    effector tilting into bed on print
    22.2k
    • TimVukmanundefined
      TimVukman
      My kit did not have the blue cap shown covering the nozzle. Is that where the probe is?
        The probe is built into the PCB. It uses the nozzle to probe the bed and the PCB detects the force. See the commissioning section in the fitting instructions at https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer.
          TimVukman
          Ooops. Sorry about that. I hadn't read the commissioning part yet when I wrote my note. I'm glad to know that my kit wasn't missing any parts.
          I will follow the commissioning instructions very carefully and report back
            TimVukman
            I have gone through the commissioning section.
            I get the green light for the z-probe.
            The hot end stops on the way down when I tap the nozzle.
            Auto configuration returns
            G32
            Calibrated 6 factors using 10 points, deviation before 2.045 after 0.181
            Homeall
            G32
            Calibrated 6 factors using 10 points, deviation before 0.238 after 0.226
            G32
            Calibrated 6 factors using 10 points, deviation before 0.204 after 0.199
            Observations / Comments / Chance of printing?
            Please advise
            • Dougal1957undefined
              Dougal1957 @TimVukman
              @timvukman do several Autocals (without homing in-between) til it converges so the the before and after figures are about the same your figures still seem a bit high tho they are better than before as a matter of interest high many factors are you calibrating?
              Doug
                TimVukman
                I'm not sure what you mean by how many factors. I believe it is 6. That is my S setting
                  TimVukman
                  G32
                  Calibrated 6 factors using 10 points, deviation before 0.206 after 0.202
                  Better?
                    Dougal1957
                    yes it is the Param
                    6 or 8 is ok 7 or 9 will try and adjust the rod length which if your using haydn's rods should be set correctly anyway
                      TimVukman
                      Check this out!!!
                      G32
                      Calibrated 6 factors using 10 points, deviation before 0.206 after 0.206
                        dc42 administrators @TimVukman
                        @timvukman said in effector tilting into bed on print:
                        Check this out!!!
                        G32
                        That's a lot better than you were getting before. It's still a lot worse than is possible with the Smart Effector, so I suspect that either the carriages are out of alignment or the towers are not quite parallel to each other. If it's the carriages then the spirit level will probably show some varying tilt.
                        You can try printing with it, but you will need to use either a higher than normal first layer height, or mesh bed compensation.
                          TimVukman
                          I am going to order a metal kit for the top and bottom frames. There are visible spaces that I can't get rid of on the current injection molded ones.
                          Would my original 80 steps / mm change for the M92 command?
                          My test prints are really unusual. I will send a calibration cube so I can see what I am physically getting, but I tried a couple of small items and I am getting puddles. The hotend is not going up quickly enough and the nozzle is plowing through previous layers.
                          Should I get rid of the microstepping?
                            M92: the tower steps/mm depends on the number of teeth on the motor pulleys and on whether you have 1.8 or 0.9deg motors. 80 steps/mm is correct for 20 tooth GT2 pulleys and 1.8deg motors.
                            Microstepping: I recommend you use the default x16 with interpolation to 256 until you have the printer working well.
                              TimVukman
                              Thanks
                              Motors are 1.8. 20 tooth, microstepping is 16. Interpolation is off.
                              I'm going to try mesh bed compensation
                              Ran a test print. Way too much filament. Had to stop the print since it was bogged down in the cube.
                              X and Y dimensions appear pretty close. Z not doing well. Z height
                              DWC has extruder controls set at 1 mm feed amount and 1 mm feed rate. Extrusion slider is at 100%
                                TimVukman
                                Watching the print. Z is climbing at .2 for each layer which is what is set my my slicer software (Simplify3d)
                                I guess I need to take apart the hotend so I can see what length is being extruded when I tell it to extrude 100mm
                                  TimVukman
                                  Backed the filament out of the hot end.
                                  Extruded 10mm and it advanced 40mm. Searching for my notes on adjusting.
                                    TimVukman
                                    Extruder Adjusted
                                    Printing Calibration Cube.
                                    Print is looking very good. X and Y are 20mm.
                                    I can't thank you all enough for the help and support that you have provided. You are all consistently knowledgeable and helpful every time I contact you.
                                    My printer is completely silent except for the fans that are cooling the main board. There is no motor sound at all.
                                    I am really very impressed with the Smart Effector.
                                    Is there any way I can adapt my cartesian printer to support one of these? My current hot end is a square unit that mounts via screws through the top. It would be great to be able to bolt one of these on somehow.
                                    (edited for spelling)
                                      I'm glad you got there eventually!
                                      I guess you could mount a Smart Effector on a Cartesian printer, but it would take up quite a lot of room. You might want to look at the Precision Piezo, which is another type of nozzle-contact Z probe. I haven't used one, but several forum users have and can tell you more if you ask.
                                      PS - is it possible that the bed is not quite at right angles to the towers? If so then it's worth trying 8-factor calibration (S8 on the final G30 command in bed.g instead of S6). I suggest you use 13 or 17 probe points, e.g. 9 or 12 around the periphery, 3 half way from the centre, and the centre.
                                        TimVukman
                                        Thanks dc42. It is possible that the bed is not at right angles. I will try S8. I will search for the Precision Piezo.
                                        I wrote my not just before heading out. The print did not complete. The nozzle stopped rising and there was evidence of skipping from the belts.
                                        Time to order the metal frames. I will pick this printer up again later.
                                        Thanks for all the help
                                        Tim
                                          TimVukman
                                          Hi:
                                          I have now received and installed the aluminum corners for my printer. The lower ones are single thick pieces and the upper ones are the normal single thickness.
                                          I had hoped that I had some sort of gap in the old plastic parts causing my issues. With the aluminum, everything is tight!
                                          Auto Configuration is returning
                                          G32
                                          Calibrated 6 factors using 10 points, deviation before 0.071 after 0.066
                                          5:32:20 PMG32
                                          Calibrated 6 factors using 10 points, deviation before 0.075 after 0.067
                                          2:02:38 PMG32
                                          Calibrated 6 factors using 10 points, deviation before 0.071 after 0.058
                                          I am surprised that these numbers are changing. I would have expected that they would settle out and then stay the same each time.
                                          I did try to print, which was not a good idea. I am not printing at the center of the bed, and the print height is not steady.
                                          All ideas welcome
                                          adavidmundefined 1 Reply Last reply Reply Quote 0
                                            The numbers change because the bed probe reading heights you are getting are varying by about 0.01mm. This is a very small amount, comparable with the size of a single 1/16 microstep if your delta printer uses 1.8deg motors.
                                            If you are using M558 P5 with your Smart Effector, you may get slightly better results with M558 P8.
                                            Although your calibration deviation is not as low as many users obtain, it should be good enough to print with. I used to print with a calibration deviation of 0.12mm before I upgraded my delta to linear rails and Smart Effector.
