    My custom Cartesian
    My Duet controlled machine
    14
    152
    23.2k
    • OBELIKSundefined
      OBELIKS
      You know what. Send me sliced file, I'll try it here. We will be able to definitely rule out slicers if it is all OK on my front.
      P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
      Original Prusa i3 MK3S
      • wilrikerundefined
        wilriker @OBELIKS
        @obeliks Uploaded it to my Dropbox 3DBenchy_75mm.gcode.
        Of course you have to adjust start and end codes as for me this simply calls two files in /sys via M98 and temperatures are set at the beginning of the file as well.
        Manuel
        My Tool Collection
        • OBELIKSundefined
          OBELIKS
          Good news, I have the same result. And I think I know what is the problem. Try disabling Print Infill Before Walls. When it was printing walls I could hear it dragging against the infill and I can feel it. With Slic3r that prints walls before the infill by default I never had this issue.
          wilrikerundefined 1 Reply Last reply Reply Quote 1
          • wilrikerundefined
            wilriker @OBELIKS
            @obeliks First of all thanks for your test print! 👍
            I have to check my settings what the actual value of this switch is tomorrow. I know so much as that I am using the default of Cura.
            But interestingly I always thought that printing infill before walls was exactly to prevent the issue I am seeing. But my brain had so much input in the field of 3DP since I (only) started end of March in this adventure it would not be unlikely for me to mix something up here. 😁
            Manuel
            My Tool Collection
            • wilrikerundefined
              wilriker
              OK, I checked the the default settings of Cura. As you said it will by default print infill before walls. In the setting's description it even says this can lead to infill sometimes showing through. I assumed "sometimes" would not mean "nearly always". 🤦 Anyway, it also says that enabling it will improve overhangs significantly.
              But then I also found a setting "Connect infill lines". From the description of it it might alleviate the issue so I get best of both worlds at the price of some more filament because this basically adds another perimeter on the inside.
              I will try both after I switch filament next time because currently this is a borrowed spool that I can use for a specific purpose but I don't want to stretch the generosity by printing an army of Benchies. 😂
              Manuel
              My Tool Collection
              • OBELIKSundefined
                OBELIKS
                If you need more help from me just say. I can print more tests. Just prepare them for PETG.
                • OBELIKSundefined
                  OBELIKS
                  Also. I might be slightly linguistically impared. We have a local festival, so...
                  I really do not mid to run some tests if you need them.
                  • wilrikerundefined
                    wilriker @OBELIKS
                    @obeliks said in My custom Cartesian:
                    Thanks! I might come back to this offer in the future. For now I already appreciate that you pointed me in the right direction.
                    Also have fun at your festival! 🙂 Drink a beer for me - I would not like it anyway so it is better spent on you! 😂
                    Manuel
                    My Tool Collection
                    OBELIKSundefined 1 Reply Last reply Reply Quote 0
                    • wilrikerundefined
                      wilriker
                      Totally unrelated: I am in the process of rewiring everything. It's going quite slow but it progresses. 🙂
                      Last weekend I replaced the wiring for my Z motors. @dc42 suggested somewhere that for high-inductance motors they should be wired in parallel instead of using the in-series-wired two connectors on the Duet. So I did that and could effectively double the max speed of my Z axis to 25mm/s - this looks totally unreal now when moving longer distances after I got used to 10 or 12mm/s max speed I had before. 😁
                      Manuel
                      My Tool Collection
                        deckingman @wilriker
                        @wilriker Lucky you. I run mine at 450mm/min which is 7.5mm/sec. I've pushed it to 10mm/sec (600mm/min) but it's not too happy. Mind, it weighs around 8kg and I'm driving it with 3 screws via a single Nema17. With 750mm Z travel it takes 100 secs to go from max to min (not that I do that too often)☺
                        • OBELIKSundefined
                          OBELIKS @wilriker
                          @wilriker Beers were drank, food was eaten, it was good.
                          Even today it is not too bad.
                          • wilrikerundefined
                            wilriker @deckingman
                            @deckingman But what to do with my luck? Driving Z all day up and down... 😂 I could write a macro for it, it's RRF after all. 😁
                            But still your motor seems to be better than mine plus you probably use 24V.
                            My X gantry weighs about 2kg (probably much less but easier for the following math) and I have two Z motors and therefore only 2 leadscrews. That makes a quarter of the weight, double motor power and only 2/3 of the leadscrew friction. All together my Z axis should run 8-12x as fast as yours and I only have it about 4 times faster.
                            But as you also mentioned: when does one need speed in the Z axis? 😂
                            Manuel
                            My Tool Collection
                              @wilriker said in My custom Cartesian:
                              Ahh, but what is the lead of your screws? Mine are fine lead (1mm) so I've probably got better gearing than you.
                              There is one situation that I could think of where you might need faster Z and this is if you homed to Z max - for example if you want to recover from a power loss on a CoreXY. I don't do that myself as the bed would cool during a power fail and the part would fall off in any case. For me to home to Z max would take 200 seconds (100 seconds to go down 750mm and 100 seconds back up). ☺
                              • wilrikerundefined
                                @deckingman said in My custom Cartesian:
                                Mine is really coarse at 8mm. But that gives me also fewer steps/mm what makes it less likely to get to the speed limit of the motor. 😉
                                Yeah, you're right about that case. Luckily and solely by coincidence I can re-home to regular Z min if X is at min and Y at max position. I could only hit something if I would print in the very back left corner and I never did that so far. 🙂
                                So, no real need for a Z faster than needed at printing. We could invent vertical layers. 🤔 😂
                                Manuel
                                My Tool Collection
                                  I already have a technique for that - it's called printing something on it's side. 😁
                                  • wilrikerundefined
                                    wilriker
                                    @OBELIKS Printed a new Benchy with walls before infill today. Will check the result in detail when I get home. Based on what I can see over the webcam the issue with very visible infill patterns seems at least to be reduced but not completely gone. But images can be misleading. Will report more details tonight.
                                    Manuel
                                    My Tool Collection
                                      Phaedrux Moderator @wilriker
                                      @wilriker You can also modify the amount that infill crosses over into the walls.
                                      • wilrikerundefined
                                        wilriker @Phaedrux
                                        @phaedrux I know but that already is as low as (Cura's default of) 10%. Going lower doesn't make sense IMHO, does it?
                                        Here are the results of printing walls before infill. The backside is totally smooth now. The front side still some infill is visible and it can be felt when sliding a finger across the surface. To my surprise it is rougher though than previous ones.
                                        front side
                                        Front side. Previous result on the left, today's Benchy on the right.
                                        back side
                                        Back side. Again old Benchy to the left, new one on the right.
                                        Manuel
                                        My Tool Collection
                                          How many walls are you using? Adding another wall would be my suggestion. With a 0.4 nozzle I usually use 3.
                                          • wilrikerundefined
                                            wilriker @Phaedrux
                                            @phaedrux With most of the settings I go by Cura's defaults. In case of perimeter count it is 2. I only increase this for parts that need additional strengths e.g. to directly tap screws into the plastic.
                                            I still have a setting to test called "Connect infill lines". It basically is an additional inner perimeter. I guess this will solve the issue finally.
                                            Manuel
                                            My Tool Collection
