    Very slow printing Duet Wifi on Am8
    1.4k
    • ludodgundefined
      ludodg
      This is a movie, made while it was simply printing a brim:
      https://www.youtube.com/watch?v=z62fujeEcYY
        deckingman @ludodg
        @ludodg Nothing leaps out at me from your config.g (but I might have missed something). Looking at the video, it isn't acceleration that's the problem. Do normal moves through the web interface works at the correct speed? If so, then it has to something to do with the gcode file you are trying to print. What speed was it sliced at? Obvious question but what is the speed fact slider in DWC set to? Is there any sign of an M220 command anywhere? If you type M220 into DWC without any other parameters, what does it report?
          Do you happen to be using mesh grid compensation? Your Z jerk is quite low (only 0.2mm/s) and that could be limiting the speed of XY moves as it has to slowly adjust the height of Z. Try increasing it to 60 (1mm/s) and see if it improves.
          Can you run an M122 and post the results?
          deckingmanundefined 1 Reply Last reply Reply Quote 1
            deckingman @Phaedrux
            @phaedrux Good catch (about the mesh compensation and slow Z speed).
            • ludodgundefined
              ludodg
              Hello.
              Thx for looking into this with me.
              Mesh compensation? Again, some studying to do, I guess 🙂
              as requested:
              M122
              Used output buffers: 3 of 32 (6 max)
              RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
              Board ID: 08DGM-956GU-DJMSN-6J9F8-3S06S-KAQZG
              Static ram used: 16152
              Dynamic ram used: 100584
              Recycled dynamic ram: 2048
              Stack ram used: 1224 current, 6464 maximum
              Never used ram: 5824
              Last reset 01:18:40 ago, cause: reset button or watchdog
              Last software reset at 2018-07-28 00:05, reason: User, spinning module GCodes, available RAM 5672 bytes (slot 2)
              Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
              Error status: 0
              Free file entries: 9
              SD card longest block write time: 0.0ms
              MCU temperature: min 40.0, current 45.5, max 45.8
              Supply voltage: min 12.0, current 12.5, max 12.8, under voltage events: 0, over voltage events: 0
              Driver 0: ok, SG min/max 0/616
              Driver 1: ok, SG min/max 0/487
              Driver 3: ok, SG min/max not available
              Slowest main loop (seconds): 0.042753; fastest: 0.000046
              MaxReps: 3, StepErrors: 0, LaErrors: 0, FreeDm: 174, MinFreeDm 150, MaxWait: 436051ms, Underruns: 0, 0
              Scheduled moves: 33946, completed moves: 33916
              Bed compensation in use: none
              Heater 0 is on, I-accum = 0.0
              Heater 1 is on, I-accum = 0.6
              Segments left: 1
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is doing "G0 X89.372 Y114.372" in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is running
                WiFi firmware version 1.21RC4(08b3)
                WiFi MAC address 60:01:94:73:5b:e0
                WiFi Vcc 3.34, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 15976
                WiFi IP address 192.168.0.175
                WiFi signal strength -62dBm, reconnections 0, sleep mode modem
                Socket states: 2 0 0 0 0 0 0 0
                === Expansion ===
              • ludodgundefined
                ludodg
                I guess I'm not running any grid compensation as I do not have a bed-level-sensor (yet)
                Might be something with my slicer ... (Slic3r Prusa Edition). The probleem seems less when slicing with cura... But that would very weird.
                • ludodgundefined
                  ludodg
                  @phaedrux said in Very slow printing Duet Wifi on Am8:
                  Can you explain to me where you read this value?
                  Do you mean Acceleration? So "M201 Z200"? Changing this to a higher value?
                  Or is it about M566?
                  Thx!
                    deckingman @ludodg
                    @ludodg said in Very slow printing Duet Wifi on Am8:
                    Not really. There are all sorts of speed settings in each slicer and each one will only do what you tell it to. Did you check to see if moves via the web console are at the correct speed? If so, then the problem is likely to be the speeds that were used to slice the model. In Slic3r, look in the "Print Settings" tab, then under "Speed". What are the various speeds set too?
                    ludodgundefined 1 Reply Last reply Reply Quote 0
                      deckingman @ludodg
                      Thx!
                      He means instantaneous speed change. But as you aren't using any form of flatness compensation, the Z axis won't be moving so don't worry about - that's not the reason for your problem.
                        You could post a gcode file that has been sliced with Slic3r and we could see all of the settings slic3r has used since it saves a copy of all it's settings at the end of every file.
                        • ludodgundefined
                          ludodg @deckingman
                          @deckingman
                          Indeed, moving via de webconsole seems to function ok. Homing is happening at normal speed.
                          Print Speed settings:
                          I'll check those, ... but it now uses the standard settings that came with the latest firm- and software :s
                          It has to be SlicerPE as the AM8 now prints Ok when using Cura for slicing.
                            Phaedrux Moderator @ludodg
                            @ludodg standard settings for which firmware and software?
