    DAMNED CRASH - Stuck in spin loop
    Firmware installation
    2.5k
    • gate546undefined
      gate546 @dc42
      thank you for your quick answer...:😊
      @dc42 said in DAMNED CRASH - Stuck in spin loop:
      I'm sorry to hear that you had a reset so close to the end of a long print.
      I have examined the stack trace, but unfortunately I can't tell anything from it because for this type of reset (stuck in spin loop), I need a longer stack trace. I will amend the stack trace in the 2.01 release to provide more information.
      The most likely causes of the reset that I can think of are:
      1. An electrical transient causing the board to malfunction. Can you confirm that you did not have a USB connection to the Duet at the time? Were any large items of electrical equipment turned on or off around the time of the reset?
      This is not possible because the printer have a dedicated UPS, that is also filtered
      1. A failure of the SD card interface to either return the requested data or time out. I have seen evidence of this happening in the past, but not recently. I will change the stack trace information to record whether an SD card timeout had been logged at the time of the reset.
      This is at least unlikely because for a long time it never happened
      1. An undiagnosed firmware issue.
      I do not know if it can help you, but maybe it could be a problem on the WEB Server part, the only thing I did was to connect with a browser (local) to see the progress
      the printer was printing autonomously and never connected before.
      Hoping that this will help your troubleshooting 😉
      Cheers
      Dommy
      (just started again the long print crossing the finger...)
      timcurtis67undefined Phaedruxundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • timcurtis67undefined
        timcurtis67 @gate546
        @gate546 said in DAMNED CRASH - Stuck in spin loop:
        I ran into a similar issue last week with a few failures (2 during random prints) near the end of long prints. I replaced the SD card with a new one and the issue went away.
        I tried re-formatting the old card but the problem still came back after a few good prints. So I went to a new SD card and had no problems after that.
        I never had an issue with my SD card until I started having an issue with my SD. Sometimes they work until they don't work anymore.
        gate546undefined 1 Reply Last reply Reply Quote 0
        • gate546undefined
          gate546 @timcurtis67
          @timcurtis67 said in DAMNED CRASH - Stuck in spin loop:
          Thank you to share...
          Dommy
          timothyzundefined 1 Reply Last reply Reply Quote 0
          • denkeundefined
            denke
            Isn't it possible to manually craft a resurrect file to continue such a print?
            If any additional information is needed to craft one, cannot it be added to the dump?
            (Maybe even auto create a resurrect file on a post-crash bootup?)
            • timothyzundefined
              timothyz @gate546
              @gate546
              I had a similar issue, it was resolved by reformatting with a larger allocation unit size (the largest possible). that resolved a number of issues and made a number of things work better.
              -Tim
                Phaedrux Moderator @gate546
                I used to use a UPS on my old printer, but I stopped when one day the printer suddenly stopped and restarted in the middle of a print while I was sitting next to it. I looked over at the UPS and saw that it was doing an automatic self-test. The self-test is not supposed to interrupt power but I think due to the high load of the bed heater the voltage drooped enough to reset the controller.
                Just a thought.
                  dc42 administrators @gate546
                  Did the reset occur immediately after you connected the web browser, or some time later?
                  gate546undefined 2 Replies Last reply Reply Quote 0
                  • gate546undefined
                    gate546 @dc42
                    This post is deleted!
                    • gate546undefined
                      gate546 @dc42
                      Immediately, or better, immediately as soon as have launched the browser, in fact the browser was not connected, remain on connecting status then I look the printer and I see that the printer was stopped, crashed, without any apparent problem, only stopped.
                        Thanks, it does sound that connecting the browser may have triggered the problem. I'll do some more tests on connecting a browser while a print is in progress.
                        • gate546undefined
                          gate546 @gate546
                          One more info, the involved gcode file is over a normal SD card that is installed on the 7" Panel and NOT on the micro SD Card that is inside the Duet Wifi board
                          Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            @gate546 How long was the cable between the panel and the Duet? What type of cabling is used?
                            • gate546undefined
                              gate546 @dc42
                              this sound goods....
                              I hope that you are able to replicate the issue.
                              • gate546undefined
                                gate546 @Phaedrux
                                @phaedrux said in DAMNED CRASH - Stuck in spin loop:
                                the TFT panel and the board are very close, 25 cm. of wire, 1 inch.
                                the cable is a normal quadripolar cable, single wires, with connectors on both sides.
                                However we need to remember a point, this printer worked from a couple of years without any problems, and I also have printed very long files without difficulty.
                                This thing happened only now, in conjunction with the firmware change.
                                Since the new firmware is RTOS, then with separate tasks, I'm trying to provide DC42 as much information as possible because, maybe, they are useful for help it for troubleshooting this issue.
                                  @gate546 Yes, of course. Merely chasing down possibilities.
                                    That may be very relevant. The SPI link to the SD card on the PanelDue doesn't have the same hardware timeout mechanisms as the interface to the micro SD card. Also if the ribbon cable is too long then the signal integrity may be degraded. For best reliability, I recommend printing from the micro SD card.
                                    Do you have any other SPI-connected devices, for example a PT100 or thermocouple daughter board?
                                    • gate546undefined
                                      gate546 @dc42
                                      the cable is very short, 25cm plus or minus and yes there is a PT100 daughter board installed.
                                      You suggest to use the micro SD instead? I have some doubts with the micro SD Card due to their structure....
                                      • gate546undefined
                                        gate546
                                        David, just for information, to close the circle.
                                        The same long print that caused the crash I wrote before, ended happily without any kind of problems ☺
                                        Same machine, same SD card, all the same, the difference is that I never tried to connect to printer with the browser. ☠
                                        Perhaps we should investigate very well in this field.
