    smart effector not working
    Smart effector for delta printers
    3.1k
    • Monster Deltaundefined
      Monster Delta @dc42
      @dc42 all things i have checked and are good as far as i can tell and as i say there is 3.2v between the pins so rules out a bad crimp
        dc42 administrators @Monster Delta
        @monster-delta said in smart effector not working:
        Does anything in particular provoke the fault, such as waggling the cables, or moving the effector in a certain direction?
        Monster Deltaundefined 1 Reply Last reply Reply Quote 0
          Monster Delta @dc42
          @dc42 tapping it sometimes does leaving it for a few hours will sometimes get it to respond but soon reverts to either not working at all or the 2 flashes but it really seems random i even soldered the crimps onto the wires but i cant seem to find one particular thing that provokes a response
            OK, if you think the effector is faulty, please ask your supplier to replace it. See https://www.duet3d.com/warranty.
              Monster Delta @dc42
              @dc42 ok will do thanks for your time
                Monster Delta
                I filled out the warranty form on monday morning but i havn't received a response yet
                  T3P3Tony administrators @Monster Delta
                  @monster-delta I have highlighted this
                    Monster Delta @T3P3Tony
                    @t3p3tony thankyou
                      Monster Delta
                      Replacement received promply and now this one is doing weird things. I went to run calibration this morning and at first it wouldn't do much and after a few reboots it sprung into life but now it constantly triggers erratically and the values bounce around from 0 to 1000 and various values in between i checked the voltage and it is is 3.3v un plugged the fan and the hotend and removed the arms but it makes no difference
                        If the reading bounces around without the green LED flashing or flickering in sympathy, that suggests a bad crimp connection in the output wire from the effector to the Duet Z probe input.
                          Monster Delta
                          The green light does flash randomly without any kind of pattern to it
                          • adavidmundefined
                            adavidm
                            Out of interest, have you ever had a probe working on your Duet, and which revision of the Duet do you have? I got caught out by the fact that there are differences in the pinout on the Duet's probe connector depending on the revision. My (white) prototype board has the opposite pinout to the (blue) production board.
                            Diagrams showing both are available here:
                            https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                            adavidm
                              If it flashes randomly with no heaters or fans turned on, and you haven't increased the sensitivity, that suggests a hardware fault - possibly in the effector, but more likely a bad crimp connection in the +3.3V or ground wire between the 8-pin connector and the Duet.
