    Up and running
    • mrehorstdmdundefined
      mrehorstdmd
      UMMD is now up and running with Duet Ethernet and Panel Due. I still have some fine tuning to do, but everything seems to be working as it should. First test print here..
      It's a LOT quieter than it used to be!
      Thanks to all who helped get it running.
      I'll be adding a blog post on the conversion from SmoothieBoard to Duet shortly.
      T3P3Tonyundefined 1 Reply Last reply Reply Quote 3
        I'm glad to hear that you are up and running with the Duet! Please share your experience of what aspects of using and configuring the Duet you found well-documented, and which areas of the documentation you feel need to be improved.
        I have confirmed that configtool incorrectly generates a M301 command when you set the chamber heater to bang-bang. We will fix that.
          T3P3Tony administrators @mrehorstdmd
          @mrehorstdmd Great, looking forward to reading the blog post!
