X and Y motors not moving
motor not running
2.5k
    samlogan87
    Hi there everyone,
    I am having issues with the core xy printer that I am building. I am running 3x Z axis Nema 23 motors that are working fine, but the X and Y axis are not. I have tried switching the motors to the Z drivers and they work. Z axis ones do not work on drivers 0 and 1. I have a DueX2 and have put the x and y motors on there and it still does not work. I am thinking it could be something to do with the config. Can someone cast their eye over it and see if they can see anything.
    M555 P1 ; Set firmware compatibility to look like RepRapFirmare
    M667 S1 ; Select CoreXY mode
    ;M912 P0 S# CPU Temp
    M550 PSam's Printer ; Set machine name
    M552 P192.168.1.40 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P0 S0 ; Drive 0 goes forwards X Axis
    M569 P1 S0 ; Drive 1 goes forwards Y Axis
    M569 P2 S0 ; Drive 2 goes forwards Z Axis 1
    M569 P3 S1 ; Drive 3 goes forwards Z Axis 2
    M569 P4 S0 ; Drive 4 goes forwards Z Axis 3
    M569 P5 S1 ; Drive 5 goes forwards Extruder
    ; Motor remapping for dual Z
    M584 X0 Y1 Z2:3:4 U3 V4 E5 P6 ; Driver 0 For X, 1 for Y, Z=2:3:4 U3 V4, Extruder 5
    M350 X16 Y16 Z16:16:16 U16 V16 E16 I1 ; Configure microstepping with interpolation
    M92 X80 Y80 Z400:400:400 U400 V400 E420 ; Set steps per mm
    M566 X150 Y150 Z12:12:12 U12 V12 E120 ; Set maximum instantaneous speed changes (mm/min)
    M203 X150 Y150 Z180:180:180 U180 V180 E1200 ; Set maximum speeds (mm/min)
    M201 X250 Y250 Z250:250:250 U250 V250 E250 ; Set accelerations (mm/s^2)
    M906 X850 Y850 Z1850:1850:1850 U1850 V1850 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X0 Y0 Z0 U0 V0 S1 ; Set axis minima
    M208 X400 Y400 Z420 U420 V420 S0 ; Set axis maxima
    M671 X256.6:-53.6:100 Y239.10:239.1:65.50 S3 ; Define the X and Y coordinates of the leadscrews. Motor order: FR (1), FL (2), RC (3).Snn Maximum correction in mm to apply to each leadscrew (optional, default 1.0)
    M574 X1 Y1 S1 ; X home to min. Y home to max. Normally Closed limit switches.
    M307 H5 A-1 C-1 D-1 ; Disable the 4th Heater to free up PWM channel 2 on the Duex board for BL TOUCH.
    M574 Z1 S2 ; Define Z to use Probe. Home to Min
    M558 P5 X0 Y0 Z1 H5 F120 T6000 ; MUST CHANGE H=== TO SUIT BEFORE RUNNING!!!!!!!!!!!!!!
    G31 X0 Y0 Z1.5 P25 ; MUST CHANGE X AND Y OFFSET BEFORE RUNNING AND THEN TUNE Z!!!!!!!!!!!!11
    M581 E0 S1 T1 C0 ; invoke trigger 2 when a rising edge is detected on the E1 or E2 endstop input
    ; Define mesh grid
    M557 X0:400 Y0:400 S20
    M140 H1 ; Remap heated bed to heater 1
    M305 P0 X200 ; Set PT100 for Hot End
    M143 H0 S300 ; Set temperature limit for heater 0 to 300C
    M307 H0 A350 C139 D5.5 B0 ; set model parameters for heater 0 and use PID mode
    M305 P1 X201 ; Set PT100 Channel 2 to Heat Bed
    M143 H1 S130 ; Set temperature limit for heater 1 to 130C
    M307 H0 A249.7 C1079.9 D20.0 S1.00 V24.3 B0 ; set model parameters for heater 1 and use PID mode gain 249.7, time constant 1079.9, dead time 20.0,
    M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 H0 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H0 S"Extruder" ; Define tool 0
    ; Automatic power saving
    M911 S10 R11 P"
    M913 X0 Y0
    G91
    M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
    Regards,
    Sam
    Custom Core-XY
    undefined 1 Reply Last reply 14 Aug 2018, 08:37 Reply Quote 0
      If you send M584 with no parameters in the console what do you get back?
        samlogan87
        Hi there,
        This is what I get:
        11:51:28 AM M584
        Driver assignments: X0 Y1 Z2:3:4 U3 V4 E5, 5 axes visible
        Regards,
        Sam
        Custom Core-XY
          Can you test without your additional axis defined?
            samlogan87
            Yeah just tried it and nothing.
            Custom Core-XY
              samlogan87
              this is what I have in there
              M584 X3 Y4 Z2 P3 ; Driver 0 For X, 1 for Y, Z=2:3:4 U3 V4, Extruder 5 :0:1 U3 V4 E5
              M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation :16:16 U16 V16
              M92 X80 Y80 Z400 E420 ; Set steps per mm :400:400 U400 V400
              M566 X150 Y150 Z12 E120 ; Set maximum instantaneous speed changes (mm/min) :12:12 U12 V12
              M203 X150 Y150 Z180 E1200 ; Set maximum speeds (mm/min) :180:180 U180 V180
              M201 X250 Y250 Z250 E250 ; Set accelerations (mm/s^2) :250:250 U250 V250
              M906 X850 Y850 Z1850 E800 I50 ; Set motor currents (mA) and motor idle factor in per cent :1850:1850 U1850 V1850
              Does it look correct?
              Custom Core-XY
              undefined 1 Reply Last reply 14 Aug 2018, 07:41 Reply Quote 0
                samlogan87
                I have done some more troubleshooting. When I remap the extruder to one of the x and y drivers it works as it should. I can use the extrude and retract buttons to make the x and y axis to move. When I remap it back, I can not get it to home. The Z axis moves as it should, but the x or y won't move
                Custom Core-XY
                  How are you trying to move the motors?
                  If you send this does the motor move?
                  G91
                  G1 S2 X10 F3000
                    samlogan87
                    Currently I have just been trying to get it to home the axis. I have the homing g code files from the configurator and when I run it, the Z axis shifts up (down in my case being a corexy) and then nothing for the x and y until I push the end stops in. Once I do this, the z axis then moves again. It says that the axis have homed and when I try and shift it, nothing happens.
                    I will give that a try and let you know.
                    Custom Core-XY
                      samlogan87
                      I gave that a go and it doesn't move.
                      Custom Core-XY
                        @samlogan87 said in X and Y motors not moving:
                        1. Please clarify: do you have X and Y mapped to drivers 3 and 4 as here, or mapped to drivers 0 and 1 as in the config.g file you listed in your first post?
                        2. You can send following commands to test the X motor individually:
                        G91 ; relative movement
                        G1 S2 X10 F1000 ; move the X motor forward 10mm
                        G1 S2 X-10 F1000 ; move the X motor back 10mm
                        Similarly for the Y motor.
                          samlogan87
                          @dc42 said in X and Y motors not moving:
                          G1 S2 X-10 F1000
                          Hi there,
                          Yes sorry it is as the above configuration. I was just making sure in that bit, that it was not a motor issue by mapping it to other drivers. Turns out the motors are fine.
                          I tried that and nothing. They do not move at all.
                          I am very confused as they turn when I set them up as extruders and use the retract button on the UI
                          Custom Core-XY
                            Just on a lark, can you delete the entire line and type it out again from scratch?
                              samlogan87
                              Yeap I did that.
                              G1 S2 X100 F1000 and it did not move at all
                              Custom Core-XY
                                Sorry, I meant the M584 command
                                  Also, are you sure the x and y steps per mm are 80?
                                  You said when you switched them to be extruders they worked but the extruder steps are 400.
                                    samlogan87
                                    Sorry I typed M584 and got
                                    M584
                                    I tried changing the steps per mm to 800 and it just sits there and hums
                                    Custom Core-XY
                                      If you replace your m584 command in config.g with just M584 X0 Y1 and nothing else do they work then?
                                        samlogan87
                                        Tried that and still nothing. Sounds like it wants to move but it doesn't do anything unfortunately
                                        Custom Core-XY
                                          Can you send M906 and verify that the motor currents are being accepted?
                                          9 out of 27
