Tool changer commands
5.1k
    RajaaKahel @whosrdaddy
    @whosrdaddy
    If I write in tpre0 to park T1 then select T0 during a print that's ok. But then at the beginning of a print it will also do the same (to park T1 then select T0) but T1 is already parked, That will be horrible crash.
    As I said I'm pretty confused, so please if you can't explain with simple steps don't confuse me more 🙂
    Thanks for the input 🙂
      whosrdaddy
      Actually parking T1 should be done in TFree1.g, don't touch other tools in the Txxxx Macro's
        T3P3Tony administrators
        @RajaaKahel the Duet does not know that a particular T0 command is at the start of a print, or part way through a print, which is why i am suggesting having the appropraite pick up command in your start gcode as included in the slicer.
        Alternatively always have the printer have T0 picked up when its in an idle state.
        undefined 1 Reply Last reply 21 Aug 2018, 18:08 Reply Quote 0
          RajaaKahel @T3P3Tony
          @t3p3tony and @whosrdaddy
          Thank you for your input! I'll try to figure this out with a new cup of coffee 🙂
          undefined 1 Reply Last reply 21 Aug 2018, 18:13 Reply Quote 0
            whosrdaddy @RajaaKahel
            @rajaakahel : I don't know if you read this one too: https://duet3d.dozuki.com/Wiki/Gcode#Section_T_Select_Tool?
            This is the most informative doc about tools and the sequence followed on tool changes.
            undefined 1 Reply Last reply 21 Aug 2018, 21:14 Reply Quote 0
              @whosrdaddy
              Thank you, I started to make progress finally, after some painful crashes especially with the interference from S3D..
                RajaaKahel
                Ok, so I removed any parking or picking commands from Simplify3D, and did the following:
                ; tfree0.g
                ; called when tool 0 is freed
                M98 P/macros/parkT0
                ; tfree1.g
                ; called when tool 1 is freed
                M98 P/macros/parkT1
                ; tpre0.g
                ; called before tool 0 is selected
                M98 P/macros/selectT0
                ; tpre1.g
                ; called before tool 1 is selected
                M98 P/macros/selectT1
                It works fine during a print, but at the beginning it doesn't pick any tool, and at the end it doesn't park any tool. Is there a way to fix this?
                I noticed that I don't have files such as start.g or end.g in the files section, anyway is there such a start file for T0 and another one for T1? (same for the end?)
                undefined undefined 2 Replies Last reply 22 Aug 2018, 14:39 Reply Quote 0
                  T3P3Tony administrators @RajaaKahel
                  @rajaakahel glad you got it working on tool change!
                  start and end gcodes are normally configured in you slicer so you can add the relevant macro calls to your slicer.
                  One thing I note it that if you don't always start with tool 0 for every print then its probably better to have the "default state " of your printer with the tool changer with tool 1 selected.
                  undefined 1 Reply Last reply 22 Aug 2018, 15:24 Reply Quote 0
                    @t3p3tony Thank you!
                    Unfortunately Starting Script and Ending Script in Simplify3D don't allow IF commands such as {IF NEWTOOL=0}
                    It's only allowed in Tool Change Script section.
                    And as you know each print is different, one time you start with a tool and another time you start with another tool (same for finishing). So I would love to make it automatic..
                    undefined 1 Reply Last reply 22 Aug 2018, 16:57 Reply Quote 0
                      @rajaakahel in that case you are going to have to have a default state of the printer with always having T0 (or T1) selected. So your end script always selects T0 so you know at the start that T0 is selected. That way when the printer changes to T1 it will park T0 and then pickup T1. That should work even if the printer start with T1, as long as S3d explicitly chooses the tool every time.
                      undefined 1 Reply Last reply 22 Aug 2018, 18:05 Reply Quote 0
                        @t3p3tony Thank you very much for your time! I'll look into this closely. I also submitted a request to S3D to allow IF commands in start and end scripts. I hope it can be added later in the Duet firmware as well.
                        Please can you check my other post whenever you have time?
                        https://forum.duet3d.com/topic/6517/setting-z-offset-for-t1
                          dc42 administrators @RajaaKahel
                          @rajaakahel, make sure you start with no tool selected. You probably have T0 at the end of config.g, if so then remove that. Also include T-1 in your slicer end script to deselect and park the active tool.
                          undefined 2 Replies Last reply 23 Aug 2018, 18:50 Reply Quote 0
                            RajaaKahel @dc42
                            @dc42 Thank you! I'm still trying to work it out to be full automatic. Will get back to you with the results 🙂
                              RajaaKahel @dc42
                              @dc42 Hello again, I managed to
                              park any nozzle at the end of a print by putting the following Ending Script in my slicer:
                              G1 E-15 F4000
                              M104 S0 ; turn off extruder
                              M140 S0 ; turn off bed
                              T0
                              M98 P/macros/parkT0
                              G28 X ; home x and y axes
                              G28 Y ; home x and y axes
                              M84 ; disable motors
                              M107
                              M1
                              In Duet firmware I have the following:
                              ; tfree0.g
                              M98 P/macros/parkT0
                              ; tfree1.g
                              M98 P/macros/parkT1
                              ; tpost0.g
                              ; called after tool 0 is selected
                              ; tpost1.g
                              ; called after tool 1 is selected
                              But the problem is when I start a print, Duet is always activating T0 (even if the first tool to run is T1) when starting to heat up, but it does not actually go and pick T0 tool (so it thinks T0 is already picked up).
                              I can work this around by picking T0 at the end of each print without parking it. But I want both nozzles to be parked to prevent oozing and stuff.
                              So the question is: how can I tell the duet to start a print (heat up) without activating any tool until the print gcode tells it to activate (thus pick up) the right tool?
                              *I don't have T0 or T1 at the end of config.g
                              *I tried to include T-1 or M1 at the Starting Script of my slicer, but it didn't work. (Duet is always activating T0 regardless of what tool gonna start).
                              *I tried sending M1 manually before I start a print (to deactivate tools) but same thing happens when a print is started by heating up (activating T0).
                              undefined undefined 2 Replies Last reply 24 Aug 2018, 10:15 Reply Quote 0
                                zerspaner_gerd @RajaaKahel
                                @rajaakahel Make sure that all axes are referenced before the tool command!
                                Only then will the tool script be triggered!
                                @rajaakahel said in Tool changer commands:
                                Do you have a start.g file? With me the duet does not select a tool at the print start, so you have somewhere a tool command.
                                Does not T-1 work? There must be no M84, M18, M1 before.
                                G1 E-15 F4000
                                M104 S0; Extruder
                                M140 S0 ausschalten; Bett ausschalten
                                T-1
                                G28 X; home x und y Achsen
                                G28 Y; home x und y Achsen
                                M84; Deaktivieren Sie die Motoren
                                M107
                                M1
                                You can activate tools with T# P0 (# = Tool Number) without changing the tool
                                https://duet3d.dozuki.com/Wiki/Multiple_tools_and_Tool_change_macros
                                Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                                undefined 1 Reply Last reply 24 Aug 2018, 14:18 Reply Quote 0
                                  RajaaKahel @zerspaner_gerd
                                  @zerspaner_gerd
                                  "Make sure that all axes are referenced before the tool command!
                                  Only then will the tool script be triggered!"
                                  You mean by "referenced" homed? if so, then yes they are homed.
                                  "Do you have a start.g file? With me the duet does not select a tool at the print start, so you have somewhere a tool command."
                                  No I don't have a start.g file in the Duet. And in my slicer only G28 is included in the Start Script. I don't find any tool command..
                                  "Does not T-1 work? There must be no M84, M18, M1 before."
                                  I tried T-1 and M1 in the Start Script of my slicer, they do nothing. After I upload a print to the Duet, it immediately choose T0 (but doesn't activate the tpost1.g (same if I manually send T-1 or M1 before I start a print).
                                  Where should I put T# P0?
                                  Again, Duet is always activating T0 (even if the first tool to run is T1) when starting to heat up, but it does not activate the tpost1.g.
                                    RajaaKahel
                                    Here are all my settings if that helps..
                                    Macros:
                                    https://drive.google.com/open?id=1Nwte-EtKEzL_ogCqJp7PMQ2qsLK7RBkM
                                    Configurations:
                                    https://drive.google.com/open?id=1q-h8eojJ91CQwK2p5YhWKuQaQph0sQ_T
                                    0_1535131031908_8.gcode
                                      That probably means you have either a T0 command or a M109 command near the start of your GCode file before the printer has been homed. M109 or M109 T0 will select T0 implicitly if no tool is selected, and if the printer hasn't been homed than the tool change macros won't be run.
                                      undefined 1 Reply Last reply 25 Aug 2018, 07:24 Reply Quote 0
                                        RajaaKahel @dc42
                                        @dc42 said in Tool changer commands:
                                        M109
                                        This is my Start and Ending Scripts in Simplify3D, nothing else is there in between:
                                        Start Script:
                                        G1 E15 F3000
                                        G28 ; home all axes
                                        G1 Y37
                                        Ending Script
                                        G1 E-15 F4000
                                        T0
                                        ;M98 P/macros/parkT0
                                        M107
                                        M1
                                        I can't find any M109. Where in the Duet I can look for what is causing this? You see I attached all the files in my last post, I can't either find anything in them, please check them yourself too. Maybe my firmware is bad somehow? especially that I have another problem that I have to fix in order for my printer to function! (G10 Z offset for T1 simply doesn't work) as you see here:
                                        https://forum.duet3d.com/topic/6517/setting-z-offset-for-t1/15
                                        Any suggestions please? (at least I have to fix the T1 Z offset issue).
                                        Firmware Version: 1.21 (2018-03-21)
                                        WiFi Server Version: 1.21RC4(08b3)
                                        Web Interface Version: 1.21-RC4
                                          Please post the first 50 or so lines (not counting comment lines) of the GCode file generated by your slicer. You may find that it has inserted a M109 command before your start GCode.
                                          15 out of 32
