Problem printing circles
I hope this is true.
I really need to reduce weight of the bed assembly. I ordered PCB bed without ALU and thinner glass. That should save me around 500g, and if this goes well I will replace the bed frame for ALU also, at the moment I have inox. That would mean at least 200g. -
Unless you have very shitty belts that strech like crazy, there is no reason for the weight of the moving things to generate backlash. I have it too in Y on my CoreXY, but I am sure it is not the axis weight which is pretty thin.
If you suspect the weight is an issue then you can play with motors currents and/or acceleration and see if there are any changes. -
@sigxcpu said in Problem printing circles:
If you suspect the weight is an issue then you can play with motors currents and/or acceleration and see if there are any changes.I agree with this. @deckingman probably has the heaviest print head axis combo of everyone on this forum and he doesn't complain about backlash.
Ian, do you want to comment about this?
My bed assembly is in the region of 1,5kg
@timcurtis67 said in Problem printing circles:
Not really
But since you asked...... I have 4kg split between two gantries so roughly 2 kg per XY mechanism. "No name" 6mm GT2 belts. Max X axis speed 50,000, max Y axis speed 35,000, accel 1,000 for both, jerk 600 for both. I have experimented with high print speeds up to 300mm/sec and my default non-print move speed is 350mm/sec. No sign of backlash but everything is pretty rigid. It'll print OK at higher accelerations but with the mass being over a metre above the floor, the printer tends to start to rock about a bit at high speeds.
As an aside, I don't get ringing either - one advantage of high mass
Hah, I have a i3 style printer. So it is moving a lot.
I will investigate the whole mechanics of X and Y, something is wrong there, that I am certain.Aaaand, he deleted the post
@obeliks said in Problem printing circles:
Yes, I realised my mistake - hence I deleted the post. For some reason I thought yours was a CoreXY the same as mine.
Edit. So in which case, you could well have backlash or movement issues in Y
You could try reducing the accel and jerk for your Y axis. I think in your config you have X and Y the same. It's not uncommon to use different values for i3 style printers because of the bed weight.
I was thinking, and in the end it is probably a problem with the sintered bushes that I use instead of bearings.
Image by Toolson
I made a stupid decision and lubricated them, and they still move, but the moves are "sticky". I will try to clean them, and maybe switch back to linear bearings. I just need to find good ones.
Is this still the right category for this thread?
I took X and Y axes apart, cleaned all the components, so now it is gliding as good as it can. Positive is that printer got quieter, negative is that the circles are still flat on top and bottom.
I am slowly running out of ideas.
The only part that I still need to investigate is the print head. But it is rigid as it ever was. -
@obeliks Did you ever try lower acceleration for your Y axis as someone suggested? I note that the motor currents are set to 800mA so presumably the motors are rated at 1Amp? If your bed weight 1.5kg, the Y motor might be struggling so either try lower acceleration, increase the current if you can, or a bigger motor.
I actually just ordered Wantai 42BYGHM810
It was on my to do list, so...
Then I just need 24V power supply and Anet A8 will be no more.My motors are rated 1680mA, not sure if that is correct. And I had them running, at 1400mA and the circles were not great. But they heated up over 80°C So I stopped that.
And at the moment I am printing a puzzle box for a gift, it has mostly straight lines, so the circles are not a problem.
So, with Wantai motors the circles are circles. So either the stepper for X or Y was bad or the 0,9° vs 1,8° makes the difference. Or it was something else that I did not see and was fixed on reassembly. But I did that before the stepper change and there was no difference.
Motors are also quieter and cooler (both around 5 down).The only thing left is to figure out what to do with the old electronics and steppers. I might need another printer.
Q: What AWG wires do I need for the steppers? I will need to clean the wiring now.
I started rewiring now and will use 0.5mm² or 20 AWG for the wiring of my steppers. But you have to get wires with rather thin insulation to still fit into the Molex KK crimps. I use LiYY 4x0.5mm² cable for this.
20awg is rather thick. I suggest 22 awg, or 24awg for lower current motors.
I have 2.4A motors, so 22AWG?
Yes, 22awg is suitable.
@dc42 Is there any reason not to use 20AWG except for the stiffness of the cable if it needs to move?
@dc42 thank you
20awg should be OK, the crimp pins we supply are intended for 20 to 24awg.
