    Laser Filament Monitor - test results
    Filament Monitor
    16
    139
    22.0k
    • wilrikerundefined
      wilriker @Qdeathstar
      @qdeathstar You seem to like ABS. 😉
      Manuel
      My Tool Collection
        T3P3Tony administrators @Qdeathstar
        @qdeathstar said in Laser Filament Monitor - test results:
        Ok, last ABS test
        Matterhackers Light - Blue ABS filament - Benchy Test
        Calculated Steps/mm 424
        M591 D0
        Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position -2.4, brightness 92, shutter 11, measured minimum 0%, average 93%, maximum 102% over 3975.4mm
        minimum 0?
        do you mind checking that again?
        Qdeathstarundefined 1 Reply Last reply Reply Quote 0
        • Qdeathstarundefined
          Qdeathstar
          Yes, i can rerun that test later today. I think that might have been a real slippage, as this blue filament feels pretty slippery. I also noticed while i was loading it it didn't move the first time i pressed "extrude" but i chalked it up to me accidentally pressing the "retract" button instead. Its about 2 years old....
          • kraegarundefined
            kraegar
            I like spreadsheets, so I created one for tracking my results. Any other data needed?
            https://docs.google.com/spreadsheets/d/1a5suKtijUsatl3DhUFiox_rfW39qo9kHSlihYHaAcxo/edit?usp=sharing
            tinkerzundefined 1 Reply Last reply Reply Quote 0
            • tinkerzundefined
              tinkerz @kraegar
              @kraegar Thank you! Not sure why I didn't think of putting it up on Google docs, here I have all my results in good 'ol Notepad++. Thank you again. This makes it easy to keep updated without worrying about saving, losing or sharing.
              Tinkerz
              kraegarundefined 1 Reply Last reply Reply Quote 0
              • kraegarundefined
                kraegar @tinkerz
                @tinkerz No problem - I have a ridiculous number of data tracking spreadsheets for 3d printing. I can't do anything without tracking it, lol.
                  Qdeathstar @T3P3Tony
                  @t3p3tony said in Laser Filament Monitor - test results:
                  Ok, last ABS test
                  M591 D0
                  minimum 0?
                  M591 D0
                  Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position -3.0, brightness 91, shutter 11, measured minimum 88%, average 95%, maximum 102% over 3973.3mm
                  Better result this time.
                  • wilrikerundefined
                    wilriker
                    Finally managed to print the sensor housing. It seems that the lazy-me (why should I disassemble my X axis before lubricating it?) got some PTFE on my build plate - perfect for first-layer adhesion. 🤦 Luckily nothing that gluestick won't overcome. 😂
                    So, assembly and mounting of the sensor probably tonight. 🙂
                    Manuel
                    My Tool Collection
                    • wilrikerundefined
                      wilriker
                      Finally, the first result I can contribute:
                      Generic Black PLA (the same that is used for the housing):
                      Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 120%, check every 3.0mm, current position -7.9, brightness 60, shutter 17, measured minimum 80%, average 87%, maximum 93% over 320.6mm
                      Housing: @dc42 original, Open Top, 9mm base
                      PTFE Tubing: Generic 4mm OD 2mm ID (I will probably switch to the included Capricorn when I first switch housing parts.
                      I am so happy to be part of the test group. As I don't have too many filaments I will probably mainly be concentrating on housing performance.
                      Also, this gave me a chance to solve a very annoying issue I introduced myself when I added my reverse bowden. It literally took me 15-20 minutes(!) to change filament because the extruder-near end of it was totally in the way and I ended up disassembling the extruder every other time.
                      The sensor housing now also is my reverse bowden endpoint and is mounted via nuts and screws so I can easily remove it when loading filaments. 🕺
                      EDIT: Also no started a Google Spreadsheet.
                      Manuel
                      My Tool Collection
                      • fmaundefined
                        fma
                        Ok, here is my first result. I use David's enclosure, printed in black PLA.
                        I printed a part with Dailyfil cream white: https://www.filimprimante3d.fr/filament-pla-175-mm/1470-bobine-pla-dailyfil-blanc-creme-175-mm-1kg.html
                        Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 140%, check every 3.0mm, current position -10.2, brightness 94, shutter 8, measured minimum 53%, average 93%, maximum 107% over 5764.6mm
                        Frédéric
                        • fmaundefined
                          fma
                          Second test with SOVB3D purple PLA: http://www.sovb3d.fr/pla-175mm-standard-500g/90-fil-pla-violet-175mm-500g.html
                          Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 140%, check every 3.0mm, current position 2.7, brightness 93, shutter 11, measured minimum 56%, average 84%, maximum 99% over 3425.2mm
                          Frédéric
                            FWIW the shutter reading is an indication of how much of the laser light is returning back to the sensor, which should be mostly determined by how reflective the filament is. High shutter reading = low refectivity.
                            • wilrikerundefined
                              wilriker @dc42
                              @dc42 I wanted to ask about shutter anyway. What is the range of values and what qualifies as high/low value?
                              And when we are at that, can you also say something about the brightness value?
                              Manuel
                              My Tool Collection
                                The brightness is the average brightness of IR light received on the sensor. It doesn't usually vary as much as the shutter does, because the sensor appears to adjusts the shutter to try to keep the brightness constant.
                                • kraegarundefined
                                  kraegar
                                  So to be clear, the ideal situation would be a totally enclosed housing that doesn't reflect any IR back?
                                    dc42 administrators @kraegar
                                    @kraegar said in Laser Filament Monitor - test results:
                                    Yes, I think so.
                                    • kraegarundefined
                                      kraegar
                                      What wavelength is the IR?
                                        850nm.
                                        • fmaundefined
                                          fma
                                          Another result, with Dailyfil Dark gray PLA: https://www.filimprimante3d.fr/filament-pla-175-mm/1479-pla-175mm-dailyfil-gris-fonce-1kg.html
                                          Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 140%, check every 3.0mm, current position -1.7, brightness 92, shutter 17, measured minimum 89%, average 97%, maximum 109% over
                                          9032.8mm
                                          Soon a result with their blue PLA ("Tardis RAL")...
                                          Frédéric
                                          • fmaundefined
                                            fma
                                            Dailyfil Dark blue (aka 'Tardis') PLA: https://www.filimprimante3d.fr/filament-pla-175-mm/1483-filament-bleu-fonce-dailyfil-pla-1kg-175-mm.html
                                            Duet3D laser filament monitor on endstop input 3, disabled, allowed movement 40% to 140%, check every 3.0mm, current position -9.5, brightness 94, shutter 17, measured minimum 60%, average 97%, maximum 131% over 15377.6mm
                                            Frédéric
