    Switch Z-probe not inverting
    4.3k
      deckingman
      Just looking through the wiki, you may have to use S2 at the end of M574? - not sure.
        The E parameter was removed from M574 many firmware versions ago. Use the I1 parameter in the M558 command to invert the Z probe polarity.
        madmattcoundefined 1 Reply Last reply Reply Quote 0
        • madmattcoundefined
          madmattco @dc42
          @dc42 said in Switch Z-probe not inverting:
          I tried that. It didn't work
            dc42 administrators @madmattco
            @madmattco, that's uppercase letter I followed by digit 1. Not the vertical bar character.
              madmattco
              Correct. I even did a direct copy and paste from the guide when i was testing. Nothing inverts it
                Which firmware version are you using?
                  madmattco
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
                    madmattco
                    Just tried the beta aswell. No luck
                      What is the exact M558 command that you tried? Are you certain that there isn't another M558 line later in config.g ?
                        madmattco
                        0_1530394460156_config.g
                          madmattco
                          It is set to I0 in that file but I also tried I1 too
                            madmattco
                            Would it be prudent to try a version where the E param was still valid in M574?
                              That M558 command looks ok to me. Changing between I0 and I1 should make the Z probe reading when not triggered change between 0 and 1000.
                              Check that you don't have a M558 command in config-override.g.
                                deckingman
                                I've just had a thought - does the switch have a series LED by any chance? The Metrol positioning switch that I use does, and so the value for the probe reading doesn't go to zero but only down to around 600 IIRC. So I use P1 for the probe type in my M558 and then in G31 I use P700 for the trigger value. Even if the switch doesn't have an LED, it might be worth checking that the Z probe reading does in fact go to zero when triggered. If it doesn't, using P1 for the probe type and setting an appropriate trigger threshold in G31 might be a solution?
                                  madmattco
                                  I don't have a config-override file. And there is no led here. this is a film touch switch style leveling probe that attaches to the nozzle
                                    madmattco
                                    @deckingman can you or @dc42 tell me exactly what the trigger value is for? ive set it at 0. 600 and 1000 so far with it making no changes.
                                    deckingmanundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                      deckingman @madmattco
                                      @madmattco
                                      DC42 is the man really but as he's on vacation and taking some well earned time off, I'll do my best. When you use a Z probe with a output that isn't a simple on-off, the probe reading will change when it gets near or at the trigger point. So when it isn't triggered, it'll read 1,000 ( I think) and when it is triggered, it'll read something else. If it's a simple switch, that "something else" will be zero but with say an IR probe, it'll be about 500 or less. What does it show for you on the machine properties tab?
                                        T3P3Tony administrators @madmattco
                                        @madmattco
                                        It should show 0 when not triggered and 1000 when triggered if its a simple switch.
                                          madmattco @T3P3Tony
                                          @t3p3tony It does the opposite of that
                                            madmattco @deckingman
                                            @deckingman https://puu.sh/AP65q/df543c1ca3.png is untriggered.
                                            https://puu.sh/AP66h/a74ec1a9b0.png is triggered
