    Retraction Tuning Guide
    33
    7.0k
    • Ricky_Grade10undefined
      Ricky_Grade10
      I never went to university to get a fancy PFD or whatever, I only got my grade ten.
      Any suggestions on where to start with the T and R parameters? Are these usually small values?
      Thanks for the help boys
        I usually use 20-40mm/s for unretracting. 90-133mm/s for retraction.
        The R value is usually a very small positive or negative decimal value.
        Beauty of firmware retraction is that you can adjust the values during a print. So you can start a retraction test print and make changes on the fly to see how they effect it.
        • wilrikerundefined
          wilriker
          Something I wanted to share here because the Printer Settings plugin for Cura came up: currently there is a bug in CuraEngine (the part the does the slicing in the background) that will create broken GCODE if you enable FW Retract, Relative Extrusion (as recommended for RRF) and Coasting at the same time. This is fixed in source code but will not be part of Cura 3.4 but only the version after (probably Cura 3.5 - not sure about minor fix versions).
          Just so you know, do not use this combination right now.
          Manuel
          My Tool Collection
          • Dinoundefined
            Dino
            As a slight aside I spent most of my Saturday setting up pressure advance on my delta, part of that included using firmware retraction.
            I use S3D as my primary slicer on the delta and for $150 software it doesn't have a nice checkbox to enable firmware retraction 😒 I used post processing scripts I found here:
            http://thrinter.com/using-firmware-retraction-with-simplify3d/
            I had to turn off relative extrusion distances to get the script to work properly but now that it's setup it seems to be pretty nice.
            Only thing I noticed was if I sent all the parameters for retraction distance, speed, unretract extra distance, and zhop together in the same command the zhop wouldn't apply. I added a second command and moved the zhop command to it which seems to have fixed it.
            I have all my default retraction gcode in my config.g and have alterations of it in the start gcode commands for different filament if different retraction is needed. Plus the ability to make on the fly changes to retraction is fantastic, I can disable retraction mid print or add more shop if I need, or even print multiple retraction tests at once with different settings easily.
              Ricky_Grade10
              So if the R value is neglative does that mean it will retract the filament even more?
              I guess Im having problems trying to figure out the order of the retraction process.
              In my brain compartments, I have been thinking it would retract first, then z hop and finally un-retract. Is that the way she goes?
              • wilrikerundefined
                wilriker @Ricky_Grade10
                @ricky_grade10 said in Retraction Tuning Guide:
                No, that would mean it would unretract less than it has retracted, e.g. if you set
                M207 S5 R-0.5
                that would mean it retracts 5mm but only unretracts 4.5mm (whyever you would wanna do something like this).
                That's exactly what it does.
                1. Retract amount specified by Snnn at speed of Fnnn
                2. lift Z by the amount of Znnn
                3. do whatever slicer has put in between
                4. lower Z by the amount of Znnn
                5. unretract Snnn + Rnnn at the speed of Fnnn (or Tnnn if that is given)
                Manuel
                My Tool Collection
                • burtoogleundefined
                  burtoogle @Phaedrux
                  @phaedrux said in Retraction Tuning Guide:
                  @burtoogle seems so. I don't tend to use the betas. Experimental features is as far as I'm willing to go. But glad it will become widely available. Though I still think firmware retraction belongs in the main settings.
                  Thanks for the heads up.
                  FYI Cura 3.4 has been released today.
                  wilrikerundefined 1 Reply Last reply Reply Quote 1
                  • wilrikerundefined
                    wilriker @burtoogle
                    @burtoogle Any idea when this release will make it to GitHub? As that is the base for the package manager in Arch Linux.
                    Manuel
                    My Tool Collection
                    burtoogleundefined 1 Reply Last reply Reply Quote 0
                      burtoogle @wilriker
                      @wilriker said in Retraction Tuning Guide:
                      I don't know but the tags normally appear about the same time as the release so it shouldn't be long now.
                        Ricky_Grade10
                        So if the R value is positive, it will unretract more and act like a primer of sorts? Im guessing I should start with a small value for this parameter?
                        • mrehorstdmdundefined
                          mrehorstdmd @Ricky_Grade10
                          @ricky_grade10
                          yes, start small.
                          I was using a volcano hot-end with a 0.8 mm nozzle and found that after I tuned the extra priming, it would work for the parts I tuned it for, but not for other parts/arrangements on the bed.
                          There is a plugin for Cura called "scalable extra prime" that adjusts the extra prime amount as a function of the travel distance. It's not usually needed with "normal" sized nozzles, but can be a big help with large nozzles.
