    Laser wiring?
    5.5k
      We use circuit #2 In the heater wiring, because users occasionally short +3.3V to ground because of incorrect endstop wiring or other reasons, and when that happens we don't want all the heaters to turn on at full power. The same considerations apply to a laser, so I suggest circuit #2.
      keyz182undefined 1 Reply Last reply Reply Quote 0
      • keyz182undefined
        keyz182 @dc42
        @dc42 Great, that's what I went with, and it works 🙂
        Thanks all for the help. I've got a bunch of cable management to do today, and once that's done, the real testing will begin. If the tests all work, I'll write it up and post it here for some vetting, and if it looks good, I (or someone) can put it up on the wifi 🙂
        • keyz182undefined
          keyz182
          Prepping the documentation here - https://gist.github.com/keyz182/34601ec4ba4a19c55a177d0d1738d5a3
          Any notes or corrections welcome. Once done and peer-reviewed I'll get it moved to the wiki.
          • resamundefined
            resam
            Nice!
            I think you got the GND and V_IN connection mixed up on the LASER_OUT header...?
            • keyz182undefined
              keyz182 @resam
              @resam Good catch, fixed 🙂
              • keyz182undefined
                keyz182
                Just realised I selected the 74HCT02D, rather than the 74HCT02. It's datasheet claims it's both TTL and CMOS compatible.
                I ordered a few boards from JLPCB because I've never done board design before, and figured this would be a good start.
                I think it should work, as the output is dependent on VCC rather than anything else, and other than also having CMOS input compatibility, it seems the same. Can someone with more knowledge in electronic weigh in to say if it's a choice that'll work, or if I need to change it?
                  T3P3Tony administrators @keyz182
                  @keyz182 said in Laser wiring?:8
                  74HCT02D
                  should be fine, the datasheet shows the "D" to mean its SIOC foot print. What determines the logic levels is the HC/HCT (74HC02 vs 74HCT02)
                  https://en.wikipedia.org/wiki/7400_series#7400_series_derivative_families
                  • keyz182undefined
                    keyz182 @T3P3Tony
                    @t3p3tony Awesome, thanks.
                    Do you think the "Circuit operational theory" section I just added looks correct? I want to make sure people are able to understand why they're doing something, not just that they should do it.
                      by connecting the heater PWM to two input pins of the 74HCT02, we get an inversion of the PWM, such that when PWM out is pulled low, the 74HCT02 output is driven high.
                      This is a little confusing as written because the diagram shows PWM connected to only one input. maybe re-order the text so it is clear what the 3.3V is doing first?
                      • keyz182undefined
                        keyz182 @T3P3Tony
                        @t3p3tony rearranged slightly now - https://gist.github.com/keyz182/34601ec4ba4a19c55a177d0d1738d5a3
                        I still haven't been able to fully test this yet, I ran out usable filament to print a cable chain mount (I have ABS, but needed to use the room today).
                        Hopefully I'll get things all tested tomorrow, and can augment the guide with some examples of using e.g. Inkscape to do both vector and raster.
                        • keyz182undefined
                          keyz182
                          Added to the wiki - https://duet3d.dozuki.com/Item/Using_a_PWM_driven_laser_module
                            @keyz182 thanks, I moved it to a wiki page as it's not really an item:
                            https://duet3d.dozuki.com/Wiki/Laser_PWM_control
                            • keyz182undefined
                              keyz182
                              Can anyone recommend the best way to protect the signal from interference. The signal cable is running a total of about 1 meter alongside stepper cabling. I could run the cable separately, but would prefer to keeps it clean and together if possible.
                              I have plenty of shielded Cat5e/6 lying about, would that be fine? How best would I go about utilising the twisted pairs? Tie them together and treat the entire cable as 4 conductors, or e.g. pair signal and gnd? Or should I just experiment and see what works?
                              Also, does anyone have experience using Cat5e/6 for the steppers? I'd need to check the gauge on the stuff I have, but from what I've read it should be able to handle the NEMA17s I've got.
