    Cant get my nozzle close to bed at all when trying to print
    7.0k
    • Puppet172undefined
      Puppet172 @Phaedrux
      @phaedrux @dc42
      What commands do you mean in the config?
        Phaedrux Moderator @Puppet172
        @puppet172 I think he means that you should send each line of the config.g file over the USB terminal connection one at a time. If there is a command in there that is causing it to reset, you'll know when you send it.
        It looks like you're getting an error on your M587 command to add an SSID. Maybe comment out that command and try again?
        Puppet172undefined 2 Replies Last reply Reply Quote 0
          Puppet172 @Phaedrux
          @phaedrux @dc42
          i was able to get the M122 Command to go through but it still keeps reseting. THeres like a split second where i can get it to work but it still Resets every couple seconds
            Puppet172 @Phaedrux
            @phaedrux @dc42
            Is there anyway to edit that with it still reseting?
              @puppet172 said in Cant get my nozzle close to bed at all when trying to print:
              @phaedrux @dc42
              You can remove the SD card and put it in your computer and edit the file with notepad.
                Puppet172 @Phaedrux
                @phaedrux
                When ever i plug the sd card into the computer it just gives me the directory name is invalid. I have the mircro SD in an adapter and then i am plugging it into the computer
                  Puppet172 @Phaedrux
                  @phaedrux
                  Ok i have the card open now so i want to edit the config.g?
                    Puppet172
                    @Phaedrux
                    Thats the Network one but i commented it and now its connected but im not getting anything back From YAT when i out in a command like M122
                      With that command commented out does the duet keep resetting?
                      Puppet172undefined 1 Reply Last reply Reply Quote 0
                        Puppet172 @Phaedrux
                        @phaedrux
                        No
                          Puppet172
                          @Phaedrux @dc42
                          Its hard to tell though because the easiest way to tell it to see if i can connect to the DWC but since that then turns off the Wifi part i cant tell but its not doing the on off part as far as i can see because it stays connected to the printer
                            @dc42 @Phaedrux
                            RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.01beta1(RTOS) dated 2018-06-23b1<LF><LF>Executing config.g...Error: M587: Failed to add SSID to remembered list<LF>HTTP is enabled on port 80<LF>FTP is disabled<LF>TELNET is disabled<LF><LF>Done!<LF>RepRapFirmware for Duet 2 WiFi/Ethernet is up and running.<LF>WiFi module started<LF>WiFi module is c
                            Please change the Text Settings in YAT to recognise LF only as the line end sequence. Then the output will be split into multiple lines.
                              Puppet172 @dc42
                              === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta1(RTOS) running on Duet WiFi 1.02 or later + DueX5<LF>Board ID: 08DDM-9FAM2-LW4S4-6J9D8-3SD6J-T3S7X<LF>Used output buffers: 1 of 20 (1 max)<LF>=== RTOS ===<LF>Static ram: 28452<LF>Dynamic ram: 95912 of which 0 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 6452<LF>Tasks: NETWORK(ready,1372) HEAT(blocked,1264) MAIN(running,3660)<LF>Mutexes: FilamentSensors(null) DHT(null) WiFi(null) TelnetGCodeReply(null) HttpGCodeReply(null) Telnet(null) HTTP(null) SD1(null) SD0(null) DirSearch(null) FileSystem(null) Aux(null) USB(null) MessageBox(null) ToolList(null) SPI(null) Malloc(null) NetworkGCodeInput(null) NetworkGCodeInput(null) FileInfoParser(null)<LF>=== Platform ===<LF>Last reset 00:00:11 ago, cause: reset button or watchdog<LF>Last software reset details not available<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms<LF>MCU temperature: min 127.7, current 132.2<Warning: Maximal number of bytes per line exceeded! Check the end-of-line settings or increase the limit in the advanced terminal settings.>
                              Is this right?
                              dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                dc42 administrators @Puppet172
                                @puppet172, no it's still not recognising LF as end of line. I don't have access to YAT right now so I can't give precise instructions, but AFAIR you go into Settings, then press Text Settings and the selection is on that page.
                                  T3P3Tony administrators @Puppet172
                                  @puppet172
                                    The M587 only needs to be issued one - to add the SSID. the SSID (and password) is then stored on the Duet until you ask the Duet to forget it.
                                    Comment out M587 then try the SD card back in the Duet and see if it will boot without resetting.
                                    Normally M587 would not cause the Duet to reset but if that is the line that is causing the reset then thats the place to start.
                                      Puppet172 @T3P3Tony
                                      @t3p3tony @dc42 @Phaedrux
                                      even if i have that commented out it is still reseting and i changed the text setting to the ones above and i got this
                                      Used output buffers: 1 of 20 (12 max)
                                      Static ram: 28452
                                      Tasks: NETWORK(ready,1372) HEAT(blocked,1256) MAIN(running,3644)
                                      Last reset 00:00:48 ago, cause: reset button or watchdog
                                      Error status: 0
                                      MCU temperature: min 136.1, current 136.8, max 138.1
                                      Supply voltage: min 0.2, current 0.2, max 0.3, under voltage events: 0, over voltage events: 0
                                      Driver 0: ok, SG min/max not available
                                      Driver 1: ok, SG min/max not available
                                      Driver 2: ok, SG min/max not available
                                      Driver 3: ok, SG min/max not available
                                      Driver 4: ok, SG min/max not available
                                      Driver 5: ok, SG min/max not available
                                      Driver 6: ok, SG min/max not available
                                      Driver 7: ok, SG min/max not available
                                      Driver 8: ok, SG min/max not available
                                      Driver 9: ok, SG min/max not available
                                      Expansion motor(s) stall indication: yes
                                      Slowest loop: 172.25ms; fastest: 0.07ms
                                      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                      Bed compensation in use: mesh
                                      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
                                      Segments left: 0
                                      Movement lock held by null
                                      http is idle in state(s) 0
                                      telnet is idle in state(s) 0
                                      file is idle in state(s) 0
                                      serial is ready with "M122" in state(s) 0
                                      aux is idle in state(s) 0
                                      daemon is idle in state(s) 0
                                      queue is idle in state(s) 0
                                      Code queue is empty.
                                      === Network ===
                                      Slowest loop: 0.00ms; fastest: 4581298.50ms
                                      HTTP sessions: 0 of 8
                                      • WiFi -
                                        Network state is running
                                        WiFi firmware version 1.21
                                        WiFi MAC address 60:01:94:73:5a:d2
                                        WiFi Vcc 2.67, reset reason Turned on by main processor
                                        WiFi flash size 4194304, free heap 17184
                                        WiFi IP address 192.168.1.10
                                        WiFi signal strength -55dBm, reconnections 0, sleep mode modem
                                        === Expansion ===
                                        DueX I2C errors 0
                                        ok
                                        Puppet172
                                        @T3P3Tony @dc42 @Phaedrux
                                        This is also with The M587 Commented out
                                          I think the problem is that you are supplying USB power only, and when the WiFi module tries to connect, your USB power source is cutting out because of the increased current demand.
                                            Puppet172 @dc42
                                            It happens when i have my 12v power on too i can send it with the power supply on.
                                            Static ram: 28452
                                            Exception stack ram used: 300
                                            Never used ram: 6408
                                            Tasks: NETWORK(ready,1408) HEAT(blocked,1256) MAIN(running,3628)
                                            Last reset 00:00:37 ago, cause: power up
                                            Error status: 0
                                            MCU temperature: min 44.6, current 67.1, max 67.1
                                            Supply voltage: min 12.3, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0
                                            Driver 5: standstill, SG min/max not available
                                            Driver 6: standstill, SG min/max not available
                                            Driver 7: standstill, SG min/max not available
                                            Expansion motor(s) stall indication: no
                                            Slowest loop: 1.09ms; fastest: 0.07ms
                                            Segments left: 0
                                            === Network ===
                                            Slowest loop: 14.21ms; fastest: 0.01ms
                                            • WiFi -
                                              WiFi Vcc 3.17, reset reason Turned on by main processor
                                              WiFi signal strength -62dBm, reconnections 0, sleep mode modem
                                              === Expansion ===
                                              DueX I2C errors 0
