    extruder works but print not starting
    3.9k
    • Marine85undefined
      Marine85
      I am using Duetwifi with Titan Extruder my printer homing x,y,x successfully and the heater heating up to the printing temp
      it shows that the printing is in progress but no print at all
      i got a message Filament n/a layer n/a
      help please!!
      Thanks,
        Have you tested extrusion, and calibrated the extruder steps/mm?
        Marine85undefined 1 Reply Last reply Reply Quote 0
        • Marine85undefined
          Marine85 @dc42
          @dc42 Hi Dave
          I did but i edited my config files and uploaded many time after i calibrated the extruder
          do i need to re-calibrate it again?
          in simulation of print it works but when i try to print it heat up and home axis and looks ready for printing but not moving , and shows in duepanel and web interface the print time is going on but change in x,y,z or E steps.
            Can you post the first 50 or so lines of a gcode file you're trying to print?
            Can you also post your config.g?
            Marine85undefined 2 Replies Last reply Reply Quote 0
            • Marine85undefined
              Marine85 @Phaedrux
              @phaedrux
              ; generated by RepRapFirmware Configuration Tool on Wed Aug 08 2018 15:32:33 GMT+0400 (Gulf Standard Time)
              M550 PTeignbridge Vigor ; Set machine name
              M551 Pteignprop ; Set password
              M552 S1 ; Enable network
              M587 S"TEIGNBRIDGE" P"peacock1" ; Configure access point. You can delete this line once connected
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M584 X0 Y1 Z2:3:4:5 U3 V4 W5 E6 ; custome driver mapping Split Z into Z,U,V and W
              M569 P0 S0 ; Drive 0 goes forwards
              M569 P2 S0 ; Drive 2 goes forwards
              M569 P3 S0 ; Drive 3 goes forwards
              M569 P4 S0 ; Drive 4 goes forwards
              M569 P5 S0 ; Drive 5 goes forwards
              M569 P6 S0 ; Drive 6 goes forwards
              M350 X16 Y16 Z16:16:16:16 U16 V16 W16 E16 I1 ; Configure microstepping with interpolation
              M92 X80 Y80 Z640:640:640:640 U640 V640 W640 E837 ; Set steps per mm
              M566 X900 Y900 Z16:16:16:16 U16 V16 W16 E1600 ; Set maximum instantaneous speed changes (mm/min)
              M203 X6000 Y6000 Z180:180:180:180 U180 V180 W180 E20000 ; Set maximum speeds (mm/min)
              M201 X500 Y20 Z250:250:250:250 U250 V250 W250 E8000 ; Set accelerations (mm/s^2)
              M906 X1500 Y1500 Z2700:2700:2700:2700 U2700 V2700 W2700 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout(reduce all currents for Inactive motors)
              M208 X0 Y0 Z0 U0 V0 W0 A0 S1 ; Set axis minima
              M208 X1200 Y1200 Z1200 U1200 V1200 W1200 S0 ; Set axis maxima2
              M574 X1 Y1 U2 V2 W2 S1 ; Set active high endstops
              M574 Z1 S2 ; Set endstops controlled by probe
              M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
              M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
              G31 P25 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
              M557 X100:600 Y100:600 S250 ; Define mesh grid
              M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
              M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M563 P0 D0 H1 ; Define tool 0
              Phaedruxundefined 3 Replies Last reply Reply Quote 0
              • Marine85undefined
                Marine85 @Phaedrux
                @phaedrux
                herein the file i am trying to print
                ;TIME:25459
                ;Filament used: 66.807m
                ;Layer height: 0.4
                ;Generated with Cura_SteamEngine 3.4.0
                M104 S230
                M109 S230
                M82 ;absolute extrusion mode
                G28 ;Home
                G1 Z15.0 F6000 ;Move the platform down 15mm
                ;Prime the extruder
                G92 E0
                G1 F200 E3
                G92 E0
                M83 ;relative extrusion mode
                G1 F1500 E-6.5
                ;LAYER_COUNT:170
                ;LAYER:0
                M107
                G0 F3600 X18.043 Y-85.362 Z0.3
                ;TYPE:SKIRT
                G1 F1500 E6.5
                G1 F1800 X18.852 Y-85.187 E0.04129
                G1 X27.011 Y-82.963 E0.42191
                G1 X27.803 Y-82.701 E0.04162
                G1 X35.72 Y-79.602 E0.42416
                G1 X36.475 Y-79.26 E0.04135
                G1 X43.944 Y-75.377 E0.41998
                G1 X44.658 Y-74.956 E0.04135
                G1 X51.709 Y-70.279 E0.42213
                G1 X52.374 Y-69.785 E0.04133
                G1 X58.886 Y-64.388 E0.42196
                G1 X59.498 Y-63.822 E0.04159
                G1 X65.414 Y-57.744 E0.42316
                G1 X65.96 Y-57.12 E0.04137
                G1 X71.16 Y-50.496 E0.42014
                G1 X71.637 Y-49.818 E0.04136
                G1 X76.133 Y-42.633 E0.42286
                G1 X76.536 Y-41.906 E0.04147
                G1 X80.235 Y-34.298 E0.42205
                G1 X80.558 Y-33.532 E0.04147
                G1 X83.433 Y-25.557 E0.42294
                G1 X83.673 Y-24.76 E0.04153
                G1 X85.685 Y-16.51 E0.42366
                G1 X85.838 Y-15.696 E0.04132
                G1 X86.953 Y-7.36 E0.41959
                G1 X87.019 Y-6.533 E0.04139
                G1 X87.243 Y1.923 E0.42202
                G1 X87.221 Y2.752 E0.04137
                G1 X86.545 Y11.201 E0.42287
                G1 X86.435 Y12.025 E0.04147
                G1 X84.874 Y20.301 E0.42017
                G1 X84.678 Y21.104 E0.04124
                G1 X82.232 Y29.225 E0.42314
                G1 X81.949 Y30.009 E0.04158
                G1 X78.659 Y37.803 E0.42207
                G1 X78.297 Y38.549 E0.04137
                G1 X74.199 Y45.949 E0.42202
                G1 X73.756 Y46.656 E0.04162
                G1 X68.866 Y53.611 E0.42417
                G1 X68.354 Y54.263 E0.04136
                G1 X62.809 Y60.597 E0.41999
                G1 X62.231 Y61.19 E0.04131
                G1 X56.014 Y66.929 E0.42212
                G1 X55.376 Y67.459 E0.04138
                G1 X48.586 Y72.505 E0.42206
                  Phaedrux Moderator @Marine85
                  @marine85 said in extruder works but print not starting:
                  Where does the A0 come from?
                  It would appear that you are missing a tool select command anywhere. Without it, the hotend won't be enabled. Try adding T0 to the end of your config.g to enable it at startup. And add T0 to your Cura start gcode. You should probably also change Cura to use RepRap flavour gcode. I think if you do that it will add the tool selection itself when it sends the temp commands.
                    Do you have a part cooling fan? The way it is configured now all fans are thermostatically linked to the hotend.
                    Typically Fan0 would be used as the part cooling fan and Fan1 for the hotend. Fan2 possibly for cooling the duet.
                    For example, here is how I have it configured.
                    M106 P0 S0 H-1 C"Part Cooling"     ; Set fan 0 (Part cooling blower) G-code controlled. Thermostatic control is turned off
                    M106 P1 S1 H1 T45 C"Hotend Fan"   ; Set fan 1 (Hotend fan) Thermostatic control. Turns on when hotend reaches 45c
                    M106 P2 F100 L0.2 B0.5 T30:40 H100:101:102 C"Duet Fans"	; Set fan 2 Duet case fan. Tied to CPU and driver temps.
                      Don't forget to calibrate the trigger height for your zprobe.
                      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                      • Marine85undefined
                        Marine85 @Phaedrux
                        @phaedrux many thanks
                        I will do these modifications and check
                        • Marine85undefined
                          Marine85
                          I think the problem is with remapping the Extruder to driver "6" (E3) on duex2
                          but when reconfigure it again to driver"3" it works but the independent Z homing macro not working!
                          the macro was working fine when i map drivers 2,3,4 and 5 to Z with virtual axis U,V and W.
                          any help please how to sort our this issue?
                          Thanks,
                            1. Is your config.g file the same as in your post of 15 August?
                            2. Did you make sure that Tool 0 is selected, either in your slicer start GCode or before you start a print?
                            • Marine85undefined
                              Marine85 @dc42
                              @dc42 Yes it is the same config
                              M208 X0 Y0 Z0 U0 V0 W0 S1 ; Set axis minima
                              ; Automatic power saving
                              M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                              T0 ; Select first tool
                              • Marine85undefined
                                Marine85
                                the macro i use for 4 x z axis homing to max end stop is
                                M400 ; make sure everything has stopped before we make changes
                                M574 Z2 U2 V2 W2 S1 ; set endstops to max
                                G91 ; use relative positioning
                                M584 Z2 U3 V4 W5 ; split z to control z,u,v and w
                                G1 Z1350 U1350 V1350 W1350 F4000 S1 ; course home z
                                G1 Z-250 U-250 V-250 W-250 F6000 S2 ; Down Z relative to current position
                                G90 ; back to absolute positioning
                                M400 ; make sure everything has stopped before we reset motors current
                                M584 Z2:3:4:5 ; combined z again
                                M574 Z2:3:4:5 S2 ; set endstops back to normal
                                M999 ; restart
                                  I am wondering whether the stepper driver 6 output could be faulty. Can you try driver 7 instead, if it is a DueX5 not a DueX2? Alternatively, test driver 6 by e.g. connecting the X motor to it and using X6 in the M584 command instead of X0.
                                  • Marine85undefined
                                    Marine85
                                    Unfortunately i have duex2 the driver is working when assigned to stepmotor not extruder.
                                    May be if i ordered duex5 would be a solution or this may be bug with the firmware?
                                      dc42 administrators @Marine85
                                      No i don't think it's a firmware bug. Please try removing E6 from your M584 command and changing X0 to X6 in it, and with the Duet powered down move the X motor connector to the E3 connector on the DueX2. Then power up and test the X axis. That will show whether the E3 driver (driver 6) is working correctly.
                                      • Marine85undefined
                                        Marine85
                                        Hi Dave , I remapped the driver 6 to x and it is working now.
                                        i will check the printing today.
                                        I have another question I am testing PNP sensor LJ12A3-4-Z/BY and i did the static testing and it give me 1000 in in DWC.
                                        when i configure my homez.g using this code Homing Z using a Z probe the z moves 4mm and stop
                                        G91 ; relative mode
                                        G1 Z4 F200 S2; raise head 4mm to ensure it is above the Z probe trigger height
                                        G90 ; back to absolute mode
                                        G1 X100 Y100 S2 F2000 ; put head over the centre of the bed, or wherever you want to probe
                                        G30 ; lower head, stop when probe triggered and set Z to trigger height
                                        I used the code of Homing Z using a Z min endstop switch in homez.g
                                        and looks working i dont know if bed probing will work or not herein my code
                                        config.g
                                        M208 X1200 Y1200 Z1200 S0 ; Set axis maxima
                                        M574 X1 Y1 S1 ; Set active high endstops (NC)
                                        M558 P5 X0 Y0 Z1 T4000 F300 H10 ; Set Z probe type to switch and the dive height + speeds(Analog Z probe, also used for homing the Z axis)
                                        G31 Z0 P500 ; Set Z probe trigger value, offset and trigger height
                                        M557 X15:1185 Y15:1185 S100 ; Define mesh grid
                                        homez.g
                                        G91 ; relative mode
                                        G1 Z4 F200 S2 ; raise head 4mm to ensure it is above the switch trigger height
                                        G1 X0 Y0 S2 F2000 ; put the head wherever you want it to be when you home Z (omit this line if it doesn't matter)
                                        G91 ; relative mode
                                        G1 Z-1200 S1 F100 ; move Z down until the switch triggers
                                        G92 Z0 S2 ; tell the firmware that we are at Z=0mm
                                        Firmware Electronics: Duet WiFi 1.02 or later + DueX2
                                        Firmware Version: 2.02beta1(RTOS) (2018-08-12b5)
                                        WiFi Server Version: 1.21
                                        Web Interface Version: 1.22.1
                                          Is the reading 1000 when the sensor is close to the bed and triggered, or when it is far from the bed and not triggered?
                                          • Marine85undefined
                                            Marine85
                                            Reading 1000 when triggered and sensor indicator led on
