[Guide] How To Select Extruder Microstep Setting
4.0k
    wilriker
    Ok, my first print with 256x microstepping has massive under-extrusion. This means stall warnings were actual stalls and not just the setting being too sensitive.
    According to the calculator for my extruder the shortest print move would be slightly over 0.3mm (X-Y distance). According to the result of my analysis tool as listed above there are about 35% of moves in my GCODE files that are shorter, yet I never suffered from under-extrusion this much.
    I know think that RRF combines several G1 commands into one continuous print move.
    So, I wonder now if I should port this functionality to my tool because currently it does not represent actual print moves by the printer but only what the slicer did. Or should I abandon my analyzer tool altogether?
    Any thoughts, anyone?
    Manuel
    My Tool Collection
    undefined 1 Reply Last reply 27 Jul 2018, 19:57 Reply Quote 0
      I'm curious what current you're running your extruder motor at. 85% of rated?
      Wouldn't combining the G1 moves lead to longer extrusion and less missed steps anyway? Or am I missing what that really means?
      Perhaps 128 is the better way to go as DC42 has suggested elsewhere.
      undefined 1 Reply Last reply 27 Jul 2018, 19:53 Reply Quote 0
        wilriker @Phaedrux
        @phaedrux Actually I run then at 77.7% of rated current, i.e. 700mA of 900mA. Since the Duet will only use increments of full 100mA anyway, I won't get any closer.
        I will retry the same print with 128x and probably also with 16x+I.
        Also I still use my ungeared MK8 extruder with only about 97 steps/mm which might also be another factor here.
        EDIT: regarding the combining of commands: yes, this leads to longer extruder moves with less skipped steps and makes it possible to reach higher speeds as you do not have to accel/decel all the time. But this also means that GCODE in the file can contain arbitrary short moves that in reality will be merged into other moves. So my tool does only show what goes into RRF but not how the motors will actually be commanded.
        Manuel
        My Tool Collection
        undefined undefined 2 Replies Last reply 27 Jul 2018, 20:04 Reply Quote 0
          deckingman @wilriker
          @wilriker said in [Guide] How To Select Extruder Microstep Setting:
          I know that RRF combines several G1 commands into one continues print move.
          Are sure about the firmware combining G1 commands into one continuous move? That seems highly unlikely to me.
          I'm not seeing any stall warnings but maybe I'm not looking in the right place. Where are you getting them from and are they during print moves or the more rapid retract moves?
          Anyway, that aside, try 128 x instead of 256 x.
          undefined 1 Reply Last reply 27 Jul 2018, 20:03 Reply Quote 0
            wilriker @deckingman
            @deckingman I am not a 100% certain about this TBH. Maybe that's the point where @dc42 could step in. 😉
            To get stall warnings you have to enable them in the first place with M915 P3 S1 R1 where the R1 is the part that enables the logging. Then they will just be send to GCODE console as well as pop-up messages in DWC.
            Manuel
            My Tool Collection
              Yes, that'll definitely screw things up. Geared extruders such as E3D Titans or Bondtech BMGs typically have around 400 steps per mm. So the best thing you could do would be to ditch that ungeared one. You'll need less micro-stepping and you'll also have 3 to 4 times more torque available because of the gearing.
              undefined 1 Reply Last reply 27 Jul 2018, 20:07 Reply Quote 0
                @deckingman There is actually a Titan laying on my desk already for a while. I just did not find the time yet to install it (and after some issues with failed "upgrades" to my Y axis a for me unusual never-change-a-running-system attitude had formed - need to get rid of this again 😂 ).
                Manuel
                My Tool Collection
                  dragonn @wilriker
                  If you cool you motor you can even get over-current, my motors are rated at 1.7A and they are running at 1.9A, but ever single have 40mm fan behind it. Nothing will happen if you motor runs at 88% if it doesn't get to hot (60-70C is still ok for a Nema17 motor).
                  undefined undefined 2 Replies Last reply 28 Jul 2018, 11:44 Reply Quote 0
                    deckingman @dragonn
                    @dragonn said in [Guide] How To Select Extruder Microstep Setting:
                    If you cool you motor you can even get over-current, my motors are rated at 1.7A and they are running at 1.9A, but ever single have 40mm fan behind it................
                    ...........and if the cooling fan fails................?
                    undefined 1 Reply Last reply 28 Jul 2018, 11:57 Reply Quote 0
                      dragonn @deckingman
                      @deckingman well then probably my motor will demagnetize :D, I have a plan replace then with 2.5A motors. I am not saying this is a good idea :P, just wonted to point out that running motor 3% over recommend 85% is really nothing bad.
                      undefined 1 Reply Last reply 28 Jul 2018, 13:08 Reply Quote 0
                        deckingman @dragonn
                        @deckingman ............... just wonted to point out that running motor 3% over recommend 85% is really nothing bad.
                        Possibly not, but you are running 1.7A rated motors at 1.9 amp which is nearly 12% over their maximum, rather than 15% under . So that's about 27% higher than the Duet recommendation. Personally I wouldn't consider that to be safe for so many reasons but hey - it's your printer and your house.
                          wilriker @dragonn
                          @dragonn As I usually have no issues with torque on my extruder except for the change to 256x microstepping I don't think I need to go over its rating - also I already have a replacement with gearing ready to install.
                          Of course I could go to 800mA and even 900mA and it is currently mounted on a metal extruder carriage so no risk that heat would damage anything but the motor itself but again I don't see a need yet.
                          But thanks nevertheless for pointing out that I actually could get closer to 85% by going to 800mA. Never really thought about that. 😂
                          Manuel
                          My Tool Collection
                          18 out of 20
