Pause to change filament colour?
5.9k
    dc42 administrators @BlitzReg
    @blitzreg said in Pause to change filament colour?:
    @adrian52 I just ran your line for pause in script. I set it for layer 81. I do have a raft. So, what happened it paused at layer 84 and when I hit resume it left a 1mm gap in between two halfs. Any ideas?
    Have you tested your pause and resume macro files, by pausing a print and then resuming it?
    undefined 3 Replies Last reply 23 Aug 2018, 00:27 Reply Quote 0
      BlitzReg @dc42
      @dc42 I just test it and its not working right. I've posted it here so you can look at the pause and resume files.
      pause.g
      ; pause.g
      ; called when a print from SD card is paused
      ; generated by RepRapFirmware Configuration Tool on Sun May 20 2018 02:01:02 GMT-0700 (Pacific Daylight Time)
      M83 ; relative extruder moves
      G1 E-10 F3600 ; retract 10mm of filament
      G91 ; relative positioning
      G1 Z5 F360 ; lift Z by 5mm
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; go to X=0 Y=0
      resume.g
      ; resume.g
      ; called before a print from SD card is resumed
      G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
      G1 R1 X0 Y0 ; go back to the last print move
      ;G1 E10 F3600 ; extrude 10mm of filament
      undefined 1 Reply Last reply 23 Aug 2018, 10:03 Reply Quote 0
        BlitzReg @dc42
        @dc42 Looks like in my resume.g its not going right where it left off but 5mm higher
        undefined 1 Reply Last reply 23 Aug 2018, 00:52 Reply Quote 0
          BlitzReg @BlitzReg
          @blitzreg I may have found the problem. It retracts 10mm at pause and the when it goes to resume there is a ; in front of extruding 5mm back. So when the nozzle starts to print there is no plastic until it catches up.
            BlitzReg @dc42
            @dc42 Ok, the pause and resume .g files are working when I click on the lcd pause and resume. But when the script runs in S3D I'm getting a 1mm gap in between the model. I put the script bellow. Not sure if its a filament extruding problem. Maybe I should prime it more until it comes out of the nozzle.
            undefined 1 Reply Last reply 23 Aug 2018, 07:26 Reply Quote 0
              Adrian52 @BlitzReg
              @blitzreg Yes I do small extrudes from dwc until the new filament is coming through properly, then retrieve dangling filament just before hitting resume. Generally gives a seamless transition.
                @blitzreg, this line in resume.g:
                should have a Z0 parameter too. But I'm not sure that is causing the problem.
                undefined 1 Reply Last reply 24 Aug 2018, 02:12 Reply Quote 0
                  BlitzReg @dc42
                  @dc42 Ok, after it has paused and I change the filament and before I hit resume. I manually click on retract about 2mm. If I don't when it goes to resume it pushes out to much filament at the first start and leaves a glob. If I do a 2mm retract before I hit resume then it comes out perfect.
                  undefined undefined 2 Replies Last reply 24 Aug 2018, 02:13 Reply Quote 0
                    BlitzReg @BlitzReg
                    @blitzreg my extruder is the Titan Aero with a Volcano. I like the extruder but its a real pain changing out filaments in it and too often when you pull out the filament then the hole gets blocked and impossible to get the new filament back in without disassembly
                    of the extruder.
                      Check your pause.g and resume.g files. Generally you should retract in pause.g and extrude the same amount in resume.g, but if you hot end oozes a lot you may need to extrude less than you retracted. Don't forget to put M83 before the retract and extrude commands in case you were doing a print in absolute extrusion mode.
                      undefined 2 Replies Last reply 24 Aug 2018, 22:06 Reply Quote 0
                        BlitzReg @dc42
                        ; pause.g
                          BlitzReg @dc42
                          @dc42 Just want to say "Thank you" for all the help! This is my first build and there is a lot to learn! I'm already planning a second build and duetwifi will definitely be in that machine also! Just a great board! I use 3D Printers in manufacturing fishing tackle. I own a fishing tackle company. www.wwfishingtackle.com. Thanks, Larry
                          25 out of 27
