    Burnt cable from 5v
    • npm1undefined
      npm1
      Hi guys,
      i connected the bltouch incorrectly by accident, from which point my cable coming from the 5v had started getting hot,
      Now the servo on the touch doesn't work and the BLtouch only goes into error.
      when using the m280 command to deploy the pin, it doesn't do anything.
      Have i destroyed something on my BLtouch or have i destroyed something on my duet.
      Please Help
      Ender 5 pro(LGXextruderddewith e3d revo rapid changer) with fly rrf e3 and a standard prusa mk3, both siting air-tight in a ikea kitchen cabinet.
        T3P3Tony administrators @npm1
        @npm1 did you connect to the 5V pin on the expansion header? If so then it's most likely that the BL touch is damaged but hopefully not the Duet. Is the Duet working correctly otherwise?
