    24v Heatbed with 12v everything else
    30
    5.0k
    • Vaeiundefined
      Vaei
      I have a second 24v PSU and want to use it solely for the heat bed. Everything else is running 12v.
      I just wanted to check, will it be fine to wire the 24v heatbed directly into the 24v PSU instead of the mainboard?
      Cheers
      • pro3dundefined
        pro3d
        This is just a guestimate from me so do some reasearch..
        I run 220V heatbed and use a Solid state relay as a switch controlled by the bed-out on the duet to control heating of the bed. I think you must do something similar for your setup
        Valkyrie DIY High Temp 3D Printer
        R&D - Engineering Designer - Viking 3D Printers
        https://vkingprinter.com/
          You can connect your 24V bed heater between the +ve output from the PSU and the BED- pin of the bed heater terminal on the Duet. Leave the bed heater VIN terminal of the Duet unconnected. Connect the negative output of the 24V PSU to the negative VIN terminal on the Duet, along with the negative wire from the 12V PSU.
          Vaeiundefined 2 Replies Last reply Reply Quote 0
          • Vaeiundefined
            Vaei @dc42
            @dc42 said in 24v Heatbed with 12v everything else:
            Perfect, thank you once again!
            • Vaeiundefined
              Vaei @dc42
              My parts finally arrived and I got around to trying this but I'm a bit confused - You say to plug BOTH the 12v and 24v psu into the power VIN on the DUET? It's not going to burst into flames is it?
              I drew a quick diagram based on what you said, I want to be sure I have it right before I proceed. Could you confirm it's accurate?
              If you're coming from Google DO NOT use this - it's wrong
                That's not right.
                Both PSU negative outputs go to the ground pin on the VIN terminal block (power GND). The + output of the 12V supply goes to the + pin on the VIN terminal block. The + output of the 24V supply goes to one end of the bed heater.
                • Vaeiundefined
                  Vaei
                  That's not right.
                  Thanks 🙂 I think I understand now, one more time in the interest of not starting house fires:
                  • DjDemonDundefined
                    DjDemonD
                    I'd like to throw in a second way, just in case the method outlined above doesn't suit you.
                    Get an external mosfet board (they are £5) . Optoisolated, they run from your bed heater output on the duet (12v is fine for this "signal") when the bed comes on the 12v signal switches the mosfet on the external board. Your 24v PSU is connected only to the external board, and through it the bed. I have a machine in this configuration.
                    Advantages:
                    Complete electrical isolation of 24v and 12v supplies.
                    No high current switching on your duet (I know compared to lesser boards they can do it but I like not switching so many amps on my most expensive component)
                    Disadvantages
                    None that I can think of (except spending £5).
                    www.precisionpiezo.co.uk
                    Vaeiundefined 1 Reply Last reply Reply Quote 1
                    • Vaeiundefined
                      Vaei @DjDemonD
                      @djdemond said in 24v Heatbed with 12v everything else:
                      Advantages:
                      Disadvantages
                      These? https://www.amazon.com/gp/product/B06XY5HBFX/
                      I have four of them sitting in a box collecting dust.
                      I can think of one disadvantage, and that's having an extra board to account for when making an enclosure etc but that doesn't bother me.
                      • DjDemonDundefined
                        DjDemonD
                        Yep those are the things. If you have a 1 PSU system and your bed is below the 18A suggested limit, then they are probably an extra bit of kit you don't need. But a 2 PSU system is easily setup using one of these. Plus you get the highest current part of the system off the duet board - not a bad idea really.
                        Those smaller ones will work for most application they do make an even larger one
                        But I did buy one of these, they are massive could probably handle 50A+
                        Vaeiundefined 1 Reply Last reply Reply Quote 2
                        • Vaeiundefined
                          Vaei @DjDemonD
                          @djdemond Ah thanks!
                          So these have a 'ctrl in', a power+/- (dc in) and bed+/-
                          The ctrl in takes a 2 pin connector - do I use ctrl in for this?
                          I think I need a more detailed rundown if you can spare the time 🙂
                          From what you've said this is what I gather, but I'm still unsure about the ctrl in and BED- in particular
                          • DjDemonDundefined
                            DjDemonD
                            Everything there looks good, except you feed the CTRL in from the Duet Bed heater output - the big screw terminals. It doesn't matter that its massively oversized, the CTRL in will only draw a few milliamps from the duet bed heater. Make sure the + and - are correct, I don't believe you will do any damage if they are wrong but the system either won't work or will behave oddly. Usually the mosfet board will have an LED on it, which lights up when it is active, so you might see it flickering when using PWM control thats normal. If using bang-bang it will be either on or off. PWM is better but then for beds with reasonable thermal mass bang-bang will maintain a set temp without any problems.
                            Vaeiundefined 1 Reply Last reply Reply Quote 0
                            • Vaeiundefined
                              Vaei @DjDemonD
                              @djdemond
                              So just to confirm, I feed both the Bed VIN and Bed- to the Ctrl terminal? Are you sure VIN is needed?
                              Cheers
                              • DjDemonDundefined
                                DjDemonD
                                Okay so the heated bed normally has a + and - output. You need to connect them to the + and - of the CTRL-in on the mosfet board (sometimes labelled bed + & - or signal + & -) otherwise, the mosfet board cannot tell when you've turned the bed on. It's electrically isolated from the second power supply, so for the control side of the mosfet board to be able to tell if there is a signal present it needs a circuit of some sort, connecting one wire isn't going to create a voltage it can detect and then switch on the optocoupler which in turn opens the large mosfet to power the bed up.
                                What is your reservation about doing this? If it's that it seems wrong to connect the bed output to a signal input, remember a heater only draws the power its resistance allows it to. So if you connect a bed heater to the bed heater output and its 12v and has a resistance of 0.72 ohms for example, then it will draw 16.66amps. If you connect a small transistor and a few resistors (the low current side of the mosfet board) then it will draw a few milliamps.
                                Those of us using mains heated beds are using SSR's which is just a version of a mosfet board than can handle AC mains 240v on one side, but accepts 2 tiny wires from the duet heated bed output as the control signal.
                                • Vaeiundefined
                                  Vaei
                                  CTRL-in and Bed+/- is not the same thing. You can not connect a heated bed to CTRL-in. CTRL-in also does not have a polarity.
                                  There is a DC IN+/-, Bed+/-, CTRL-In.
                                  • DjDemonDundefined
                                    DjDemonD
                                    We are not talking about any of the BED power wires or wires to/from the PSU, we are talking about where to connect the signal wire, the answer is to the duet's heated bed output. My understanding is that polarity is usually important but not harmful if wrong, so try it whichever way around you wish, if it works you're good.
                                    See the diagram post Vaei 5 Jul 2018, 12:51 above. The CTRL in goes to the duet bed heater + and - which are the only two connections in that diagram that Vaei was unsure about it.
                                    I have the same setup (2 PSUs and a small mosfet the same as shown above). If you want me take a photo of it when I get home this afternoon I will do.
                                    • Vaeiundefined
                                      Vaei @DjDemonD
                                      @djdemond Thank you! It works 🙂 However heats extremely slow, which is possibly because I haven't run an autotune yet since using the previous 12v bed. I'm putting MGN12 rails on the Y axis tomorrow, so will install it properly and do the autotune etc then.
                                      • DjDemonDundefined
                                        DjDemonD
                                        Autotune won't affect heat up times.
                                        You can check your mosfet board, just connect the bed directly to the PSU, start a timer, and measure the temp, don't leave it unattended 🙂 when it hits whatever temp your aiming for disconnect it. It should heat up just as fast with the mosfet.
                                        WHat bed (amps or watts) and PSU (24v yeah? what amps or watts) are you using?
                                        • Vaeiundefined
                                          Vaei @DjDemonD
                                          @djdemond 200W / 8.33A 24V heat bed, 350W / 14.6A 24V PSU
                                          ..Just realized, the mosfet is 12V. Or at least that's what the Amazon page says. But if I google for 24V mosfet I'm not getting any useful results.. Amazon page also claims it can handle 25A.
                                            T3P3Tony administrators @Vaei
                                            @vaei 12V sounds Odd for a mosfet rated to handle 25A and in that package. A little bit of investigation:
                                            DG210N06 is the model number - you can buy them off aliexpress etc. I cannot find a datasheet for them anywhere!
