    Laser wiring?
    5.5k
      The heater pins on the expansion are active low, so you will get a glitch turning the laser on while the Duet initialises itself. I suggest you do the same as we do for the heater mosfet drive circuits, which is to use a 74HCT02 gate powered from 5V to gate the signal with +3.3V, and invert it and level shift it to 5V.
      • flippnswitchezundefined
        flippnswitchez
        Thank you, Sir!!
        Tronxy X5S w? DuetWifi
        CTC
        • nirmal005undefined
          nirmal005
          I am new to 3D printing, so please forgive my ignorance.
          I am planning to buy DuetWiFi so that I can connect a 12v 15W 450nm TTL controlled laster module. The answer to this exact question is what I am looking for.
          @flippnswitchez, Were you able to make it work? If yes, would you please share your circuit schematics? It would be really helpful to know what needs to be connected where.
          flippnswitchezundefined 1 Reply Last reply Reply Quote 0
            flippnswitchez @nirmal005
            @nirmal005 I was sidetracked and have not finished yet, but yes it should work. I was sidetracked by some troubles getting my printer back up and working from the switch between boards. I also added a 24v power supply because of my bed, so I also had to order a step-down module for the laser.
            CTC
            • keyz182undefined
              keyz182
              @dc42 said in Laser wiring?:
              How would I go about wiring this configuration up? I have a laser module that takes a 5v PWM signal that I'd like to get hooked up.
              • resamundefined
                resam
                Take a 74HCT02 (or some other form of NAND/NOR/inverter logic gate), and feed in your control signal from the Duet. The output of the logic gate then goes to the 5V-PMW input of the laser.
                A typical 74HCT02 (Quad 2-input NOR gate) gets connected to +5V and GND.
                1A and 1B get connected together and then to your Duet output pin.
                1Y goes to the 5V-PWM laser input.
                (as the 74HCT02 as 4 such logic gates, you can also use 2A+2B with 2Y, 3A+3B with 3Y, etc.)
                Just look up the pin assignment in the 74HCT02 datasheet (e.g., https://assets.nexperia.com/documents/data-sheet/74HC_HCT02.pdf on page 2)
                • keyz182undefined
                  keyz182
                  @resam thanks 🙂
                  I wasn't sure how to wire up the 1a,b inputs, but you've cleared that up for me!
                  • keyz182undefined
                    keyz182
                    Does #1 in the image look correct? Also, would #2 work? It was taken from the power mosfet drivers from the Duex boards (there's also a cap between 5V and GND I missed out).
                    I tried #2, because I figured but it seems the laser off on 0 and 100%, and on full everywhere between.
                    I can try #1, but want to make sure it's correct this time before wiring it up.
                    • resamundefined
                      resam
                      I'm using #1, but with the HEATER_3 pin, if I remember correctly.
                      Not sure how FAN2- behaves in this circuit...
                      keyz182undefined 1 Reply Last reply Reply Quote 0
                      • keyz182undefined
                        keyz182 @resam
                        @resam D'oh, Looks like I got turned around - Will try on heater now.
                        • resamundefined
                          resam
                          On my system:
                          M452 P3 to enable "laser mode" on heater 3.
                          M3 S1 turn on the laser at the lowest intensity.
                          M3 S255 at full intensity.
                          M5 and M3 S0 is laser off.
                          • keyz182undefined
                            keyz182
                            It works! I think I'm going to have to write this up later and put it up here/on the wiki for others to reference. @dc42 is there any downside to using circuit #2 in my previous reply above vs the "simpler" one? If not, I'll stick with #2.
                            @resam said in Laser wiring?:
                            On my system:
                            Yup, that's what I've got now 🙂
                              We use circuit #2 In the heater wiring, because users occasionally short +3.3V to ground because of incorrect endstop wiring or other reasons, and when that happens we don't want all the heaters to turn on at full power. The same considerations apply to a laser, so I suggest circuit #2.
                              • keyz182undefined
                                keyz182 @dc42
                                @dc42 Great, that's what I went with, and it works 🙂
                                Thanks all for the help. I've got a bunch of cable management to do today, and once that's done, the real testing will begin. If the tests all work, I'll write it up and post it here for some vetting, and if it looks good, I (or someone) can put it up on the wifi 🙂
                                • keyz182undefined
                                  keyz182
                                  Prepping the documentation here - https://gist.github.com/keyz182/34601ec4ba4a19c55a177d0d1738d5a3
                                  Any notes or corrections welcome. Once done and peer-reviewed I'll get it moved to the wiki.
                                  • resamundefined
                                    resam
                                    Nice!
                                    I think you got the GND and V_IN connection mixed up on the LASER_OUT header...?
                                    • keyz182undefined
                                      keyz182 @resam
                                      @resam Good catch, fixed 🙂
                                      • keyz182undefined
                                        keyz182
                                        Just realised I selected the 74HCT02D, rather than the 74HCT02. It's datasheet claims it's both TTL and CMOS compatible.
                                        I ordered a few boards from JLPCB because I've never done board design before, and figured this would be a good start.
                                        I think it should work, as the output is dependent on VCC rather than anything else, and other than also having CMOS input compatibility, it seems the same. Can someone with more knowledge in electronic weigh in to say if it's a choice that'll work, or if I need to change it?
                                          T3P3Tony administrators @keyz182
                                          @keyz182 said in Laser wiring?:8
                                          74HCT02D
                                          should be fine, the datasheet shows the "D" to mean its SIOC foot print. What determines the logic levels is the HC/HCT (74HC02 vs 74HCT02)
                                          https://en.wikipedia.org/wiki/7400_series#7400_series_derivative_families
                                          • keyz182undefined
                                            keyz182 @T3P3Tony
                                            @t3p3tony Awesome, thanks.
                                            Do you think the "Circuit operational theory" section I just added looks correct? I want to make sure people are able to understand why they're doing something, not just that they should do it.
