    Pause to change filament colour?
    5.9k
    • BlitzRegundefined
      BlitzReg @dc42
      @dc42 Looks like in my resume.g its not going right where it left off but 5mm higher
      BlitzRegundefined 1 Reply Last reply Reply Quote 0
      • BlitzRegundefined
        BlitzReg @BlitzReg
        @blitzreg I may have found the problem. It retracts 10mm at pause and the when it goes to resume there is a ; in front of extruding 5mm back. So when the nozzle starts to print there is no plastic until it catches up.
        • BlitzRegundefined
          BlitzReg @dc42
          @dc42 Ok, the pause and resume .g files are working when I click on the lcd pause and resume. But when the script runs in S3D I'm getting a 1mm gap in between the model. I put the script bellow. Not sure if its a filament extruding problem. Maybe I should prime it more until it comes out of the nozzle.
          Adrian52undefined 1 Reply Last reply Reply Quote 0
          • Adrian52undefined
            Adrian52 @BlitzReg
            @blitzreg Yes I do small extrudes from dwc until the new filament is coming through properly, then retrieve dangling filament just before hitting resume. Generally gives a seamless transition.
              dc42 administrators @BlitzReg
              @blitzreg, this line in resume.g:
              G1 R1 X0 Y0 ; go back to the last print move
              should have a Z0 parameter too. But I'm not sure that is causing the problem.
              • BlitzRegundefined
                BlitzReg @dc42
                @dc42 Ok, after it has paused and I change the filament and before I hit resume. I manually click on retract about 2mm. If I don't when it goes to resume it pushes out to much filament at the first start and leaves a glob. If I do a 2mm retract before I hit resume then it comes out perfect.
                BlitzRegundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • BlitzRegundefined
                  BlitzReg @BlitzReg
                  @blitzreg my extruder is the Titan Aero with a Volcano. I like the extruder but its a real pain changing out filaments in it and too often when you pull out the filament then the hole gets blocked and impossible to get the new filament back in without disassembly
                  of the extruder.
                    @blitzreg said in Pause to change filament colour?:
                    Check your pause.g and resume.g files. Generally you should retract in pause.g and extrude the same amount in resume.g, but if you hot end oozes a lot you may need to extrude less than you retracted. Don't forget to put M83 before the retract and extrude commands in case you were doing a print in absolute extrusion mode.
                    BlitzRegundefined 2 Replies Last reply Reply Quote 0
                    • BlitzRegundefined
                      BlitzReg @dc42
                      ; pause.g
                      ; called when a print from SD card is paused
                      ; generated by RepRapFirmware Configuration Tool on Sun May 20 2018 02:01:02 GMT-0700 (Pacific Daylight Time)
                      M83 ; relative extruder moves
                      G1 E-10 F3600 ; retract 10mm of filament
                      G91 ; relative positioning
                      G1 Z5 F360 ; lift Z by 5mm
                      G90 ; absolute positioning
                      G1 X0 Y0 F6000 ; go to X=0 Y=0
                      • BlitzRegundefined
                        BlitzReg @dc42
                        @dc42 Just want to say "Thank you" for all the help! This is my first build and there is a lot to learn! I'm already planning a second build and duetwifi will definitely be in that machine also! Just a great board! I use 3D Printers in manufacturing fishing tackle. I own a fishing tackle company. www.wwfishingtackle.com. Thanks, Larry
