Tevo little monster duet conversion
@andrewjames13 said in Tevo little monster duet conversion:
...I believe it maybe a faulty endstop wire I'm changing it when I get back home I know the motor works I plugged it into the second "z" slot an it will home an I plugged a different endstop into the "Y" endstop an the led comes on
looks like you have found at least one issue - if the endstop is not working but putting a different one on that port works then that endstop or wiring has a fault or is disconnected.
@t3p3tony I'm using them motors I have them. I have a smart effector volcano block an a pt100 e3d sensor I need to know how to configure my:
-im swapping to a zesty nimble for the extruder motor
-filament run out sensor
-.9 degree motors from 1.8 degree
-configure the smart effector
-also I'm going to use berd air for part coolingI ordered a 12v berd air because the 24v isnt available for a month I'm gonna switch the motor to a 24v when I'm on reprap configurator in the motor tab so double all the settings I have for X,Y, an Z?
@adavidm do you have more info for what I'm looking to do now ? So everyone knows this is my first delta 3d printer build an first time with duet after this is done I'm going to build a kissel xl
Have you read the guide I linked to? You're asking for us to suggest changes to your configuration but, unless I've missed something, you've not posted your current configuration files.
Tony, one of the Duet3D partners, has suggested you fix your known issue with an endstop. Rather than try too many things at once let's get that sorted, post your configs and then report back the behaviour you are seeing.
Happy to help.
I need to know what I need to change in my configurator to make this run the little monster comes with nema 17 1.8 degree motors
To allow for changing from 1.8 to 0.9deg XYX motors, double the XYZ steps/mm in the M92 command in config.g.
@adavidm I didnt see the link sorry also my endstop is fixed yes bad wire now when I turn it on an try an home I hear terrible sound from the motors am I kick it off so it doesnt destroy itself I'll post configuration now
This post is deleted! -
@dc42 where it says x80 y80 z80 e399 for me? double all them to 160? except for e of course
update my tevo is working thank god i ended up swapping my motors to the .9 degree motors i changed M92 i doubled it i ran the new wires from the motors to the duet wifi 1.04 i have i ran a new wire to my "Y" endstop i ohmed the wire there was i short within the wire an go figure this was a brand new 3d printer a week ago i added the duet wifi to it an still havent done a first print yet. next is my smart effector i messaged haydn huntley he custom made me 400mm arms i have everything except my berd air. i have the volcano heat block pt100 e3d and duet board idk what one is best to use im gonna need help configuring this theres no videos on youtube to use as a guide
