    My Delta
    My Duet controlled machine
    2.0k
    • Danalundefined
      Danal
      Hey! A "motors on top". Fantastic!!
      What are the dimensions?
      • Craigundefined
        Craig
        330mm diameter with 450mm height.
          T3P3Tony administrators @Craig
          @craig How are you finding the tightening of the wheels on the 20x60 carriages? it looks like the brackets are sturdy but they dont appear to have adjustments
          Craigundefined 1 Reply Last reply Reply Quote 0
          • Craigundefined
            Craig @T3P3Tony
            @t3p3tony All the wheels on one side have fitted eccentric spacers. As they are rotated they move the wheel into the v-slot. Once adjusted the nut on the axel is tightened to hold them in that position. They are integral to the openbuilds system.
            • Craigundefined
              Craig
              For stability I wanted no plastic parts in the frame. I have followed other builds and for this size printer most are using materials custom cut on a CNC or water jet. I could not justify a $20 13" x 13" x.125 build plate being custom cut for $150. My top and bottom plates together cost $40 and would have cost another $200 to have them professionally cut. So the basis of my build is to cut all of my materials myself and use drill jigs to give me the necessary accuracy for this build. My tools include a 12" radial arm saw, a 10" table saw, a jig saw and a scroll saw, along with a drill press and misc. hand tools. Right now I am in assembly having cut my plates and just received the v-slot materials. The total out of pocket costs for the frame material excluding freight is less than $200.
              • Hergonowayundefined
                Hergonoway @Craig
                @craig yeah welcome to the MotorOnTop club >high five<
                Delta goes BrrrRRRRrrrrrRRRRrrr
                  deckingman
                  ....and welcome to the OpenBuilds club too
                  • Craigundefined
                    Craig
                    • Craigundefined
                      Craig @deckingman
                      @deckingman I have been part of Openbuilds for several years.0_1530715965758_20170404_132655.jpg
                      • DjDemonDundefined
                        DjDemonD
                        I like the belts and motors on the outside, I was thinking about reframing my acrylic tube leadscrew delta (acrylic tube was a nice gimmick but isn't holding up too well), to have the screws on the outside of the towers, as you have your belts. Looks good.
                        www.precisionpiezo.co.uk
                        • Craigundefined
                          Craig
