    Switch Z-probe not inverting
    4.3k
    • madmattcoundefined
      madmattco
      M119
      Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop
        deckingman @madmattco
        @madmattco
        Sorry, I meant run M119 with the switch both triggered and not triggered. So as it is, the firmware reads that its is triggered. Now trigger the switch and run M119 again and it should say "not stopped". If thta works, then the logic is inverted and you need to change it. If it shows "at min stop" whether the switch is triggered or not, then it would indicate a wiring problem or faulty switch, rather than a configuration/ firmware issue.
          madmattco
          If i trigger it, M119 still shows the same. But I can see the E0 endstop changing in the machine properties tab
            deckingman
            That's odd. Try adding Z1 to your M584. You should only need it with firmware 1.19 or earlier but .....
              madmattco
              I dont think it liked that. This is on a delta btw. Sorry for forgetting to mention that in the first place
                @madmattco said in Switch Z-probe not inverting:
                Ahhhh. Yes, sorry - I know nothing about Deltas (strange mystical devices☺ ) .
                  madmattco
                  Do you think I would have better luck if i issued a P5 or P7 instead of P4 on M558?
                    Not if you've wired it E0. According to the Wiki, P5 is for the Z probe connector and P7 is for the Z end stop connector. Having said that, I don't know if it makes any difference or if you have to use a different connector on a Delta. I know they home at Z max but that's the limit of my knowledge. Sorry but I'm fresh out of ideas. Hopefully, someone more knowledgable than I will step in and help you out.
                      deckingman
                      Just looking through the wiki, you may have to use S2 at the end of M574? - not sure.
                        The E parameter was removed from M574 many firmware versions ago. Use the I1 parameter in the M558 command to invert the Z probe polarity.
                        madmattcoundefined 1 Reply Last reply Reply Quote 0
                          madmattco @dc42
                          @dc42 said in Switch Z-probe not inverting:
                          I tried that. It didn't work
                            dc42 administrators @madmattco
                            @madmattco, that's uppercase letter I followed by digit 1. Not the vertical bar character.
                              madmattco
                              Correct. I even did a direct copy and paste from the guide when i was testing. Nothing inverts it
                                Which firmware version are you using?
                                  madmattco
                                  RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
                                    madmattco
                                    Just tried the beta aswell. No luck
                                      What is the exact M558 command that you tried? Are you certain that there isn't another M558 line later in config.g ?
                                        madmattco
                                        0_1530394460156_config.g
                                          madmattco
                                          It is set to I0 in that file but I also tried I1 too
                                            madmattco
                                            Would it be prudent to try a version where the E param was still valid in M574?
