    Switch Z-probe not inverting
    4.3k
      deckingman
      That's odd. Try adding Z1 to your M584. You should only need it with firmware 1.19 or earlier but .....
      • madmattcoundefined
        madmattco
        I dont think it liked that. This is on a delta btw. Sorry for forgetting to mention that in the first place
          deckingman @madmattco
          @madmattco said in Switch Z-probe not inverting:
          Ahhhh. Yes, sorry - I know nothing about Deltas (strange mystical devices☺ ) .
            madmattco
            Do you think I would have better luck if i issued a P5 or P7 instead of P4 on M558?
              Not if you've wired it E0. According to the Wiki, P5 is for the Z probe connector and P7 is for the Z end stop connector. Having said that, I don't know if it makes any difference or if you have to use a different connector on a Delta. I know they home at Z max but that's the limit of my knowledge. Sorry but I'm fresh out of ideas. Hopefully, someone more knowledgable than I will step in and help you out.
                deckingman
                Just looking through the wiki, you may have to use S2 at the end of M574? - not sure.
                  The E parameter was removed from M574 many firmware versions ago. Use the I1 parameter in the M558 command to invert the Z probe polarity.
                  madmattcoundefined 1 Reply Last reply Reply Quote 0
                    madmattco @dc42
                    @dc42 said in Switch Z-probe not inverting:
                    I tried that. It didn't work
                      dc42 administrators @madmattco
                      @madmattco, that's uppercase letter I followed by digit 1. Not the vertical bar character.
                        madmattco
                        Correct. I even did a direct copy and paste from the guide when i was testing. Nothing inverts it
                          Which firmware version are you using?
                            madmattco
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
                              madmattco
                              Just tried the beta aswell. No luck
                                What is the exact M558 command that you tried? Are you certain that there isn't another M558 line later in config.g ?
                                  madmattco
                                  0_1530394460156_config.g
                                    madmattco
                                    It is set to I0 in that file but I also tried I1 too
                                      madmattco
                                      Would it be prudent to try a version where the E param was still valid in M574?
                                        That M558 command looks ok to me. Changing between I0 and I1 should make the Z probe reading when not triggered change between 0 and 1000.
                                        Check that you don't have a M558 command in config-override.g.
                                          deckingman
                                          I've just had a thought - does the switch have a series LED by any chance? The Metrol positioning switch that I use does, and so the value for the probe reading doesn't go to zero but only down to around 600 IIRC. So I use P1 for the probe type in my M558 and then in G31 I use P700 for the trigger value. Even if the switch doesn't have an LED, it might be worth checking that the Z probe reading does in fact go to zero when triggered. If it doesn't, using P1 for the probe type and setting an appropriate trigger threshold in G31 might be a solution?
                                            madmattco
                                            I don't have a config-override file. And there is no led here. this is a film touch switch style leveling probe that attaches to the nozzle
