I can no longer Load/Unload different filaments
1.2k
    DR8
    Firmware Version: 2.0(RTOS)RC5 (2018-05-22b1)
    WiFi Server Version: 1.21
    Web Interface Version: 1.21.1-RC4
    After the update on this firmware version I can't Load/Unload/Change filaments from my tool head. I have double checked and the right macros for the filaments are present in the "Filaments" folder. What can I do?
    Thanks!
    undefined 1 Reply Last reply 11 Jul 2018, 11:53 Reply Quote 0
      wilriker @DR8
      @dr8 I am not totally sure but I think I remember that this has been fixed in the final release whereas you are still running older release candidates. So update and check again, please.
      Manuel
      My Tool Collection
        DR8
        Oh, ok. Got it. So i have downloaded the latest firmware, server and web control from here https://github.com/dc42/RepRapFirmware/releases and when I try to upload and install the firmware via web interface I gor error. Why is that?
        undefined 1 Reply Last reply 11 Jul 2018, 12:39 Reply Quote 0
          wilriker @DR8
          @dr8 What error do you get?
          Manuel
          My Tool Collection
            DR8
            it's says error on the bar where it should be 10 20 30 99% uploading. It uploads until 22 or so and then it shows error
            undefined 1 Reply Last reply 11 Jul 2018, 12:46 Reply Quote 0
              wilriker @DR8
              @dr8 I assume you are using Duet2CombinedFirmware.bin, don't you? Have you tried again?
              Manuel
              My Tool Collection
                DR8
                I hve tried again and again. I think was the wak connection of my wifi router. Now I have uploaded and yes the topic problem was solved. But Now i have another one. When i want o move the head X+10mm the head goes -X and -Y direction. When I press Y+10 the head goes -X and +Y direction. My config.g is this
                M569 P1 S0 ; Drive 1 goes forwards
                M569 P3 S0 ; Drive 3 goes forwards
                M350 X64 Y64 Z64 E32 I1 ; Configure microstepping with interpolation
                I have tried:
                M569 P0 S0 ; Drive 1 goes forwards
                M569 P1 S0 ; Drive 2 goes forwards
                M569 P0 S1 ; Drive 1 goes forwards
                M569 P1 S1 ; Drive 2 goes forwards
                undefined undefined 2 Replies Last reply 11 Jul 2018, 13:42 Reply Quote 0
                  wilriker @DR8
                  @dr8 I am a little out of ideas about this misbehaving of movements. But what I can spot (probably) independent of this is that you have configured microstepping and your comment (and I parameter) says interpolation enabled. But interpolation only works works with 16x microstepping, so you effectively disabled that by setting your drives to 64x and 32x respectively.
                  Also I notice that the commands listed below "I have tried" are all the same for all four blocks as well as being the same as in the excerpt above that. And your comments on direction mismatch on those having S0 which means backwards and not forwards.
                  Manuel
                  My Tool Collection
                    dc42 administrators @DR8
                    @dr8 said in I can no longer Load/Unload different filaments:
                    I have tried:
                    I think that's an issue with DWC 1.21.2b1 and b2 on CoreXY machines. I suggest you revert to DWC 1.21.1.
                      DR8
                      That's right dc42. I have a CoreXY and defenetly it's a problem on DWC latest release. I did the downgrade and now it's working fine. Thanks
                      3 out of 10
