    Cant get my nozzle close to bed at all when trying to print
    7.0k
      What was the last thing you changed in config.g? Has any wiring or anything else changed?
      Power down, remove the SD card, pop it into your computer, does anything show on the card? If so, make a backup of the contents. Try deleting the config.g and then renaming the config.g.bak to config.g. It automatically makes a backup whenever you save a new change.
      As for the way forward, I'll have to let someone more versed in hardware problem recovery step in.
      In the mean time you can try running through this: https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        Phaedrux Moderator @Puppet172
        @puppet172 said in Cant get my nozzle close to bed at all when trying to print:
        @phaedrux
        It resets whether or not its connected online or to usb And yes i downloaded:
        DuetWebControl-1.21.2-b1.zip &
        Duet2CombinedFirmware.bin
        and i also updated the wifi server Also
        So you're saying if you disconnect everything from the board and then connect it to your computer via USB it will just continuously power cycle?
          If it resets continuously, please try starting the Duet with the SD card removed and try to connect via USB. If that works and it no longer keeps rebooting, send M122 and post the software reset data and stack trace here so that I can diagnose the problem. Then run the commands in config.g manually one at a time to see which one causes the reset.
          Puppet172undefined 2 Replies Last reply Reply Quote 0
          • Puppet172undefined
            Puppet172 @dc42
            Is the Software reset data and stack trace what i will get from the M122 Command?
              Puppet172 @dc42
              @dc42 @Phaedrux
              RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.01beta1(RTOS) dated 2018-06-23b1<LF><LF>Executing config.g...Error: M587: Failed to add SSID to remembered list<LF>HTTP is enabled on port 80<LF>FTP is disabled<LF>TELNET is disabled<LF><LF>Done!<LF>RepRapFirmware for Duet 2 WiFi/Ethernet is up and running.<LF>WiFi module started<LF>WiFi module is c
                Yes. M122 is a dump of diagnostic information
                Puppet172undefined 1 Reply Last reply Reply Quote 0
                  Puppet172 @Phaedrux
                  @phaedrux @dc42
                  What commands do you mean in the config?
                    @puppet172 I think he means that you should send each line of the config.g file over the USB terminal connection one at a time. If there is a command in there that is causing it to reset, you'll know when you send it.
                    It looks like you're getting an error on your M587 command to add an SSID. Maybe comment out that command and try again?
                      Puppet172 @Phaedrux
                      @phaedrux @dc42
                      i was able to get the M122 Command to go through but it still keeps reseting. THeres like a split second where i can get it to work but it still Resets every couple seconds
                        Puppet172 @Phaedrux
                        @phaedrux @dc42
                        Is there anyway to edit that with it still reseting?
                          @phaedrux @dc42
                          You can remove the SD card and put it in your computer and edit the file with notepad.
                            Puppet172 @Phaedrux
                            @phaedrux
                            When ever i plug the sd card into the computer it just gives me the directory name is invalid. I have the mircro SD in an adapter and then i am plugging it into the computer
                              Puppet172 @Phaedrux
                              @phaedrux
                              Ok i have the card open now so i want to edit the config.g?
                                Puppet172
                                @Phaedrux
                                Thats the Network one but i commented it and now its connected but im not getting anything back From YAT when i out in a command like M122
                                  With that command commented out does the duet keep resetting?
                                    Puppet172 @Phaedrux
                                    @phaedrux
                                    No
                                      Puppet172
                                      @Phaedrux @dc42
                                      Its hard to tell though because the easiest way to tell it to see if i can connect to the DWC but since that then turns off the Wifi part i cant tell but its not doing the on off part as far as i can see because it stays connected to the printer
                                        @dc42 @Phaedrux
                                        Please change the Text Settings in YAT to recognise LF only as the line end sequence. Then the output will be split into multiple lines.
                                          Puppet172 @dc42
                                          === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta1(RTOS) running on Duet WiFi 1.02 or later + DueX5<LF>Board ID: 08DDM-9FAM2-LW4S4-6J9D8-3SD6J-T3S7X<LF>Used output buffers: 1 of 20 (1 max)<LF>=== RTOS ===<LF>Static ram: 28452<LF>Dynamic ram: 95912 of which 0 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 6452<LF>Tasks: NETWORK(ready,1372) HEAT(blocked,1264) MAIN(running,3660)<LF>Mutexes: FilamentSensors(null) DHT(null) WiFi(null) TelnetGCodeReply(null) HttpGCodeReply(null) Telnet(null) HTTP(null) SD1(null) SD0(null) DirSearch(null) FileSystem(null) Aux(null) USB(null) MessageBox(null) ToolList(null) SPI(null) Malloc(null) NetworkGCodeInput(null) NetworkGCodeInput(null) FileInfoParser(null)<LF>=== Platform ===<LF>Last reset 00:00:11 ago, cause: reset button or watchdog<LF>Last software reset details not available<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms<LF>MCU temperature: min 127.7, current 132.2<Warning: Maximal number of bytes per line exceeded! Check the end-of-line settings or increase the limit in the advanced terminal settings.>
                                          Is this right?
                                          dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                            dc42 administrators @Puppet172
                                            @puppet172, no it's still not recognising LF as end of line. I don't have access to YAT right now so I can't give precise instructions, but AFAIR you go into Settings, then press Text Settings and the selection is on that page.
