LF>Last software reset at 2018-06-05 17:43, reason: User, spinning module GCodes, available RAM 5864 bytes (slot 1)<LF>Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff<LF>Error status: 24<LF>Free file entries: 9<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms<LF>MCU temperature: min 26.8, current 27.3, max 27.5<LF>Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0<LF>Driver 0: standstill, SG min/max not available<LF>Driver 1: standstill, SG min/max not available<LF>Driver 2: standstill, SG min/max not available<LF>Driver 3: standstill, SG min/max not available<LF>Driver 4: standstill, SG min/max not available<LF>Driver 5: standstill, SG min/max not available<LF>Driver 6: standstill, SG min/max not available<LF>Driver 7: standstill, SG min/max not available<LF>Driver 8: standstill, SG min/max not available<LF>Driver 9: standstill, SG min/max not available<LF>Expansion motor(s) stall indication: yes<LF>Date/time: 2018-06-06 08:14:33<LF>Slowest loop: 4.38ms; fastest: 0.09ms<LF>=== Move ===<LF>Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0<LF>Scheduled moves: 12, completed moves: 12<LF>Bed compensation in use: none<LF>Bed probe heights: 0.000 0.000 0.000 0.000 0.000<LF>=== Heat ===<LF>Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1<LF>Heater 0 is on, I-accum = 0.0<LF>=== GCodes ===<LF>Segments left: 0<LF>Stack records: 4 allocated, 0 in use<LF>Movement lock held by null<LF>http is idle in state(s) 0<LF>telnet is idle in state(s) 0<LF>file is idle in state(s) 0<LF>serial is ready with "m122" in state(s) 0<LF>aux is idle in state(s) 0<LF>daemon is idle in state(s) 0<LF>queue is idle in state(s) 0<LF>autopause is idle in state(s) 0<LF>Code queue is empty.<LF>=== Network ===<LF>Slowest loop: 1.03ms; fastest: 0.01ms<LF>Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)<LF>HTTP sessions: 0 of 8<LF>Interface state: 5<LF>=== Filament sensors ===<LF>Extruder 0 sensor: no filament<LF>Extruder 2 sensor: ok<LF>=== Expansion ===<LF>DueX I2C errors 0<LF>ok<LF>
                Duet Ethernet - Most likely the most recent Edge firmware
                Duet X5
                7" Panel Due V2
                Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                  Here is a photo showing the position of the CD pin.
                  Take a look at it, using magnification if possible, and see whether it looks properly soldered to the pad or is just resting on top of it.
                  If the CD pin does cause issues then in recent firmware versions you should see error messages telling you that the SD card has been removed with open files on it.
                  timcurtis67undefined 1 Reply Last reply Reply Quote 0
                    timcurtis67 @dc42
                    @dc42 Thank you, I will check it out tonight and advise.
                    • demonio669undefined
                      demonio669
                      dc42, what happens if you have a 0 bytes config.g ? should the firmware run config.g.bak ?
                      I have several times a 0 bytes config.g after power-off cycle
                      • BMMalundefined
                        BMMal
                        To expand further on my issue of not getting responses, it seems that DWC is somehow getting out of sync but not disconnecting ie, a print was started and it did not automatically go to the Print Status screen. DWC still indicated that the machine was connected. I made a change to config.g, the file got updated (confirmed by looking after saving) and DWC asked if I wanted to reboot as if the machine was not printing even though it was. Manually going to the status page, it did not appear that the machine was printing. Refreshing the browser did however update properly.
                        Duet X5
                        7" Panel Due V2
                        • Knaudlerundefined
                          Knaudler
                          Hello
                          little Problem with
                          Web Interface Version: 1.21.1
                          there is only 1 Fan slider
                          on 1.21 you have sliders for all 3 PWM Fans (if activated)
                          thanks
                          Ingo (Knaudler)
                            timcurtis67
                            @dc42 I got my install working perfect now. I tried taking the SD card out a few times but that made no difference so I copied the firmwares to my SD card and activated the installs with my PanelDue. It worked great that way. No need for USB interfacing.
                            On a side note I did notice when I was having my issues with the first install I saw that the blue LEDs were lit up in the Wifi module but not blinking and they were barely lit. If that means anything?
                            I must have gotten a bad install on one of the firmwares the first time but all is well now.
                            Thank you for the help!
                            • Catalin_ROundefined
                              Catalin_RO
                              Using it on WorkBee since released. No problems so far!
                              • ChrisPundefined
                                ChrisP
                                I have some Duest 06 that I'm still having the same issues with as was mentioend previously in 1.20 with regards to not using static IPs (https://forum.duet3d.com/topic/3508/firmware-1-20-released/75).
                                To confirm, if a static IP isn't provided using M552 then the Duet will work fine and can be controlled over USB and/or a PanelDue as long as the ethernet is disconnected. Before plugging in the ethernet, this is the output of M112:
                                RepRapFirmware for Duet version 1.21.1 running on Duet 0.6
                                Used output buffers: 1 of 16 (2 max)
                                === System ===
                                Static ram: 44628
                                Dynamic ram: 41348 of which 40 recycled
                                Stack ram used: 2920 current, 4400 maximum
                                Never used ram: 7888
                                Last reset 00:00:07 ago, cause: power up
                                Last software reset time unknown, reason: Stuck in spin loop, spinning module Network, available RAM 7080 bytes (slot 2)
                                Software reset code 0x2041 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0440f80f, BFAR 0xe000ed38, SP 0x20087cdc
                                Stack: 000c4127 00000001 fffffff9 20087b98 20087c41 80000000 00000001 2007a524 000ac0bd 000ac0bc 61000000 000000b5 00000004 000bdcd9 000afa53 0000003a 00000001 00000006 2007a900 20087d56 2007aa40 20087d90 20087d50 00000023
                                Error status: 0
                                Free file entries: 10
                                SD card 0 detected, interface speed: 21.0MBytes/sec
                                MCU temperature: min 30.3, current 36.6, max 36.6
                                Slowest loop: 1.16ms; fastest: 0.10ms
                                Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 100, MinFreeDm 100, MaxWait: 0ms, Underruns: 0, 0
                                Bed heaters = 0, chamberHeaters = -1 -1
                                Segments left: 0
                                serial is ready with "M122" in state(s) 0
                                === Network ===
                                Free connections: 16 of 16
                                Free transactions: 24 of 24
                                Locked: 0, state: 2, listening: 0, 0, 0
                                ok
                                Immediately after plugging in the ethernet, this is the output:
                                Used output buffers: 1 of 16 (7 max)
                                === System ===
                                Static ram: 44628
                                Stack ram used: 2920 current, 5128 maximum
                                Never used ram: 7160
                                Last reset 00:00:48 ago, cause: power up
                                Error status: 0
                                MCU temperature: min 36.6, current 39.5, max 39.6
                                Slowest loop: 3.99ms; fastest: 0.10ms
                                Segments left: 0
                                === Network ===
                                Locked: 0, state: 3, listening: 0, 0, 0
                                ok
                                Shortly after, however, everything locks up and neither the serial over USB or PandelDue respond. After unplugging the ethernet, and waiting a short while (without power-cycling or resetting) I can issue an M122 again, and this is the response:
                                === System ===
                                Static ram: 44628
                                Last reset 00:00:12 ago, cause: software
                                Last software reset time unknown, reason: Stuck in spin loop, spinning module Network, available RAM 7884 bytes (slot 0)
                                Software reset code 0x2041 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0440f80f, BFAR 0xe000ed38, SP 0x20087e64
                                Stack: 000c4127 00000001 fffffff9 89cdcd64 20087ebc 20070ff4 00000001 20087ebc 000aac3d 000a9c2c a1000000 20073788 2007a868 0000012c 00000113 00000000 20073778 200737b4 0000011f 2007add8 000000f0 00000045 81cdcd89 20073778
                                Error status: 0
                                MCU temperature: min 39.3, current 39.9, max 40.3
                                Slowest loop: 1.17ms; fastest: 0.10ms
                                Segments left: 0
                                === Network ===
                                ok
                                • ChrisPundefined
                                  ChrisP
                                  I have just tried the same on an 85 board and can confirm that it does the same. Dropping back down to 1.19 makes everything work again (minus the new features ofc).
                                    dc42 administrators @demonio669
                                    @demonio669 said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
                                    Only in the version 2.0 release firmware.
                                      dc42 administrators @Knaudler
                                      @knaudler said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
                                      Hello
                                      little Problem with
                                      thanks
                                      Ingo (Knaudler)
                                      With DWC 1.21.1 and RRF 2.0/1.21.1 you are able to control all fans that are not set up as thermostatically controlled.
                                      Knaudlerundefined 1 Reply Last reply Reply Quote 0
                                        dc42 administrators @ChrisP
                                        @chrisp said in It's out! RepRapFirmware 2.0 and 1.21.1 released:
                                        I have tried to reproduce this issue before several times, without success. But if you make your config.g file available, I'll try once again.
                                        ChrisPundefined 1 Reply Last reply Reply Quote 0
                                        • Knaudlerundefined
                                          Knaudler @dc42
                                          Hello
                                          little Problem with
                                          thanks
                                          Ingo (Knaudler)
                                          could I change this behavior in reprap.htm ?
                                          unhidden ?
                                          thanks
                                          • ChrisPundefined
                                            ChrisP @dc42
                                            Thanks, that would be great!
                                            Below are two config file from two very different printers one uses an 06 board, the other uses an 85 board - the problem on both boards is the same. With any FW later than 1.19, the ethernet connectivity is broke. If a static IP isn't specified then the board constantly boot loops. If a staic IP is defined, the boards will boot but I still can't access the web interface either by printer name or IP.
                                            The first is my own printer that I often take into work and use there. Its a pretty standard setup and uses the 06 board with a PanelDue:
                                            ; Communication and General
                                            M111 S0 ; Debug off
                                            M555 P2 ; Set output to look like Marlin
                                            M550 PStarttEx ; Machine name
                                            M551 Preprap ; Machine password (used for FTP)
                                            M540 P0x36:0x18:0x70:0x4E:0xDB:0x00 ; MAC Address
                                            ;M552 P<removed> ; IP address
                                            M552 P0.0.0.0 ; IP address
                                            M553 P255.255.255.0 ; Netmask
                                            M586 P0 S1 R80 ; Enable HTTP/HTTPS
                                            ;M586 P1 S1 R21 ; Enable FTP/SFTP
                                            ;M586 P2 S1 R22 ; Enable Telnet/SSH
                                            ; Workmode
                                            G21 ; Work in millimetres
                                            ; Motor Configuration
                                            M569 P0 S0 ; Drive 0 (x) goes backwards
                                            M569 P1 S1 ; Drive 1 (y) goes forwards
                                            M569 P2 S0 ; Drive 2 (z) goes backwards
                                            M569 P3 S0 ; Drive 3 (e) goes backwards
                                            M906 X900 Y900 Z900 E900 ; Set motor currents (mA)
                                            ; Axis Configuration
                                            M574 X1 Y1 Z2 S1 ; X and Y endstop at min end, Z at max end, active high
                                            M92 X80.0 Y80.0 Z1600.0 ; Set axis steps/mm (GT2)
                                            M201 X2000 Y2000 Z100 E10000 ; set max accelerations (mm/s^2)
                                            M203 X18000 Y18000 Z600 E3600 ; set max feedrates (mm/min)
                                            M204 P10000 T10000 ; set max print and travel accelerations (mm/s^2)
                                            M566 X600 Y600 Z30 E600 ; set max inst. speed change (jerk) (mm/min)
                                            ;M201 X2000 Y2000 Z100 E5000 ; set max accelerations (mm/s^2)
                                            ;M566 X600 Y600 Z30 E120 ; set max inst. speed change (jerk) (mm/min)
                                            M208 X155 Y125 Z131.45 ; set axis maxima
                                            M208 X-19.5 Y-1.5 Z0 S1 ; set axis minima (make X=0 and Y=0 the edge of the bed after homing)
                                            ; Temperature Sensor Parameters
                                            M305 P0 R4700 T100000 ; Bed
                                            M305 P1 R4700 T100000 B4725 C7.06e-8 ; Hot end
                                            ; Tool Definitions
                                            M563 P0 D0 H1 ; Define tool 0
                                            G10 P0 S200 R0 ; Set tool 0 operating and standby temperatures
                                            ; Gain (A) | Time constant (C) | Dead time (D)
                                            M307 H1 A437.5 C48.6 D4.6 B0 ; Model based hotend temperature control from an autotune (over-ridden in config-override.g)
                                            M92 E410 ; Set extruder steps per mm
                                            ; Z Probe
                                            M558 P0 ; Z probe is not present
                                            ; Axis Compensation
                                            M556 S78 X0 Y0 Z0 ; Axis compensation
                                            ;M581 E1 S1 T1 C1 ; Execute pause script when triggered and currently printing
                                            M501 ; run config-override.g
                                            The second has 5 axes and a past extruder and uses an 85 board:
                                            ; Configuration file for Paster
                                            M111 S0 ; Debug off
                                            M550 PPasteEx ; Machine name
                                            M551 PPreprap ; Machine password
                                            M540 P0xBE:0xEF:0xDE:0x76:0xFE:0xED ; MAC Address
                                            ; Workmode
                                            M569 P0 S1 ; X Drive 0 goes forwards
                                            M569 P1 S1 ; Y Drive 1 goes forwards
                                            M569 P2 S0 ; Z Drive 2 goes backwards
                                            M569 P3 S1 ; U Drive 3 goes forwards
                                            M569 P4 S1 ; V Drive 4 goes forwards
                                            M569 P5 S1 ; E0 Drive 5 goes forwards
                                            M906 X800 Y800 Z1600 U1000 V1200 E1000 ; Set motor currents (mA)
                                            M906 I50 ; Set motor idle factor
                                            M584 X0 Y1 Z2 U3 V4 E5
                                            M574 M574 X1 Y1 Z2 S0 ; end stops
                                            M574 V1 S1
                                            M92 X80 Y80 Z400 U88.9 V32 ; Set axis steps/mm
                                            M350 X16 Y16 Z16 U16 V16 E16
                                            M201 X800 Y1800 Z500 U200 V200 E1000 ; Accelerations (mm/s^2)
                                            M203 X2000 Y2000 Z1500 U1500 V1500 E3600 ; Maximum speeds (mm/min)
                                            M566 X1200 Y1200 Z50 U1000 V1000 E500 ; Maximum instant speed changes (mm/min)
                                            M208 X190 Y270 Z194.8 V190 ; set axis maxima
                                            M140 S-273.15 H-1
                                            ; Tool Definitions
                                            M563 P0 D0 S"Paste extruder"
                                            G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
                                            M92 E913 ; Set extruder steps per mm
                                            ; Z Probe
                                            ; Axis Compensation
