Duet Maestro Freefall
Firmware wishlist
10
51
5.7k
    fcwilt @LeonMF
    @leonmf said in Duet Maestro Freefall:
    I can post a picture later if you still want one.
    Thanks much. That is a large and pricey printer. I guess for that kind of money that can provide a low friction setup.
    My FT5 moves smoothly but it slowly sinks down without crashing.
      LeonMF
      I hope this printer becomes a solid workhorse but, I'm afraid, it is still more of a beta solution and this particular problem is one of the more vexing ones!
      Current: Railcore II ZLT w/Duet 3 and Hemera hot end.
      Retired: Robo3D R1,BI V2.5 Delta updated to BerryBot magnets, bespoke carriages and Duet Ethernet, M3D Promega;
        LeonMF
        Here are some videos highlighting the issue:
        Duet Power off free-fall:
        https://youtu.be/WCvHGXi6jxs
        Duet Power On Free-Fall
        https://youtu.be/7uG-6czPOVY
        Duet Bed Stall crash
        https://youtu.be/QH9c-w1Nbgg
        undefined undefined undefined 3 Replies Last reply 29 Aug 2018, 07:10 Reply Quote 1
          mrehorstdmd
          Wow! I'd say something needs to be done about that.......
            deckingman @LeonMF
            @leonmf OK. So what seems to be happening is that the bed is being driven in minus Z because those moves are very much faster than gravity with no power. So if it's being driven, then there must be something in your files telling it to move to Znnn at a feedrate (speed) of Fnnn. Might be an idea to post your home Z file, or at least take a look at it and see what is being commanded after the probe or stall detection or whatever method you use to home, has been triggered.
            Edit. And/or you have the steps per mm for Z set wildly wrong.
              wilriker @LeonMF
              @leonmf For one @deckingman is right, the last one is definitely driven by the motor. You can even hear the high pitched sound of the motor running at a very high speed. Please post homez.g, homeall.g and maybe also your config.g.
              Manuel
              My Tool Collection
              undefined 1 Reply Last reply 29 Aug 2018, 08:36 Reply Quote 0
                deckingman @wilriker
                @wilriker said in Duet Maestro Freefall:
                @leonmf For one @deckingman is right, ...................
                Manuel, mind if I correct your translation? That sounds a bit like "For once deckingman is right" To a native English speaker, that means the person is usually wrong but on this occasion was right. Now of course, you might have meant that I'm usually wrong, in which case no correction is needed 😉
                undefined 1 Reply Last reply 29 Aug 2018, 08:57 Reply Quote 0
                  wilriker @deckingman
                  @deckingman said in Duet Maestro Freefall:
                  Thanks and I never mind being corrected! 🙂 Also I definitely did not want to say that you are usually wrong because I know better. 😂 (And I don't mean I know better not to say it but I know better that this would not be true).
                  But one thing I wonder now: I wrote "For one" and wanted to say "First of all" whereas you corrected "For on_c_e" (which I would have known to have the meaning to described). So would my wording have expressed what I wanted to say?
                  Manuel
                  My Tool Collection
                  undefined 1 Reply Last reply 29 Aug 2018, 10:06 Reply Quote 0
                    I agree, the motor is definitely driving the bed down.
                    Is the printer definitely being controlled by a Duet Maestro? I believe M3D used other Duets in early machines, before the Maestro became available. So I am wondering whether your machine is running a Duet 2 Ethernet and the stall detection is configured to do something silly.
                      Yes, you did say "for one" but it's not a common or normal expression. So the meaning of what you wrote was clear but it's an unusual thing to say. Hence it could easily be misinterpreted as a typo and the actual meaning was something else. Whilst I always enjoy these little chats, this probably isn't the time or place to discuss the finer points of English grammar. ☺
                      undefined 1 Reply Last reply 29 Aug 2018, 10:16 Reply Quote 0
                        You are right and we should put a stop to hijacking this thread. 😉 Thanks for clarification, though.
                        Manuel
                        My Tool Collection
                          LeonMF
                          @dc42 This is definitely a Duet Maestro. I can post a board picture later if you want confirmation.
                          Firmware Name: RepRapFirmware for Duet 2 Maestro
                          Firmware Electronics: Duet Maestro 1.0
                          Firmware Version: 2.01beta1(RTOS) (2018-06-23b1)
                          Web Interface Version: 1.22.1
                          Here is my current config:
                          https://www.dropbox.com/s/aeppocjnft4zg4q/Promega Config.zip?dl=0
                          I looked for an a M915 command in the files but found nothing, Typing M915 into the gcode console says not supported. Is there something else I should be looking at?
                            Dougal1957
                            Could this by due to the fact that you have Deploy/retractprobe files in the sys directory there was a note on one of the firmware updates to remove them as they caused issues?
                              wilriker
                              What confuses me more is that on the one hand the config defines
                              M574 X2 Y2 Z2 S0 ; Set xy end-stops types (S0 is active low, applied to XY)
                              a Z-max switch as an endstop in machine_endstoptypes.g and then also
                              a switch-based Z-probe in machine-zprobe.g.
                              Additionally at the start of homez.g there is
                              ; Ignore Machine boundaries
                              M564 H0 S0
                              and I am not sure how this influences the latter
                              ; Rapid Z until limit switch triggers
                              G0 Z450 F1500 S1
                              in the same file.
                              So @LeonMF can you give some more information on what your endstop for Z actually is?
                              Manuel
                              My Tool Collection
                              undefined 1 Reply Last reply 29 Aug 2018, 13:13 Reply Quote 0
                                Dougal1957
                                The way the config has been written with all those called macros is very confusing that's for sure it seems to be very over complicated
                                undefined undefined 2 Replies Last reply 29 Aug 2018, 12:39 Reply Quote 0
                                  wilriker @Dougal1957
                                  @dougal1957 said in Duet Maestro Freefall:
                                  Hehe, I was in the process of changing my config to the same style a couple of days ago until I realized that this will make it less readable then before and reverted everything back. 😁
                                  Manuel
                                  My Tool Collection
                                    LeonMF @Dougal1957
                                    @dougal1957 I'm with you. That's the way it came from M3D and I haven't taken the steps to merge them yet. I see what they were trying for but I don't think they realize how painful it is to dig through!
                                      LeonMF @wilriker
                                      @wilriker The system has a max travel Z-endstop at the bottom of Z travel used for homing. There is also a manually deployed limit switch probe and an IR probe attached to the hot end. The deployable probe and the IR probe are either/or changed in one of the files.
                                      @Dougal1957 I don't know about the deploy/retract files. The system can't use them and they are in the M3D default image. They left Homedelta, too and I'm pretty sure that's not needed. 🙂
                                      undefined 1 Reply Last reply 29 Aug 2018, 13:15 Reply Quote 0
                                        wilriker @LeonMF
                                        OK, I see.
                                        So what exactly are you doing to get this horrible bed race towards the bottom effect? Is it homing Z or bed leveling?
                                        They are empty anyway.
                                        Manuel
                                        My Tool Collection
                                        undefined 1 Reply Last reply 29 Aug 2018, 13:34 Reply Quote 0
                                          LeonMF @wilriker
                                          @wilriker The bed crash is caused when the z is driven into an immovable object like the hot end and stalls out. This is, presumably, triggering a fault of some sort and the user theory on the M3D discord is that a mosfet disconnects the motor connection and lets it freewheel.
                                          I'm not electrically savvy enough to know if this is what's going on. I'm pretty good with config files but when we get into esoteric electrical properties I get lost!
                                          undefined undefined 2 Replies Last reply 29 Aug 2018, 14:11 Reply Quote 0
                                          15 out of 51
