    Cannot reach web interface
    1.1k
    • Brmattundefined
      Brmatt
      I am having trouble reaching the web control interface on chrome. I have been following This guide and when I get to step 8 everything seems to be running the same, yet I cannot access the web interface. Please help. I am using a duet ethernet v3 with firmware version 1.21 installed. Here is what the sd card looks like when opened:0_1533831576654_sd card.PNG
      Here is the inside of www:0_1533831604145_www.PNG
      Here is the inside of sys:0_1533831620581_sys.PNG
      And here is my config.g file:0_1533831670372_config.PNG
      • ngwpowerundefined
        ngwpower
        I used this program to get mine working! https://configurator.reprapfirmware.org/
        It makes a zip file and you load it to your desktop. load on a SD card and try.
        • Brmattundefined
          Brmatt
          My printer specs are incompatible with this program
          ngwpowerundefined titanhuskerundefined 2 Replies Last reply Reply Quote 0
          • ngwpowerundefined
            ngwpower @Brmatt
            @brmatt I have the Wifi version and just trying to help. O Well. good luck!
            Brmattundefined 1 Reply Last reply Reply Quote 1
            • Brmattundefined
              Brmatt @ngwpower
              @ngwpower Thank you! Yeah i tried that a little bit ago to see if i could skip the web control but unfortunately no dice
              • titanhuskerundefined
                titanhusker @Brmatt
                @brmatt I had an issue with this as well. The only fix I could could find to make it work, was to place a copy of the DuetWifiControl folder in the sys folder and another copy renamed www. I also had to the do the same on the SD card outside of the sys folder.
                Example
                SD CARD/www
                SD CARD/DuetWifiControl
                SD CARD/sys/www
                SD CARD/sys/DuetWifiControl
                If I delete any of them, I don't have any control either. I was under the assumption, that you were only suppose to need a www folder in the sys folder, maybe @dc42 can clarify. Also I am using 1.19.2 firmware & 1.19.3 wifiserver firmware. I don't know why but the blue light on the board for the Wifi doesn't turn on with that firmware, but it does for 1.21.
                • Brmattundefined
                  Brmatt
                  Interesting. I'll give that a try. Seems a bit odd so hopefully @dc42 can clarify as you said. Thanks for the tip
                    Looks like your config.g file still contains the following line:
                    M552 P192.168.1.14
                    As indicated in the comment line before that one, you should replace the IP address (192.168.1.14) with an IP address that will work with your router. Or you can use 0.0.0.0 and it will ask the router for an IP address, but then you will have to find out what IP address has been assigned, either from the router or by sending M552 from USB or PanelDue.
                    Brmattundefined 1 Reply Last reply Reply Quote 0
                    • Brmattundefined
                      Brmatt @dc42
                      @dc42 It worked! I'm finally in! Thank you.
